catmando #26 Posted December 17, 2020 18 hours ago, Fred Olivas said: Any approximation when a new alphabetised menu will be released? I like the convenience of just having one cart to carry around. No need, just use this program to copy your roms to the card Quote Share this post Link to post Share on other sites
gilsaluki #27 Posted December 17, 2020 On 10/7/2020 at 3:44 AM, turbo graphics 220 said: The case looks really cool, too bad I can't play it as my Lynx stopped working not that long ago, the wire trick doesn't even anymore work so I have to wait for some parts. my BennVenn works great. Get another Lynx. B&C can be relied upon. Quote Share this post Link to post Share on other sites
Igor #28 Posted December 20, 2020 It's close to being done, or was...then we had our baby boy so he's keeping me from spending too much time on this. I'll have to invoke the CDPR phrase of "when it's ready" in this case... it is on my list of things to do, after I finishing writing up details of the game jam I've just finished running - https://itch.io/jam/lynxmas2020 (it's taken me about a week to find the time to do that though!) Quote Share this post Link to post Share on other sites
UHATEIT #29 Posted December 30, 2020 I got my elcheapo in the mail this week along with the LCD screen. I was talked to the seller and they did mention that only .lnx format works on the el cheapo. Does anyone have an easy drop and convert program or link to where I can convert .lyx and .o formats to .lnx? Quote Share this post Link to post Share on other sites
Igor #30 Posted January 11 On 12/31/2020 at 12:22 AM, UHATEIT said: I got my elcheapo in the mail this week along with the LCD screen. I was talked to the seller and they did mention that only .lnx format works on the el cheapo. Does anyone have an easy drop and convert program or link to where I can convert .lyx and .o formats to .lnx? I've updated the Atari Gamer website to add some basic functionality for this. The following tools can be used: LNX to LYX ROM Converter LYX ROM Converter The LNX2LYX tool can convert .o files to LNX, this is essentially the same code as on the Lynx SD. LYXCONV tool can be used to convert a LYX file to a 512KiB LNX ROM with a default header. Hope this helps! I plan to expand on these tools later when I have more time 🙂 Quote me here and report any issues if you encounter any, but DM you me the ROM you're having issues with so I can test it out myself. Quote Share this post Link to post Share on other sites
UHATEIT #31 Posted January 11 10 hours ago, Igor said: I've updated the Atari Gamer website to add some basic functionality for this. The following tools can be used: LNX to LYX ROM Converter LYX ROM Converter The LNX2LYX tool can convert .o files to LNX, this is essentially the same code as on the Lynx SD. LYXCONV tool can be used to convert a LYX file to a 512KiB LNX ROM with a default header. Hope this helps! I plan to expand on these tools later when I have more time 🙂 Quote me here and report any issues if you encounter any, but DM you me the ROM you're having issues with so I can test it out myself. Thank you so much for doing this! I ended up converting all the .o to .lyx which the first converter did and then converted the .lyx to .lnx and they came at the 512kb format with a header so the size ends up as 513kb. All seem to work well! I even went into some of the other ones that were small, like random .lnx files that were 11kb, 43kb, 15kb and such, and did the .lnx to .lyx, and then converted them back to .lnx in the higher size. not sure what that does exactly as far as whether something is 256kb or 512kb, but that seems to have fixed the really small size .lnx files I had Not on your end, tho on the Bennvenn Elcheapo end, what was weird is things were all disorganized alphabetically when Sd card boots udespite having everything in the folder sorted in alphabetical order. So what I did was pulled ALL the files from the SD card to a folder on my computer, and then erased the SD card and reformatted it again and then pulled everything from the folder back to the SD card again. Now it's alphabetized and organized ***The weird thing tho is that is is making the letter "E" as the first letter of the alphabet so file #1 is actually Eggsavier instead of 8bit Goblin. If Bennvenn sees this post do you know it would do that exactly? I could probably take everything off and then reformat again but not sur why it starts the alphabet with the letter "E" Quote Share this post Link to post Share on other sites
Igor #32 Posted January 11 Awesome! Glad it all worked, sorry it took me so long to get around to this, I saw this post a while back but was busy with our newborn to do any coding. With regard to the disorganised ROM listing, this is expected because the default menu displays ROMs in file-system-order, which means the order they were copied to the SD card. I'm working on a new menu system to replace the default one and that will sort ROMs into their correct spots. Again, I've not had too much time to get to this because of the baby, but I do plan to release it some time soon. Quote Share this post Link to post Share on other sites
UHATEIT #33 Posted January 11 (edited) 1 hour ago, Igor said: Awesome! Glad it all worked, sorry it took me so long to get around to this, I saw this post a while back but was busy with our newborn to do any coding. With regard to the disorganised ROM listing, this is expected because the default menu displays ROMs in file-system-order, which means the order they were copied to the SD card. I'm working on a new menu system to replace the default one and that will sort ROMs into their correct spots. Again, I've not had too much time to get to this because of the baby, but I do plan to release it some time soon. hey you rock! Yeah it's odd because I took ALL of the roms off the SD card and reformatted it and then dragged the Boot.bin and all 200+ roms onto the fresh SD card and for some reason it decided to make "E" at rom #1 and alphabetically from there, even tho I had them alphabetized before dragging them back onto the card and put them all back on at the same time, so I'd have imagined it would have loaded them alphabetically that way. it's not a big issue, but if there is ever an update to the Boot.bin for the ElCheapo that will probably fix those issues! Edited January 11 by UHATEIT 1 Quote Share this post Link to post Share on other sites
BennVenn #34 Posted February 5 On 1/12/2021 at 9:36 AM, UHATEIT said: hey you rock! Yeah it's odd because I took ALL of the roms off the SD card and reformatted it and then dragged the Boot.bin and all 200+ roms onto the fresh SD card and for some reason it decided to make "E" at rom #1 and alphabetically from there, even tho I had them alphabetized before dragging them back onto the card and put them all back on at the same time, so I'd have imagined it would have loaded them alphabetically that way. it's not a big issue, but if there is ever an update to the Boot.bin for the ElCheapo that will probably fix those issues! If you select all, and drag them over to the SD, the file you select to drag will be the first file that is copied, then the rest below it, then looping back around from the start until that file.. if that makes sense? Quote Share this post Link to post Share on other sites
42bs #35 Posted February 5 Maybe CMD.exe would help: FOR %I IN (*.LNX) do copy %i <SD> Quote Share this post Link to post Share on other sites
Igor #36 Posted February 8 My version of the menu will address this Quote Share this post Link to post Share on other sites
KevinMos3 #37 Posted February 22 On 2/7/2021 at 11:41 PM, Igor said: My version of the menu will address this When do you expect to release it? Quote Share this post Link to post Share on other sites
Igor #38 Posted February 22 Plan was to have something last week, but with a newborn baby it's a little difficult to predict when I will have time to work on it...just keep an eye out for my updates on Atari Gamer 1 Quote Share this post Link to post Share on other sites
UHATEIT #39 Posted February 23 When you do the update for I drag everything off the card and reformat it blank then af the new bootemu and drag the games back? Asking so I do it right when the time comes. I'll also make sure to drag starting from the first game in the folder so it stays alphabetical. Quote Share this post Link to post Share on other sites
Igor #40 Posted February 24 All you'd need to do is copy the new BOOT.bin and it should be good to go 😎 Quote Share this post Link to post Share on other sites
KevinMos3 #41 Posted February 26 I've been itching to do a label for the BennVenn cart, and finally got around to throwing together a quickie. The idea was to use the tie-dye pattern at the top so it matches the rest of the shell, and put something Lynx-like where a label normally goes. I didn't plan on using the circuitboard on the label, but once I scanned it in for sizing, I liked it better than the plain orange or purple. Here's what it looks like applied to my BennVenn cart: There's approximately a millimeter or so of excess on the sides to give room for trimming. I actually applied this label to the cart before trimming off the edges, letting the hobby knife ride in the groove between the PCB and shell. It gave a nice fit. All images uploaded in 600dpi. If forum software resizes them, I'll zip them up or something. Quote Share this post Link to post Share on other sites
KevinMos3 #42 Posted February 26 (edited) Bah... After I print, apply, and upload images, I realize some mistakes. - I should have used the microSD logo instead of the SDHC logo. - I should have added BENNVENN.COM I did say it was a quickie. That's what happens I suppose. Here are those couple of corrections. I'm sure there are a multitude of improvements that could be made, but I'll call it done. Edited February 27 by KevinMos3 Quote Share this post Link to post Share on other sites
UHATEIT #43 Posted February 27 Those look sweet! I do not have a sticker printer tho Quote Share this post Link to post Share on other sites
42bs #44 Posted February 27 16 minutes ago, UHATEIT said: Those look sweet! I do not have a sticker printer tho Most copyshops should have such. Quote Share this post Link to post Share on other sites
+karri #45 Posted March 2 On 2/27/2021 at 11:04 PM, UHATEIT said: Those look sweet! I do not have a sticker printer tho I invested in a Canon Selphy photo printer that does 148mm by 100mm prints. It is a sublimate printer so the colour is on plastic sheets and is transferred by heat to the glossy paper. You can fit 4 labels on one sheet. With a little glue and scissors the result is awesome! 108 sheets with the inks cost 46 € here in Finland. So a single label would be just 0.11 €. Not bad. 1 Quote Share this post Link to post Share on other sites
Igor #46 Posted 38 minutes ago Shared on AG - https://atarigamer.com/news/1k9c615w2yo Also 600DPI versions are available on Thingiverse, thanks @KevinMos3 - https://www.thingiverse.com/thing:4787685 Quote Share this post Link to post Share on other sites
