Captain Spazer Posted April 26, 2020 Share Posted April 26, 2020 I'm experimenting with a randomly generated horizontal scrolling playfield, trying to make something like the levels in the Game & Watch version of Super Mario Bros, it works but it's way to random, and I was hoping someone had some tips on how to store premade parts of the playfield that could be choosen and placed at random as the level scrolls in. My code so far simply involves turning pfpixels on at points where the ground and blocks should be: a = 0 player0x = 20 : player0y = 72 main COLUBK=$00 COLUPF=$0E COLUP0=$44 scorecolor = $0E player0: %01100110 %00100100 %01011010 %00111100 %00011000 %00011100 %00011000 %00000000 end rem spawns a row at lowest level if a = 0 then pfpixel 31 10 on rem spawns blocks at highest level if a = 1 then pfpixel 31 2 on rem spawns blocks at middle level if a = 2 then pfpixel 31 6 on if a = 3 then pfpixel 31 6 on : pfpixel 31 10 off : pfpixel 31 2 off drawscreen rem scrolls playfield b = b + 1 if b = 1 then pfscroll left if b >= 31 then b = 0 c = c + 1 if c = 60 then a = (rand&3) if c = 61 then c = 0 goto main Quote Link to comment Share on other sites More sharing options...
Captain Spazer Posted April 26, 2020 Author Share Posted April 26, 2020 I kind of figured out a way to do it, making pretty good mario styled platforming sections with good holes and some higher platforms in the sky. With enough pieces a randomly generated mario platformer would be doable: rem Generated 26/04/2020 12:55:57 by Visual bB Version 1.0.0.554 rem ********************************** rem *<filename> * rem *<description> * rem *<author> * rem *<contact info> * rem *<license> * rem ********************************** a = 0 player0x = 20 : player0y = 72 main COLUBK=$00 COLUPF=$0E COLUP0=$44 scorecolor = $0E player0: %01100110 %00100100 %01011010 %00111100 %00011000 %00011100 %00011000 %00000000 end rem starting with full row of blocks on ground if a = 0 then var40=%11111111 : var41=%11111111 : var42=%11111111 : var43=%11111111 : var20=%00000000 : var21=%00000000 : var22=%00000000 : var23=%00000000 : a = 5 rem spawns a row at lowest level if a = 1 then var40=%11111111 : var41=%11111111 : var42=%11111111 : var43=%00000011 : var20=%00000000 : var21=%00000000 : var22=%00000000 : var23=%00000000 : a = 5 rem air platforms if a = 2 then var40=%11111111 : var41=%11111111 : var42=%11111111 : var43=%00001111 : var20=%00000000 : var21=%00000000 : var22=%00000000 : var23=%11000000 : a = 5 if a = 3 then var40=%11111111 : var41=%11111111 : var42=%11111111 : var43=%00001111 : var20=%00000000 : var21=%00000000 : var22=%00000000 : var23=%11110000 : a = 5 drawscreen rem scrolls playfield b = b + 1 if b = 1 then pfscroll left left if b >= 10 then b = 0 c = c + 1 if c = 255 then a = (rand&3) : c = 0 goto main 1 Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted April 26, 2020 Share Posted April 26, 2020 You might want to take a look at how Pitfall did it. @Thomas Jentzsch's disassembly of it can be found at minidig. ; Scene generation: ; The 255 scenes are randomly generated through a "bidirecional" LFSR. This ; means, that the process of generating the next random number is reversible, ; which is necessary to allow traveling though the jungle in both directions. ; The random number defines the scene with the following bits: ; - 0..2: type of object(s) on the ground (logs, fire, cobra, treasure etc.) ; - 3..5: type of scene (holes, pits, crocdiles, treasures etc.) ; - 6..7: type of the tree pattern ; - 7 : position of the wall (left or right) 1 1 Quote Link to comment Share on other sites More sharing options...
KevKelley Posted April 26, 2020 Share Posted April 26, 2020 I feel like the Atari needs some more platformers. Excited to see what you come up with. 1 Quote Link to comment Share on other sites More sharing options...
ChilePepper Posted April 26, 2020 Share Posted April 26, 2020 I'm a huge Nintendo fan, so seeing the Game & Watch version of Super Mario Bros on the Atari would be awsome! Quote Link to comment Share on other sites More sharing options...
Captain Spazer Posted April 26, 2020 Author Share Posted April 26, 2020 Would be neat, yeah. I got a basic engine going: Jump on enemies, breaking blocks, walking, jumping, running and super jumping. I need to figure out how to do better platforming enemies as for now they can't detect walls and that makes things tricky when there are holes in the ground, heh. Quote Link to comment Share on other sites More sharing options...
