rockdoc2010 Posted April 15, 2020 Share Posted April 15, 2020 I just fired up my 1088XLD and I get a eight note musical rif but my screen is blank. Color filled, one color adjustable by the pot, but nothing is loading from U1MB. I hear a slight sound when I hit F12 or F11 but I am getting no action on the screen. Its a great looking single color screen btw. I used Sdrive max on my XEL in order to do all of it's updates; U1MB firmware, XEL-CF3, and SdosX but I am stuck on the 1088XLD. Any suggestions? Quote Link to comment Share on other sites More sharing options...
Sugarland Posted April 15, 2020 Share Posted April 15, 2020 Did it ever work? If not, suggest you triple check everything. Quote Link to comment Share on other sites More sharing options...
rockdoc2010 Posted April 15, 2020 Author Share Posted April 15, 2020 No it has not yet worked. I replaced the sally, antic pia and reseated the u1mb and the Sram . I am reassembling now. Quote Link to comment Share on other sites More sharing options...
Sugarland Posted April 15, 2020 Share Posted April 15, 2020 Okay but what about the many small components on the board? Did you assemble it from a bare board? Quote Link to comment Share on other sites More sharing options...
rockdoc2010 Posted April 15, 2020 Author Share Posted April 15, 2020 Yes I did and no joy with the chips I changed. I will try the GTIA now. Quote Link to comment Share on other sites More sharing options...
rockdoc2010 Posted April 15, 2020 Author Share Posted April 15, 2020 Well I verified that it most likely the U1MB. When I took out my U1MB from the 1088XLD and plugged into my 1088XEL I got the same full screen issue. I thought I was putting back the original into the XEL and thought I killed my XEL. I put the other U1MB back into my XEL and my system boot to spartados 4.49 WOO HOO it aint dead! So now I just need to pull the plcc from the bad U1MB and send it off to get reprogrammed. Assuming I can find a suitable vendor. Thank you for your time! Rockdoc2010 Quote Link to comment Share on other sites More sharing options...
rockdoc2010 Posted April 15, 2020 Author Share Posted April 15, 2020 Nope I was wrong. I looked closer and saw that I had an older version of the U1MB software installed in the XEL. Swapped again and found the correct version in that board. Woo Hoo! No bad U1MB. Sooooo there is an issue that tells the U1MB to boot up the OS that is inherent to my 1088XLD motherboard. Rockdoc2010 1 Quote Link to comment Share on other sites More sharing options...
