Gury
Effectus suggestions and bug reports
Posted (edited)
@Gury I already downloaded a new version yesterday, good job!
I'll report any bugs on your GitHub not Mariusz, ok?
Edited by zbyti
Posted (edited)
zp-sieve.eff
On 5/8/2020 at 9:09 PM, Gury said:
Solved by Effectus 0.4.1
But if file name contains '-' then Effectus produce invalid Pascal program name.
Edited by zbyti
It is Pascal syntax convention, which does not allow such characters in variables and similar statements, in this case in program name.
I fixed it, but this will be published with next release.
On 5/8/2020 at 9:21 PM, Gury said:
Solved by Effectus 0.4.1. It is faster than Action! example. I added this example to Effectus examples repository, thanks!
24 Jiffies Action! 3.7.p
13 Jiffies Effectus.
GREAT!
Posted (edited)
Proper count is 1028 http://atarionline.pl/forum/comments.php?DiscussionID=4873&page=4_#Item_37
My tests on screenshot (early Mad Pascal 1.6.4). I don't remember if I synchronized with the frame in those tests.
Action! and Effectus do not use SETBLOCK. Mad Pascal, CC65 and others use fill-like procedures.
I'll do a test for Action! and the Effectus with SETBLOCK and ZERO Page (Mad Pascal Opt).
RESIEVE with ZERO PAGE:
Mad Pascal 1.6.4 (last master) - 38 frames
Effectus 0.4.1 - 39 frames
Action! 3.7P - 48 frames
Edited by zbyti
Posted (edited)
Action! 3.7P not always count to 1028, sometimes count to 1027... Interesting indeed :)
I'll check my algorithm implementation.
EDIT:
It was my fault, false alarm.
Edited by zbyti
false alarm
Posted (edited)
[BUG REPORT]
//Action!, Effectus
BYTE ARRAY FLAGS(8192)
SETBLOCK(FLAGS,8192,'T)
//translated
FLAGS : array[0..8192] of byte;
FillChar(FLAGS, 8192, 84);
//Mad Pascal
flags: array [0..8191]
fillchar(flags, sizeof(flags), true);
@Gury in translation you reserve too much for ARRAY.
Edited by zbyti
Posted (edited)
I will fix that!
Hmm, I re-checked the problem and I think it can be an issue. If you declare a variable in Action! like this:
BYTE ARRAY flags(8192)
and then use a FOR loop:
FOR i = 0 to 8192
In this phase Effectus does not recalculate the value in FOR statement, it read it as it is (it will not be 8191).
I will check FillChar issue.
Edited by Gury
Re-check
Posted (edited)
Hi good afternoon.
something for effectus 0.4.1
Interrupt !!!
MODULE; VBI DEMO FOR ANTICDEFINE RTI="$40",       PHA="$48",       PLA="$68",       TXA="$8A",       TAX="$AA",       TYA="$98",       TAY="$A8",       JMP="$4C",       XITVBV="$E462",SAVETEMPS="[$A2 $07 $B5 $C0 $48 $B5    $A8 $48 $B5 $A0 $48 $B5 $80 $48      $CA $10 $F1 $A5 $D3 $48]",    ; diese SAVETEMPS Routine ist aus der Action! Fehlerkorrekturliste. Sie ist umfangreicher als das originale Beispiel aus dem Magazin    ; und funktioniert sicher. Das Original sichert nur die Variablen für Addition/SubtraktionGETTEMPS="[$68 $85 $D3 $A2 $00 $68    $95 $80 $68 $95 $A0 $68 $95 $A8    $68 $95 $C0 $E8 $E0 $08 $D0 $EF]"    ; das gleiche wie oben gilt auch für die GETTEMPS RoutineCARD SDLST=560,VDSLST=512,               VVBLKD=$224BYTE NMIEN=$D40E,COLBK=$D01A,     WSYNC=$D40A,COUNT=[0]BYTE ARRAY DLISTBYTE ARRAY CLRS(0)=[64 66 68 70 72 74     72 70 68 66  64  66  68  70  72     74  72  70  68  66  64  66  68     70 72 74 76 ]PROC DLINT(); a DLI written in ACTION!    BYTE DUM    [PHA TXA PHA TYA PHA]    IF COUNT=26 THEN DUM=0    ELSE DUM=CLRS(COUNT) FI    WSYNC=1    COLBK=DUM    COUNT=COUNT+1    IF COUNT=27    THEN COUNT=0    FI    [PLA TAY PLA TAX PLA RTI]PROC INIT7()    GRAPHICS(7)    SETCOLOR(0,2,10)    SETCOLOR(1,5,12)    SETCOLOR(2,0,0)RETURNPROC DLSETUP(); custom Display List    BYTE I    INIT7()    NMIEN=$40    DLIST=SDLST      VDSLST=DLINT    FOR I=30 TO 40    DO DLIST(I)=141 OD    FOR I=42 TO 54 STEP 2    DO DLIST(I)=141 OD    FOR I=57 TO 72 STEP 3    DO DLIST(I)=141 OD    FOR I=76 TO 84 STEP 4    DO DLIST(I)=141 OD    NMIEN=$C0RETURNPROC ROTATE(); the VBI routine    BYTE HOLD,CTR,CNTR    SAVETEMPS; save the temp registers    HOLD=CLRS(26); save the last element    FOR CTR=0 TO 25; the loop    DO CNTR=25-CTR; to count backwards, Action! has no STEP-1 statement    CLRS(CNTR+1)=CLRS(CNTR) OD; rotate    CLRS(0)=HOLD; put the last element into the first    GETTEMPS; get the temp registers    [JMP XITVBV]; exit the VBIPROC VBINST(); install the VBI    NMIEN=0; turn off the interrupts    VVBLKD=ROTATE; vector to PROC ROTATE    NMIEN=$40; turn the interrupts back onRETURNPROC DJD(); the driver routine, named for a famous computer genius    BYTE CRSINH=752    VBINST(); install the VBI    DLSETUP(); set up the Display List    CRSINH=1    PRINTE()    PRINTE("Áîôéã Interrupts in ACTION!")    PRINT("           by DAVID PLOTKIN")    DO OD; an endless loop...RETURN
DEFINE RTI="$40",
       PHA="$48",
       PLA="$68",
       TXA="$8A",
       TAX="$AA",
       TYA="$98",
       TAY="$A8",
       JMP="$4C",
       XITVBV="$E462",
               VVBLKD=$224
BYTE ARRAY DLIST
     70 72 74 76 ]
    BYTE DUM
    WSYNC=1
    COLBK=DUM
    COUNT=COUNT+1
    IF COUNT=27
    THEN COUNT=0
    FI
PROC INIT7()
    GRAPHICS(7)
    SETCOLOR(0,2,10)
    SETCOLOR(1,5,12)
    SETCOLOR(2,0,0)
RETURN
    BYTE I
    INIT7()
    NMIEN=$40
    DLIST=SDLST
    VDSLST=DLINT
    FOR I=30 TO 40
    DO DLIST(I)=141 OD
    DO DLIST(I)=141 OD
    DO DLIST(I)=141 OD
    DO DLIST(I)=141 OD
    NMIEN=$C0
RETURN
    BYTE HOLD,CTR,CNTR
RETURN
    BYTE CRSINH=752
    CRSINH=1
    PRINTE()
RETURN
Edited by funkheld
Posted (edited)
@funkheld and the point is? DLI works fine, VBI works too :] In code like yours current parser go crazy! :]
SET $E=$2000
SET $491=$2000
BYTE ARRAY DL=[$70$70$70$42$00$40$2$2$2$2$F0$2$2$2$2$2$70$70$70$41$00$20]
BYTE ARRAY DLI=[$48$A9$DE$8D$0A$D4$8D$18$D0$68$40]
; 48        PHA
; A9 DE     LDA #$DE
; 8D 0A D4  STA $D40A   ;WSYNC
; 8D 18 D0  STA $D018   ;COLPF2
; 68        PLA
; 40        RTI
BYTE
  CH=$2FC,
  NMIEN=$D40E
CARD
  VDSLST=$200,
  SDLSTL=$230
PROC MAIN()
  SDLSTL=DL
  VDSLST=DLI
  NMIEN=$C0
  WHILE CH=$FF DO OD
  GRAPHICS(0)
RETURN
Edited by zbyti
DLI code
Posted (edited)
[BUG ERROR]
SET $E=$2000
SET $491=$2000
BYTE
  RTCLOCK=$14,
  COLOR2=$2C6,
  CH=$2FC,
CARD
  VVBLKD=$224,
  OLDVEC
PROC SETVBLK=$E45C(BYTE WHICH,MSB,LSB)
PROC VBLANKD()
  COLOR2=RTCLOCK
[$6C OLDVEC]
PROC MAIN()
  PRINTE("Setting up Vblank")
  OLDVEC = VVBLKD
  SETVBLK(7,(VBLANKD RSH 8),VBLANKD)
  WHILE CH=$FF DO OD
  SETVBLK(7,(OLDVEC RSH 8),OLDVEC)
RETURN
1. CH=$2FC, ; translator don't catch comma as error
2. [$6C OLDVEC] OLDVEC ; missing reference
3. PROC SETVBLK=$E45C(BYTE WHICH,MSB,LSB) ; not possible
Edited by zbyti
17 hours ago, zbyti said:
[BUG ERROR]
Hi,
error catching is planned for some other version. I will resolve some bugs and add some new features before that.
OLDVEC issue is also on the list for fixing. Currently, variables cannot be assigned inside machine language [] block.
No worries, I noticed that also. The problem is a way Effectus assigns a pointer in this particular example. I already have solution for this, it will be fixed in next release. The good starting point is the same example in Tebe's GitHub Mad Pascal repository.
Action! language is very unique in a way it uses arrays and pointers, so I need to examine all possible cases to adapt Effectus to translate correctly to Mad Pascal.
Posted (edited)
In Action:
ARRAY BYTE
  TEXT(30),
  SCREEN=$8000
TEXT indicates on first byte of array, index will be BYTE in loops. TEXT(0)=10 produces only LDA / STA.
SCREEN is a POINTER to $8000 and array index will be always CARD type in loops.
Above goes from my knowledge ;)
Edited by zbyti
[BUG ERROR FOR 0.4.3]
// .eff
CLOCK=RTCLOK WHILE RTCLOK=CLOCK DO OD
// goes to .pas
CLOCK := RTCLOK;
RTCLOK := CLOCK;
WHILE RTCLOK=CLOCK do begin
end;  // while
main.eff
Good find!
I also spoted this problem in some previous release, all comparisons generated assignments with the same name before branch (IF, FOR, WHILE, UNTIL). I already fixed this problem for FOR and UNTIL branches for most cases in current releases. I will dig into remaining problems for this issue before releasing new version.
@Gury
if You create some simple issue on github I try to fix them and step by step I involve myself into development. What do you think?
I know Action! pretty well but without runtime library and I have basic knowledge about Mad Pascal and Free Pascal.
That's great to hear. Currently my goal is to follow my plan to resolve known issues. You can help, but it's better to wait till next release so we don't collide with different fixes.
When we do this it will be must to run a test suit to check all works ok.
You can already involve in doing this, but use different branch.
// .eff
// goes to .pas
CLOCK := RTCLOK;
RTCLOK := CLOCK;
end;  // while
Fixed in version 0.5.
end;
WHILE RTCLOK=CLOCK do;
