Graham Dearsley #1 Posted April 27, 2020 Below I have listed what I think is the fastest possible circle drawing program in Atari BASIC. 10 GRAPHICS 8:COLOR 1 20 R=40:CX=150:CY=100 30 X=0:Y=R:D=5-(4*R):DA=12:DB=20-(8*R) 40 PLOT CX+X,CY+Y:PLOT CX+X,CY-Y:PLOT CX-X,CY+Y:PLOT CX-X,CY-Y 45 PLOT CX+Y,CY+X:PLOT CX+Y,CY-X:PLOT CX-Y,CY+X:PLOT CX-Y,CY-X 50 IF D<0 THEN D=D+DA:DB=DB+8:GOTO 70 60 IF D>0 OR D=0 THEN Y=Y-1:D=D+DB:DB=DB+16 70 X=X+1:DA=DA+8 80 IF X<Y THEN GOTO 40 I adapted this to Atari BASIC from some pseudo code I found online and NO I do not understand the maths . Can anyone do better ? CIRCLE.BAS CIRCLE.TXT 2 Quote Share this post Link to post Share on other sites
thorfdbg #2 Posted April 27, 2020 9 minutes ago, Graham Dearsley said: I adapted this to Atari BASIC from some pseudo code I found online and NO I do not understand the maths . Can anyone do better ? Explaining or implementing? As far as explaining is concerned, this is a Bresenham style circle drawer similar to the Bresenham line drawer that is in the Os. The circle is the zero-set of the function f(x,y) = (x^2 + y^2 -r^2), and what this algorithm does is essentially an edge tracer of this zero-set, updating the function value f as it goes along. As an update to a quadratic function is linear, no multiplication is required. One cannot really draw circles much faster in terms of simplicity, but there are related algorithms (Bresenham-style) to draw conic sections, i.e. circles, ellipses and so on, just with addition, subtraction and shifts. Quote Share this post Link to post Share on other sites
Graham Dearsley #3 Posted April 27, 2020 Yep this is a Bresenham style circle and the pseudo code I found was in a computer science article written by him back in the late 1970's, he also mentions his line drawing algorithm in there 😀 Quote Share this post Link to post Share on other sites
Eyvind Bernhardsen #4 Posted April 27, 2020 You can make it run a tiny bit faster by skipping the tests on line 60: D must be >= 0 because line 50 skips to line 70 if D < 0. Your routine takes 112 jiffies on my emulator, removing the tests takes it down to 110. Quote Share this post Link to post Share on other sites
Graham Dearsley #5 Posted April 27, 2020 Er. If I rem out line 60 then it draws a square 😁 Quote Share this post Link to post Share on other sites
thorfdbg #6 Posted April 27, 2020 8 minutes ago, Graham Dearsley said: Er. If I rem out line 60 then it draws a square 😁 Not remove the line, just the if-condition upfront. Quote Share this post Link to post Share on other sites
Graham Dearsley #7 Posted April 27, 2020 Oh yes, silly me 😆 Is probably now 2 jiffies faster so you did it 😁 Quote Share this post Link to post Share on other sites
StickJock #8 Posted April 27, 2020 (edited) Possibly speed it up a bit by replacing all constant integers in the loop with symbols (0, 1, 8, 16, 40, 70). Also, merge lines 10-30 together so that the goto finds line 40 faster. Likewise, merge lines 40-50 together and merge lines 70-80 together so that you end up with just lines 10, 40, 60, 70. Edited April 27, 2020 by StickJock Quote Share this post Link to post Share on other sites
Graham Dearsley #9 Posted April 27, 2020 There would be a bit of a problem with merging lines 40-50. The reason line 45 exists is because it wouldn't fit on line 40 😁 Quote Share this post Link to post Share on other sites
explorer #10 Posted April 27, 2020 (edited) More speed precalculating operations CXX=CX+X:CYY=CY+Y:CXY=CX+Y:CYX=CY+X:CYI=CY-Y:CYS=CY-X:CXS=CX-X:CXI=CX-Y PLOT CXX,CYY:PLOT CXX,CYI:PLOT CXS,CYY:PLOT CXS,CYI PLOT CXY,CYX:PLOT CXY,CYS:PLOT CXI,CYX:PLOT CXI,CYS Edited April 27, 2020 by explorer 1 Quote Share this post Link to post Share on other sites
ac.tomo #11 Posted April 27, 2020 20 GRAPHICS 8:COLOR 1:DEG 30 FOR I=0 TO 89 40 X=(COS(I)*50)+50 50 Y=(SIN(I)*50)+96 60 PLOT X,Y:PLOT 100-X-,100-Y 70 PLOT 100-X,Y:PLOT X,100-Y 80 NEXT I This method does the circle 4 times faster than normal, there's no reason why you can't put more PLOTs in to make it 8 times faster. And then you could put the co-ordinates into a string or array in order to call up more circles almost immediately. Quote Share this post Link to post Share on other sites
Rybags #12 Posted April 27, 2020 A faster method still can be to keep an array with a SIN table. Sacrifice some precision by increasing the angle steps, and do lines from prev to current rather than individual plots. And you can effectively split the circle into 8 segments of 45 degrees each, and build each one during every loop iteration. Quote Share this post Link to post Share on other sites
Graham Dearsley #13 Posted April 27, 2020 That code doesn't work ac.tomo but if it did I see that it uses the sin and cosin functions and a FOR/NEXT loop, Atari BASIC and the OS math functions are slow at such things. Did you try my routine ? Quote Share this post Link to post Share on other sites
ac.tomo #14 Posted April 27, 2020 16 minutes ago, Graham Dearsley said: That code doesn't work ac.tomo but if it did I see that it uses the sin and cosin functions and a FOR/NEXT loop, Atari BASIC and the OS math functions are slow at such things. Did you try my routine ? I did try your routine, it's very fast, I never really thought it was possible to create a circle without the trig functions such as COS and SIN. Yes, I did try to increase the PLOTs in my routine but I couldn't do it, I remember doing it a long time ago, and being a bit rusty I can't remember how I did it. Quote Share this post Link to post Share on other sites
Graham Dearsley #15 Posted April 27, 2020 I only discovered it could be done last week 😁 Quote Share this post Link to post Share on other sites
Graham Dearsley #16 Posted April 27, 2020 Where would I put the pre calculations Explorer ? As far as I can see they would have to be within the loop, would that really be faster ? Quote Share this post Link to post Share on other sites
Graham Dearsley #17 Posted April 27, 2020 I can't find the original article I based my routine on but below is a similar one for all the mathematicians among you circlealgorithm.pdf Quote Share this post Link to post Share on other sites
StickJock #18 Posted April 27, 2020 5 hours ago, Graham Dearsley said: There would be a bit of a problem with merging lines 40-50. The reason line 45 exists is because it wouldn't fit on line 40 😁 Maybe if you change the symbols to single characters each? Quote Share this post Link to post Share on other sites
Eyvind Bernhardsen #19 Posted April 27, 2020 I made the main loop a for loop: 10 GRAPHICS 8:COLOR 1:R=40:CX=150:CY=100:X=0:Y=R:D=5-(4*R):DA=12:DB=20-(8*R):LIMIT=R*0.707+0.5 20 TI=PEEK(18)*65536+PEEK(19)*256+PEEK(20):FOR X=0 TO LIMIT:PLOT CX+X,CY+Y:PLOT CX+X,CY-Y:PLOT CX-X,CY+Y 30 PLOT CX-X,CY-Y:PLOT CX+Y,CY+X:PLOT CX+Y,CY-X:PLOT CX-Y,CY+X:PLOT CX-Y,CY-X:IF D<0 THEN D=D+DA:DB=DB+8:GOTO 50 40 Y=Y-1:D=D+DB:DB=DB+16 50 DA=DA+8:NEXT X:? PEEK(18)*65536+PEEK(19)*256+PEEK(20)-TI Now it runs in 102 jiffies (Atari BASIC, PAL machine, emulated). I tried precalculation and making variables for the constants, but it didn't make a measurable difference. 1 Quote Share this post Link to post Share on other sites
tebe #20 Posted April 27, 2020 procedure Circle(x0,y0,radius: word); (* @description: Bresenham Circle *) var x,y, dx,dy, txp, typ, txm, tym: word; d: smallint; procedure DrawCircle; begin PutPixel( txp, typ); PutPixel( txp, tym); PutPixel( txm, typ); PutPixel( txm, tym); end; begin x := 0; dx := 0; y := radius; dy := y shl 2; d := 3 - (radius shl 1); // Decision criterion while (x <= y) do begin if d >= 0 then begin d := 4 + d - dy ; dec(dy, 4); dec(y); end; txp := x0+x; typ := y0+y; txm := x0-x; tym := y0-y; DrawCircle; txp := x0+y; typ := y0+x; txm := x0-y; tym := y0-x; DrawCircle; d := 6 + d + dx; inc(dx, 4); inc(x); end; end; Quote Share this post Link to post Share on other sites
danwinslow #21 Posted April 27, 2020 No fair - this is about BASIC Quote Share this post Link to post Share on other sites
tebe #22 Posted April 27, 2020 (edited) it's only algorithm, similar Edited April 27, 2020 by tebe Quote Share this post Link to post Share on other sites
ac.tomo #23 Posted April 27, 2020 6 hours ago, Graham Dearsley said: That code doesn't work ac.tomo but if it did I see that it uses the sin and cosin functions and a FOR/NEXT loop, Atari BASIC and the OS math functions are slow at such things. Did you try my routine ? When you said my code didn't work do you mean not at all? Or do you mean you cannot expand on it with the other PLOTs, the reason I ask is because I'm having fun with my 65xe, it's not working as it should. Quote Share this post Link to post Share on other sites
Graham Dearsley #24 Posted April 27, 2020 As it is it just draws a bit of a line at four corners and then exits with a cursor out range error 3. Quote Share this post Link to post Share on other sites
ac.tomo #25 Posted April 27, 2020 ok, that does actually work on mine, but it won't allow me to put more PLOT's in. I was playing about with a different program and that wasn't doing what it was supposed to be doing, initially I thought it was me but realised afterwards it is in fact my 65XE. I can't press my RESET key too many times either. Anyone know of an Atari for sale (that works!). This is twice this has happened to me, the other time was a 1050 I bought, realising later after I got it; it loads, but you can't save on it. Quote Share this post Link to post Share on other sites
