acadiel
Unreleased CC-40 BASIC Waftertapes - list
Before the CC-40 and Waftertape drives were cancelled, the Consumer Products division had ready to release many BASIC programs that covered a gamut of Engineering and Mathematics topics.  I hereby present to you this list, which is unreleased, but now known thanks to an interview that Ksarul and I had last night with one of the last TI engineers that used to work in Lubbock on the CC-40 and TI-74 systems.
I am investigating seeing if I can get permission to get these released from TI to the community.
Control Charts
   PCHART
   P OR NP
   RANGE
   STDDV
   UCHART
   U OR C
Dynamics
   CIRCLE
   COLLIDE
   INERTIA
   LINEAR
   PROJ
   ROTATE
   SHM
   VECTOR
Electrical Engineering
   AMP
   BIPOLE
   COIL
   DELTA
   FIELD
   LDFLOW
   POWER
   RADIAL
   VOLT
Extras
   CONVERSN
   KNMATIC1
   KNMATIC2
   ORBIT
Inventory (control and management)
   EOQ
   LATE
   OVHD
   PGMT
   RT
   SUM
   TOTAL
Non Parametric Stat
   CHISQR
   COCHRAN
   FRIEDMAN
   GAUSS
   KRUSWALL
   RANK
   RANKSUB
   RUNS
   RXC
   TAU
   TOLLIM
PDraw (pen plotter drawing)
   CEDIT
   EDIT
   PERTRAN
   PLOTTERS
   TDEE
   TIMED
Photo (darkroom and film exposure/processing)
   BW
   COLOR
   DEPTH
   EXTUBE
   FLASH
   LRATIO
   SLENS
Pipe (Flow, etc)
   DWE
   EPM
   GLPS
   HCM
   HTC
   HTIP
   HWF
   WPD
ProdPlan (production planning)
   BAL
   BREAK
   CAP
   CP
   CV
   RATES
   TIME
   TV
Profit
   ATCF
   IRRA
   IRRB
   MDS
   NPVA
   NPVB
Regression
   ADV
   AUTO
   CHECK
   CORR
   CORR2
   CUBIC
   EXP
   EXP2
   MLT
   MLT2
   NL
   WAFER (utility)
Samples
   AOQL
   CONT
   DES
   SAM
   UNIT
   VARI
Solar
   FCHART
   GAIN
   HEAT
   HEATEXC
   HTC
   SOLECO
   ZENITH
Thermodynamics
   BDPOINT
   FLOW
   HEATCAP
   PENG
   PSY
   REACT
   SRK
   STEAM
WaferTape Utiliities (for building cartridge images, etc mostly ram-loadable asm utilities)
   CARTDIR
   CARTINIT
   CARTLOAD
   CARTSAVE
   CARTSAVX
   DIR
   FILECOPY
   PROG
   SUBPROG
   TAPECOPY
  • Like 6
10 minutes ago, INVISIBLE said:
I'm curious... has anyone ever made a program for the TI-99/4A to run CC40 software or it's. BASIC.
I haven't yet examined a CC-40 program to look at the tokens.  I'm assuming you could convert most of the BASIC programs over.
Actually, IIRC (from something I read in one of the CC40 manuals BITD), the CC40 BASIC is a subset of TI BASIC. I suspect the programs should run without the need for conversion.
CC40 has several functions and commands, some from the broader TI BASIC family, outside of Extended Basic, some CC40 specific.
The question is, does it save programs in the same format? I don't remember if I tried to OLD/SAVE across RS232 even.
If it uses the same token table, there might still be keywords XB would not know. Others like RPT$ are probably just spelled out (wild hunch.)
CC-40 Enhanced BASIC keywords that are not in TI-99/4A BASIC or Extended BASIC
Mathematical Functions
ACS
ASN
DEG
GRAD
INTRND
LN
PI  - XB
RAD
SQR  - Basic and XB
String Functions
KEY$
NUMERIC
RPT$ -  XB
Memory Management
ATTACH
FRE
RELEASE
File I/O
DELETE - Basic and XB
FORMAT
VERIFY
Screen
PAUSE
TAB  - XB
Commands
RENUMBER - same as RESEQUENCE
CALLS
ADDMEM
CLEANUP
DEBUG
EXEC
GETLANG
GETMEM
INDIC
IO
POKE
RELMEM
SETLANG
note: CALL VERSION returns 10
Edited by FarmerPotato
Noted my mistakes where things are in XB
Indeed. However, a few of what you listed are, in fact, in XB: PI, SQR, RPT$, DELETE, TAB.
...lee
...lee
So they are. I got mixed up with the several flavors of Visual Basic in my head. I thought TI had SQRT. I don't recall ever knowing to use TAB!
