vazquezrick
jzIntv - Stopped working
Posted (edited)
Hello, I recently fired up jzIntv and it stopped working.
I noticed when I have "Audio enabled" the emulator will hand to a black screen. After about 10 sec the emulator crashes. When I click off "Audio enabled" the emulator crashes immediately. I download a new version, same issue.
Anyone have the same issues.
New information:
D:\jzIntv\bin>start /B /WAIT jzIntv -e "D:\jzIntv\bin\exec.bin" -g "D:\Emulation\Download\intellivision\jzIntv\bin\grom.bin" -E "D:\Emulation\Download\intellivision\jzIntv\bin\ECS.BIN" -a0 -v1 -s1 "d:\Emulation\Download\intellivision\Nostalgia\roms\Flintstones Keyboard Fun.bin"
AVI: 1.000 1.000 1.000
Loading:
  d:\Flintstones Keyboard Fun.bin
  d:\Flintstones Keyboard Fun.cfg
Compatibility:
  ECS                    Tolerates
  Intellivoice           Tolerates
  Intellivision II       Tolerates
  Keyboard Component     Tolerates
  TutorVision            Tolerates
JLP Support:
  JLP Accel              Disabled
  JLP Flash Sectors      0
jzintv:  Initializing Master Component and peripherals...
active x: 0, 159, 8 active y: 4 195, 16
joy:  Found 1 joystick(s)
joy:  Joystick JS0 "3Dconnexion KMJ Emulator"
joy:     6 axes, 0 trackball(s), 1 hat(s), 4 button(s)
CP-1610          [0x0000...0x0000]
PSG0 AY8914      [0x01F0...0x01FF]
PSG1 AY8914      [0x00F0...0x00FF]
[Graphics]       [0x0000...0x0000]
Scratch RAM      [0x0100...0x01EF]
System RAM       [0x0200...0x035F]
EXEC ROM         [0x1000...0x1FFF]
ECS RAM          [0x4000...0x47FF]
ECS ROM (2xxx)   [0x2000...0x2FFF]
ECS ROM (7xxx)   [0x7000...0x7FFF]
ECS ROM (Exxx)   [0xE000...0xEFFF]
ECS UART         [0x00E0...0x00E3]
Pad Pair 0       [0x01F0...0x01FF]
Pad Pair 1       [0x00F0...0x00FF]
STIC             [0x0000...0x007F]
STIC (alias)     [0x4000...0x403F]
STIC (alias)     [0x8000...0x803F]
STIC (alias)     [0xC000...0xC03F]
STIC (BTAB)      [0x0200...0x02EF]
GROM/GRAM        [0x3000...0x3FFF]
[Event]          [0x0000...0x0000]
[Rate Ctrl]      [0x0000...0x0000]
Legacy BIN+CFG   [0x5000...0x6FFF]
Legacy BIN+CFG   [0xD000...0xDFFF]
CP-1610 Snoop    [0x0200...0x035F]
Starting jzIntv...
HALT! PC=1739 Instr =          1 MS =         13
Edited by vazquezrick
Your parameters seem okay, but that last line "PC =1739" has me interested.  That address would be an EXEC entry point.  Do you have the actual exec.bin file from the Lives! or Rocks! CD, or is it the fake one for homebrews only?
I'll look for the exec.bin from the Lives! or Rocks! CD.
Update: I did a clean install, the emulator works without sound. If I enable the sound jzIntv will crash. I used an older version of jzIntv and it behaves the same way, crashes. I used the same roms in Nostaligia and works fine, sound and all.
Strange
Can you post the command line and output with sound enabled.  From where are you downloading jzintv?  What's the operating system?
To test, put exec.bin and grom.bin in the jzintv/rom subfolder, open a command line and run "jzintv joy_diag".
I had trouble with sound running jzintv in my Linux environment originally, and the trouble was with the configure script for the pulseaudio package, not jzintv itself.  What OS are you using?
input and output:
C:\jzIntv\bin>jzIntv "C:\jzIntv\rom\astrosmash.rom"
Loading:
Downloaded from: http://spatula-city.org/~im14u2c/intv/
Windows 10 Pro 64-bit, version 1909
C:\jzIntv\bin>jzintv joy_diag
Loading:
  .\..\rom\joy_diag.rom
Name                     Joystick Diagnostics
Short Name               Joystick Diags
Author                   Joe Zbiciak
License                  GPLv2+
Release date             2005
Compatibility:
  ECS                    Tolerates
JLP Support:
  JLP Accel              Disabled
  JLP Flash Sectors      0
C:\jzIntv\bin>
The only problem I had with windows 10 was flipping between full screen and window, or was it window to full screen.  One would cause a crash.  Try it with the full screen switch -f1 on the command line.
I believe I know what the issue is. Likely you are running jzintv with the open sourced MINIEXEC.BIN (named EXEC.BIN) while your installation of Nostalgia is set up using the original, still copyrighted EXEC.BIN. I verified this by running jzintv with ECS enabled and the mentioned cartridge. Using the original EXEC it boots as it should, using MINIEXEC it crashes out right away.
Is there a difference in the files you have in these two folders? Since you most likely already have the copyrighted files on your system, you might as well use the same files with all instances of the emulator.
D:\jzIntv\bin\
Posted (edited)
Now I remember that this issue was caused by video colour depth.  The computer didn't like jzintv 8-bit colour.  Setting jzintv to 32-bit colour (eg. -z640x480,32) solved that problem.
In your case there could be an audio incompatibility. Jzintv still uses sdl 1.2, which is a little old, although I had no issues with audio and Windows 10.
Edited by mr_me
When I load the emulator with sound a window labeled SDL_app freezes for a 5 secs then quits.
