Sign in to follow this
The Undecided
Sega genesis box protections that accommodate hang tab?
Does anyone know of a box protector that you can use with intact hang tabs? The only ones I’ve seen that work are overly long boxes that you have so much clear unused space or ones that are so tight the hangtab in pushed all the way down.
i was hoping there might be ones with a better idea like maybe a cut out line for the hangtab to stick out of or something else?
Edited by The Undecided
I've not seen anything like that. I push my hangtabs down flat and in some of the newer clamshells, they have designed to hang tabs to click into place when your fold them down like that. If you want them to fit in better fitting boxes with the hang tabs sticking up. The only idea I can advise is to cut those top flaps you use to allow the hang tab to come through?
