ChilePepper
numbers...
here is an example:
You know the tinkernut tutorial, right? That has you making a game in which a squirrel-thing chases a nut thing. to make the squirrel move you would use some lines of code like
if player1y > player01 then player1y = player1y -1
how would I make it so that it would be like "then player1y = player1y - 0.5" aka, slowing down the squirrel. Help is appreciated. Thanks.
Definitely check the link provided as it is a big help. Basically you have to define a special variable, so do something like :
dim squirrelthing_move = a.b
Then you define a and b.
So a=0 and b=5
So you can do this:
if player1y > player01 then player1y = player1y -squirrelthing_move
But if you are really interested in learning, I highly recommend reading the forums and Random Terrain's website. There is a lot of helpful information out there!
uh oh, now its not moving period.
 a = 0
 b = 5
 dim slowspeed = a.b
 if player1y < player0y then player1y = player1y + slowspeed
 if player1y > player0y then player1y = player1y - slowspeed
 if player1x < player0x then player1x = player1x + slowspeed
 if player1x > player0x then player1x = player1x - slowspeed
once again, thanks for the help
Edited by ChilePepper
  dim p1y = player1y.p  ; p is the fractional part
  if player1y > player0y then p1y = p1y - 0.5
Edited by bogax
typo
Okay, so bogax's thing worked, except the speed of the squirrel seemed to change randomly, sometimes going painfully slow, sometimes turbo speed. How would I fix this? thanks for the 4th time.
So a=0 and b=5
So you can do this:
This would not work, it would only add a to player1y, and in this case it's 0 so nothing would happen,
and I don't think 0.5 sets b to five, probaly 128 or something.
Thanks. I knew I should double check! I was feeling brave enough to post something from memory. This reinforces my statement about reading the website!
Using this method you will need to add a statement for when player1 is less then player0, add this aswell
if player1y < player0y then p1y = p1y + 0.5
Im assuming what you're experiencing is when your player is above player1 it goes full speed
As for the speed being too slow - you will need to tweak the value as desired
this is what i got:
 dim p1x = player1x.p
 if player1x < player0x then p1x = p1x + 0.5
 if player1x > player0x then p1x = p1x - 0.5
still moving slow and fast and stufff. Thanks.
You are reusing the same variable. Try something like this instead:
   dim p1x = player1x.o
Here's an example on the bB page:
randomterrain.com/atari-2600-memories-batari-basic-commands.html#fixedpoint_p0_p1
There's also an example program:
randomterrain.com/atari-2600-memories-batari-basic-commands.html#ex_fixed_point_sprite
