Prizrak #1 Posted April 7, 2020 I was using a flat LCD TV to play my Atari games on but some games didn't work with my TV and switching to a CRT solved that problem. Now I've got a new problem. The LCD had a separate right and left audio for composite and I would use one for game audio and the other for Atarivox to mix the two together. My CRT has one audio instead of two. When I try and blend them using a Y jack the Atarivox overpowers the game audio and all I hear is the Atarivox talking. Somehow the Atarivox appears to be putting out so much voltage it overpowers my Atari audio? Anyway around this other than buying a set of computer speakers? Sent from my SM-N960U using Tapatalk Quote Share this post Link to post Share on other sites
+save2600 #2 Posted April 7, 2020 Look into the audio output... the AtariVox has a volume pot inside. Can carefully pop the case open or use a tiny screwdriver to access it. Quote Share this post Link to post Share on other sites
Prizrak #3 Posted April 7, 2020 Think it's because I've got the volume on it turned up and the higher voltage is cancelling my game audio?Sent from my SM-N960U using Tapatalk Quote Share this post Link to post Share on other sites
+save2600 #4 Posted April 7, 2020 That was my first thought, but now I'm thinking maybe the AVox is grounding out the signal of your 7800's audio? I have a similar setup and will try combining the two outputs in one, to hear if that's the case. May need a diode or two. -edit- Yep, that's what's going on. AVox output cancelling/grounding out the 7800's output. Quote Share this post Link to post Share on other sites
Prizrak #5 Posted April 7, 2020 I'll try the volume first but grounding out seems to be what might be going on. The game auto is non existent and all I hear is Atarivox.Sent from my SM-N960U using Tapatalk Quote Share this post Link to post Share on other sites
+save2600 #6 Posted April 8, 2020 Just got through testing this. A diode out of the center tap of the AVox's audio helped to isolate, so can combine the two channels that way if you want. Quote Share this post Link to post Share on other sites
+Karl G #7 Posted April 8, 2020 Dumb question perhaps, but do you hear the Atari audio when it is plugged in through the Y adapter when the AtariVOX isn't connected to the other end at all? Quote Share this post Link to post Share on other sites
+Nathan Strum #8 Posted April 8, 2020 I built a simple circuit to combine the audio. Just need a few resistors - you can splice them into a Y cable if you don't want to build it into a project box. http://cheeptech.com/atarivox.html Quote Share this post Link to post Share on other sites
Prizrak #9 Posted April 8, 2020 Dumb question perhaps, but do you hear the Atari audio when it is plugged in through the Y adapter when the AtariVOX isn't connected to the other end at all?Yeah in the Y the game audio plays when the Atarivox line is pulled.Sent from my SM-N960U using Tapatalk Quote Share this post Link to post Share on other sites
mutterminder #10 Posted April 10, 2020 I don't mix mine, I just run the original Atari sound to the left channel and the Atarivox to the right channel. 1 Quote Share this post Link to post Share on other sites
Prizrak #11 Posted April 10, 2020 I was able to do that with my flat TV but this CRT has one audio and one video jack unfortunatelySent from my SM-N960U using Tapatalk Quote Share this post Link to post Share on other sites
Prizrak #12 Posted April 11, 2020 Got some speakers in today, glad to be hearing the Atarivox talking again. Sent from my SM-N960U using Tapatalk 1 Quote Share this post Link to post Share on other sites
alex_79 #13 Posted April 12, 2020 On 4/8/2020 at 1:25 AM, Prizrak said: When I try and blend them using a Y jack the Atarivox overpowers the game audio and all I hear is the Atarivox talking. The problem was the Y-cable: Y-cables can be used to split an audio signal in most cases, but they must never be used to mix 2 signals together. As you experienced, it won't work, and there's even the risk of damaging your equipment in doing so. You need a resistive network to achieve what you want, like explained in the page linked by @Nathan Strum a few posts above. Quote Share this post Link to post Share on other sites
Prizrak #14 Posted April 12, 2020 We'll I'm glad I didn't jack anything up. Sent from my SM-N960U using Tapatalk Quote Share this post Link to post Share on other sites
