Bee #1 Posted April 13, 2020 So I have a new Ultra Satan and have the Get Clock in my Auto folder. On boot it shows the year 2020 retrieved, but the control panel shows 2028. Anyone know why? This is a STE on TOS 1.06, from what I read, this should be fixed until 2030? Thank you Quote Share this post Link to post Share on other sites
ParanoidLittleMan #2 Posted April 13, 2020 When you write some file on disk - like DESKTOP.INF when click on Save Desktop - what is date of it ? I guess that Control.acc is just not ready for this years . 1 Quote Share this post Link to post Share on other sites
Bee #3 Posted April 14, 2020 New folders are assigned the date 4-13-28. This is with old accessory control.acc and xcontrol.acc. Both show this date. Quote Share this post Link to post Share on other sites
ParanoidLittleMan #4 Posted April 14, 2020 OK. But should check it without any ACC - boot so, that those accessories are not in C - like rename it to *.AC temporarily . Only then can be sure about is it TOS, ACC or maybe Get Clock is not ready for years 2020 . Quote Share this post Link to post Share on other sites
krupkaj #5 Posted April 14, 2020 There is a trouble with storing the year in the TOS. Try Y2K fix program from Troed. Quote Share this post Link to post Share on other sites
Colleton #6 Posted April 15, 2020 22 hours ago, krupkaj said: Try Y2K fix program from Troed https://blog.troed.se/projects/dallas-rtc-sync-tos-y2k-fix/ I found this and downloaded it last night but haven't tried it yet. Is it specific to the Dallas RTC mentioned in the blog post or will it work with the US? Quote Share this post Link to post Share on other sites
bfollowell #7 Posted April 15, 2020 Did you ask Lotharek? I'm assuming, since he's selling the device, he'd be somewhat familiar with it, and how it works, and would be able to tell you what clock accessory to use, if a fix is required, etc. If he's ever able to finally start shipping again, I have a US coming from him as well and would be interested in knowing how this turns out. I would think there would be enough US users on here that someone would've been able to give you a definitive answer by now. Quote Share this post Link to post Share on other sites
krupkaj #8 Posted April 15, 2020 4 hours ago, Colleton said: https://blog.troed.se/projects/dallas-rtc-sync-tos-y2k-fix/ I found this and downloaded it last night but haven't tried it yet. Is it specific to the Dallas RTC mentioned in the blog post or will it work with the US? in the doc is written is works as Y2K fix only when th Dallas is not installed Quote Share this post Link to post Share on other sites
bfollowell #9 Posted April 15, 2020 (edited) So, Bee, did you not order your US from Lothark? Right there on the website, on the web page for all of the US products, there is a link called Files. If you look there, you'll find a file called clock.zip. I'm fairly certain all the files and documentation you need to get your clock working properly are included in that zip file. I don't have mine yet, so I can't play around with it, but a cursory glance looks like that is what you need. Remember, always go back to the seller/manufacturer for help first. https://lotharek.pl/productdetail.php?id=48#files Edited April 15, 2020 by bfollowell Quote Share this post Link to post Share on other sites
Bee #10 Posted April 15, 2020 Those are the files I'm using. I wrote Lotharek other questions and never got an answer. I will try the Y2k file I got it last night as well. Thank you Quote Share this post Link to post Share on other sites
bfollowell #11 Posted April 15, 2020 42 minutes ago, Bee said: Those are the files I'm using. I wrote Lotharek other questions and never got an answer. I will try the Y2k file I got it last night as well. Thank you Well, that’s all I can offer until I get mine then, but I’ll be watching. Good luck. Quote Share this post Link to post Share on other sites
Bee #12 Posted April 16, 2020 What hardware & TOS will you be running it on? Quote Share this post Link to post Share on other sites
bfollowell #13 Posted April 16, 2020 I have a 1040STE with dual TOS 1.62/2.06 Quote Share this post Link to post Share on other sites
Bee #14 Posted April 18, 2020 OK on a 1040STE, 4megs, TOS 1.06, Ultra Satan, Y2KFIX.PRG US_GET_CL.PRG Results is 4/17/00 in the desk accessory Control.Acc Booting under TOS 2.06 creating a folder is dated 4/17/00 Still tying to find a solution Thank you Quote Share this post Link to post Share on other sites
ParanoidLittleMan #15 Posted April 18, 2020 It looks that SW is able to cover only 20 year span - 0-19, when it reaches 20, as it is now, it goes back to 0. And real culprit is TOS self. About what I wrote here earlier. https://atariage.com/forums/topic/298769-some-less-known-things-about-tos-reasons-of-bad-programming-of-sw/ Last paragraph of first post in that thread. I will look into this later, probably need to correct that fixer SW, or writing new .. Quote Share this post Link to post Share on other sites
Bee #16 Posted April 18, 2020 I found some interesting info here: http://www.atari-forum.com/viewtopic.php?t=31017 I'm unclear if it changes anything. Thank you Quote Share this post Link to post Share on other sites
Bee #17 Posted April 20, 2020 Following up, on the 1040STE, TOS 1.06, I get the wrong year. On a Mega STE with TOS 2.05 I get the right date. Both running from the same Ultra Satan. Thank you Quote Share this post Link to post Share on other sites
bfollowell #18 Posted April 20, 2020 It may be a TOS issue. Whenever I get mine, and when I get my dual-TOS card installed and running, I'll check it with U.S. 1.62 and 2.06 and see if the dates work correctly or not. 1 Quote Share this post Link to post Share on other sites
tzok #19 Posted May 3, 2020 (edited) This utility probably uses standard GEMDOS routine to set the Real Time Clock. Although the GEMDOS as well as XBIOS are just fine with years above 2000, but the IKBD controller which runs a hardware RTC on ST - isn't. It accepts time and date in BCD format, with only 2 digits for year. XBIOS routine to read/set date from/to RTC uses dummy BIN to BCD conversion routine, and for year 2000 we get A0 (what should be understood as 100), and respectively for 2020, we'd get C0. Actually when you set date with CONTROL.ACC and XCONTROL.ACC, and when year is lower than 80 (1980) they send 100+year. Unfortunately IKBD ignores any entries higher than 99. Fields that are not valid BCD values are used as blanks - you always have to sent time and date, but when you want to set time only you may set all other fields to FF, or AA... they will be ignored. Year 2028 is returned in your case, because uninitialized IKBD returns year C8 (and initializing it with any value higher than 99 leaves it as it was), rest of fields are initialized correctly. For details, please read my topic: https://www.exxoshost.co.uk/forum/viewtopic.php?f=10&t=544&start=40 ...and this post: https://www.exxoshost.co.uk/forum/viewtopic.php?p=28783#p28783 Edited May 3, 2020 by tzok TOS -> XBIOS 1 Quote Share this post Link to post Share on other sites
JohnPolka #20 Posted May 10, 2020 (edited) On 4/15/2020 at 6:48 AM, Colleton said: https://blog.troed.se/projects/dallas-rtc-sync-tos-y2k-fix/ I found this and downloaded it last night but haven't tried it yet. Is it specific to the Dallas RTC mentioned in the blog post or will it work with the US? The Dallas RTC Y2K fix will work without a Dallas RTC installed. I use it to fix a Y2K problem on a 1040STE running TOS 2.06. Saying that, I had to follow these steps to get it to properly set the year: 1. Set the date using the current year - 30. That is, subtract 30 from the current year (e.g., use 1990 for 2020). 2. Run the DALLRTC.PRG The DALLRTC.PRG (Dallas RTC Y2K fix) program will add 30 to the system year and give you the correct year. This fix will work until 2030. -JP Edited May 10, 2020 by JohnPolka 1 Quote Share this post Link to post Share on other sites
Colleton #21 Posted May 11, 2020 Good info, thanks! Quote Share this post Link to post Share on other sites
glorfindeal1 #22 Posted May 31, 2020 (edited) On 5/10/2020 at 5:50 PM, JohnPolka said: The Dallas RTC Y2K fix will work without a Dallas RTC installed. I use it to fix a Y2K problem on a 1040STE running TOS 2.06. Saying that, I had to follow these steps to get it to properly set the year: 1. Set the date using the current year - 30. That is, subtract 30 from the current year (e.g., use 1990 for 2020). 2. Run the DALLRTC.PRG The DALLRTC.PRG (Dallas RTC Y2K fix) program will add 30 to the system year and give you the correct year. This fix will work until 2030. -JP So what do we do in 2031? Does this program replace the set date program for the Ultrasatan? Edited May 31, 2020 by glorfindeal1 Quote Share this post Link to post Share on other sites
tzok #23 Posted May 31, 2020 (edited) You may always install my hardware fix. It will work until 2059, and you'd also get a battery backed-up RTC for free Edited May 31, 2020 by tzok update Quote Share this post Link to post Share on other sites
videofx #24 Posted May 31, 2020 I will try this on my Mega STE as soon as my Ultra Satin arrives Quote Share this post Link to post Share on other sites
JohnPolka #25 Posted June 1, 2020 10 hours ago, glorfindeal1 said: So what do we do in 2031? Does this program replace the set date program for the Ultrasatan? Hopefully someone will have an RTC fix for 2031 before 1/1/2031. This does not replace the set date program for Ultrasatan. It just fixes the date if the date is not showing up correctly on your ST. But you'll need to follow the steps I mentioned to get it to work. -JP Quote Share this post Link to post Share on other sites
