dhe
tiimagetool
I've been playing with TI ImageTool - it's a really nice tool, with great documentation.
Last night I wanted to test a disk image for errors/problems/bad things. It has a really nice check disk feature, and even offers to repairs errors that it finds, and gives you the option to save to a log file.
So, when working under linux, I usually start a *.jar file from the command line with: javaws {something}.jar. It would appear Windows 10 doesn't like you to do that, and instead prefers that you just double click on the jar file.
javaws - WILL tell you if your Java is out of date, warn you of your potential demise if you don't update immediately and takes you to the updater.
Dano
In my case (since I am likewise a big fan of TI Image Tool), I launch TI Image Tool on Windows 10 (always without issue) via the following command:
start javaw -jar "C:\TI99\Image Tool\tiimagetool.jar"
Part of the reason for using this command is that I want to be able to associate relevant file types with the application.
To do that I've got a Batch file containing the following:
@echo off
start javaw -jar "C:\TI99\Image Tool\tiimagetool.jar" %1
And that's associated with relevant file types.  So I can just double click, say, a .cf7 file to open it in TI Image Tool.
Thanks pixelpedant, that works like a charm, and I'm a big fan of using batch files.
