Wrathchild Posted April 19, 2020 Share Posted April 19, 2020 And KimXXL might get you in trouble home ? 1 Quote Link to comment Share on other sites More sharing options...
Faicuai Posted April 19, 2020 Share Posted April 19, 2020 11 hours ago, flashjazzcat said: Unless causing problems with anything third-party is one of your trademark methods. Those entry points in Mapping the Atari should never have been published in the first place; the impressionable are encouraged to think they are legitimate calls. There is no problem, whatsoever, with the vector-tables published in Mapping The Atari. To such a point, in fact, that they clearly state the nature and use of their documented work: "The OS has been considerably rewritten and changed since the 400/800. The ANTIC, PIA, and POKEY chips are the same, but many OS routines have been moved. The vectors in RAM have remained in place for the most part, so software which avails it- self of these locations can run on all machines, Always use the vectors when writing software to use OS routines, never the ac- tual routines themselves; they may change, while the vectors will not." 1 Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted April 19, 2020 Share Posted April 19, 2020 7 hours ago, Faicuai said: There is no problem, whatsoever, with the vector-tables published in Mapping The Atari. To such a point, in fact, that they clearly state the nature and use of their documented work: He isn't using the vector table: please don't attempt to misrepresent my point simply in order to perform the usual gainsaying dance. Mapping the Atari lists addresses of arbitrary code locations as if they were entry points. It's no good putting a disclaimer alongside; as we can see, it's easily ignored. 1 Quote Link to comment Share on other sites More sharing options...
thorfdbg Posted April 19, 2020 Share Posted April 19, 2020 2 hours ago, flashjazzcat said: He isn't using the vector table: please don't attempt to misrepresent my point simply in order to perform the usual gainsaying dance. Mapping the Atari lists addresses of arbitrary code locations as if they were entry points. It's no good putting a disclaimer alongside; as we can see, it's easily ignored. Even more so as other parts of the Os do not use a vector table, i.e. the math pack. I know it is not really part of theOs, but part of the Basic which was migrated, but this does not improve the situation either. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted April 19, 2020 Share Posted April 19, 2020 1 minute ago, thorfdbg said: Even more so as other parts of the Os do not use a vector table, i.e. the math pack. Yes: that math pack is a real cluster, but since it's understood that the entry points are in the middle of the code, reimplementations always keep the entry points the same. It should have had a jump table at the front of the FP pack, but it doesn't. Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted April 19, 2020 Share Posted April 19, 2020 Lets not forget the game in all this, coders will be coders, some have a penchant for doing stuff 'their way' which will always rub correct coders up the wrong way, is it deliberate, you take your pick. As a true amatuer coder in the past I was always told to do it by the book because the code was right and it was transferable between OS's. I probably never got in to those regions because of my lack of skill but I understand the process. At the end of the day there's a game there, I care more about if its proper chess than if it works on multi OS's but as with REAL coders like FJC how its done is important, is it going to work on the many devices he so carefully codes (thank you FJC) so he's got every right to quiz the coding but let's not forget the game in all this. I knew some local coders back then who did what they called Q&D or quick and dirty coding and hitting the OS with direct calls rather than the set points outlined, was it gaining anything, I don't know but it just made their stuff OS dependant...A bit silly if you ask me. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted April 19, 2020 Share Posted April 19, 2020 (edited) Thanks for the game port and your time making it kind sir. Edited April 19, 2020 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
xxl Posted April 19, 2020 Author Share Posted April 19, 2020 22 hours ago, a8isa1 said: - display the notation for the computer's last move. done test.obx 1 1 Quote Link to comment Share on other sites More sharing options...
Faicuai Posted April 19, 2020 Share Posted April 19, 2020 4 hours ago, xxl said: done test.obx 4.49 kB · 9 downloads Nice!!! I don't have any issues with direct OS calls, as long as I know up-front the expected downside or requirements. Here's a special XL-03 load (its core is intact, plus other useful stuff on it) that also provides embedded E: acceleration. AtariOS-800XLXE-Rev03-ULT1M-F1_F4-FP-E.rom The above .obx seems to work well and displays a LOT faster with it. ANTIC can be turned off, on-the-fly with "CTRL+ Inverse", for max. CPU bandwidth. Quote Link to comment Share on other sites More sharing options...
xxl Posted April 19, 2020 Author Share Posted April 19, 2020 21 minutes ago, Faicuai said: Here's a special XL-03 load (its core is intact, plus other useful stuff on it) that also provides embedded E: acceleration. not working: Quote Link to comment Share on other sites More sharing options...
Faicuai Posted April 19, 2020 Share Posted April 19, 2020 (edited) 8 minutes ago, xxl said: not working: Very interesting!!! And that seems coming from the embedded E: acceleration... (Hyper E:) I do wonder what triggers it, though (and why on that specific corner)... But whatever it is, it is wrong... Edited April 19, 2020 by Faicuai Quote Link to comment Share on other sites More sharing options...
StickJock Posted April 19, 2020 Share Posted April 19, 2020 It's not just that corner. The entire column is shifted down. Looks like an off-by-one bug. Quote Link to comment Share on other sites More sharing options...
Faicuai Posted April 19, 2020 Share Posted April 19, 2020 5 minutes ago, StickJock said: It's not just that corner. The entire column is shifted down. Looks like an off-by-one bug. Correct! And that begs the question where the "h" comes from at the top of that list (that belongs to another "list"... It is a one-spot off-set on the output... I wonder if that section is being displayed on a different order or sequence than the others? Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted April 19, 2020 Share Posted April 19, 2020 (edited) A byte saved due to an assumption of the status of the carry post the O/S call: Edited April 19, 2020 by Wrathchild Quote Link to comment Share on other sites More sharing options...
Faicuai Posted April 19, 2020 Share Posted April 19, 2020 (edited) 2 hours ago, Wrathchild said: A byte saved due to an assumption of the status of the carry post the O/S call: Interesting!! (and THX for taking the time to trace this one down...) That seems the code of MiniChess, not the OS-embedded E: accelerator, BTW. So a CLC between $259B and $259E would make it, in order in preparation for the DEC at $259E? Edited April 19, 2020 by Faicuai Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted April 19, 2020 Share Posted April 19, 2020 (edited) In the normal OS the carry is set, so added to the $67 = $68 So the fix would be to use CLC / ADC #$68 or SEC ADC #$67 [Edit] very quite to debug in Altirra, used memory view at $BC00 to see where the character was located used "bx write=$bceb" and then looked at the history window Edited April 19, 2020 by Wrathchild 1 Quote Link to comment Share on other sites More sharing options...
Faicuai Posted April 19, 2020 Share Posted April 19, 2020 3 minutes ago, Wrathchild said: In the normal OS the carry is set, so added to the $67 = $68 So the fix would be to use CLC / ADC #$68 or SEC ADC #$67 OK, so. (when I have a little time) I wrap $25A3-$25A7 with custom JSR to pre-set location, and execute carry-setting there with an RTS and see what happens... In any case, the embedded E: accelerator may need to be revised to consider this particular condition and set Carry per oem-OS execution on those specific calls. THANKS for the insight!!! Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted April 20, 2020 Share Posted April 20, 2020 (edited) The E: accelerator does a good job taking a fifth of the time of the OS PutChar function. However it too keeps the $F2B0 as a direct entry point rather than updating the table and so could have shaved 3 cycles. The code after the JMP (that replaces STA ATACHR) is the same and is JMP'd back to and so as this is used it cannot be overwritten however, the new routines are nicely padded and so can be tweaked. So patching your replacement OS as follows: @ offset ($C)BE7, changed the RTS to SEC/RTS and so the checksum @ ($C0)00/01 then becomes $1C/$0B Whether it should be a guarantee that the routine always returns the Carry set would need more analysis but it does make the right column in the chess program as it was. AtariOS-800XLXE-Rev03-ULT1M-F1_F4-FP-E.rom Edited April 20, 2020 by Wrathchild double 'the' 3 1 Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted April 20, 2020 Share Posted April 20, 2020 22 minutes ago, Wrathchild said: would need more analysis Due to the way this routine ends, I'm fairly sure (but others can confirm too) that it does return with the carry set due to the CMP #0 (as A will always be >= 0): So that patched OS should be fine. Quote Link to comment Share on other sites More sharing options...
xxl Posted April 20, 2020 Author Share Posted April 20, 2020 or rather checking if we are working on the screen without a text window a few lines below in your example. 1 Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted April 20, 2020 Share Posted April 20, 2020 @xxl Thanks, I should have gone to bed rather than kept going Here's the revised ROM for @Faicuai then, with the highlighted code inserted so that the return state is more like that of the XL/XE O/S. AtariOS-800XLXE-Rev03-ULT1M-F1_F4-FP-E.rom 2 Quote Link to comment Share on other sites More sharing options...
xxl Posted April 20, 2020 Author Share Posted April 20, 2020 On 4/18/2020 at 5:52 PM, a8isa1 said: - a mistake typing is easy to do. it's not too diffiucult to restore a piece to its original position by entering another move but only if the piece is still on the board. please make it possible to restore removed pieces back to the board. an un-do option would be even better. added: Load state, Save state minichess.atr 3 1 Quote Link to comment Share on other sites More sharing options...
xxl Posted April 20, 2020 Author Share Posted April 20, 2020 (edited) DELETE (duplicate) Edited April 20, 2020 by xxl Quote Link to comment Share on other sites More sharing options...
Faicuai Posted April 20, 2020 Share Posted April 20, 2020 (edited) 9 hours ago, Wrathchild said: @xxl Thanks, I should have gone to bed rather than kept going Here's the revised ROM for @Faicuai then, with the highlighted code inserted so that the return state is more like that of the XL/XE O/S. AtariOS-800XLXE-Rev03-ULT1M-F1_F4-FP-E.rom 16 kB · 7 downloads Well, certainly among the finest forensics I have seen in a while, without ever forgetting the rabbits that keep coming out (endlessly) of Phaeron's hat! ? At my current available time (and debugging-know how in Altirra), it could easily take me 24-48 hrs. to nail this down (so KUDOS to you!) There seems to be a redundant / not-needed LDX @ [$CBDF: $A6 $57], as it is immediately replaced by LDX @ [$CBE4: $AE $F0 $02]. Not sure about the following LDA @ $CBE1, assuming that the idea is to also return the expected value on Accum. (?) I have actually evaluated E: performance on all versions, and here are the results (System Information 2.24, DMA=OFF for code-only throughput): 1. Rev03 Modified (missing carry-flag state): 609 2. Rev03 Modified (p1: SEC/RTS pair added): 604 3. Rev03 Modified (p2: LDA, CMP, LDX, LDA): 588 I also ran tests on two patched versions (p1 and p2) and I could not see any differences on the only (other) troubled title I've found so far, which is CopyMate 3.8, except being p1 faster. So I will stay with p1, which seems right on the mark, and also seems to display teeny-weeny-chess correctly (unless another issue comes up somewhere else, but I doubt it). For those testing these OS loads, consider the following OS-resident 1200XL (dormant) code recovered for XL/XE use (had been already included in these OS-loads, before accel-E: corrections): 1. CTRL + {Inverse/Atari} = ANTIC OFF (any other key afterwards turns it back on) 2. SHFT + {Inverse/Atari} = Key audio-feedback ON/OFF 3. CTRL + SHFT+ Caps = International Character Set on/off (you can try it and see what happens with MiniChess board) 4. CTRL + SHFT + Delete = Keyboard input ENABLE/DISABLE 5. CTRL + SHFT + Inverse = HELP key (Incognito ONLY) (EDIT): Here are the builds, for Ultimate and Incognito, per Doc's suggestion (accel-E: change only adds $38 instruction @ CBE7): AtariOS-800XLXE-Rev03-ULT1M-F1_F4-FP-E-p1.rom AtariOS-800XLXE-Rev03-INCOG-F1_F4_H-FP-E-p1.rom Edited April 20, 2020 by Faicuai Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted April 20, 2020 Share Posted April 20, 2020 all the file names are the same with the screen accelerator fixes... can we get them edited with different names... version conflicts abound these days... that and a little note saying what changed and if there was a size change, speed hit/gain as well as ranking. This can become a mess quick or years down the way in the future. As was recently the case in two other projects.... Quote Link to comment Share on other sites More sharing options...
