Sign in to follow this
Lillapojkenpåön
temp7's purpose?
What is temp7's purpose when bankswitching?
.L08 ;  goto _bank2 bank2
 sta temp7
 lda #>(._bank2-1)
 pha
 lda #<(._bank2-1)
 pha
 lda temp7
 pha
 txa
 pha
 ldx #2
 jmp BS_jsr
BS_jsr
 lda bankswitch_hotspot-1,x
 pla
 tax
 pla
 rts
It looks to me like it's just used to push what's currently in the accumulator to the stack, and that you also push x to the stack, is that just so you can continue your code in another bank?
There's no way to ldx or lda (without also assigning it to a variable) in bB, and even if there where, wouldn't it be faster to just
sta temp1
stx temp2
and load them after the bankswitching
lda temp1
ldx temp2
If I don't need to keep what's in a and x would this work
 lda #>(._bank2-1)
 pha
 lda #<(._bank2-1)
 pha
 ldx #2
 rts
Just tried it and I got error: Unknown Mnemonic 'bankswitch_hotspot-1,x'.
Is bankswitch_hotspot a table? I can't find it anywhere.
Edited by Lillapojkenpåön
Woops answered here
But I still need to know how to put the hotspots in a table or something?
hotspots
  $FFF6
  $FFF7
  $FFF8
  $FFF9
  $FFFA
  $FFFB
I tried this
lda $fff6,x
and -1 to but didn't work
The specific hotspot for bankswitching depends on the size of your project, so using the bankswitch_hotspot constant instead of a hardcoded value is a good idea. I don't know why the stack is used to preserve register values instead of temp variables; maybe @RevEng can answer that part.
Hotspots are not in a table. They are addresses that trigger a bankswitch in the hardware if they are accessed (read from or written to). If you just do a "lda bankswitch_hotspot" the code would switch to the first bank. Each address following bankswitch_hotspot would switch to the following bank.  The X register contains the bank you are switching to.
bB starts counting banks at 1 instead of 0, so that's why it uses "lda bankswitch_hotspot-1,x".
it appears to work with just a little trickery
   set romsize 16k
   set optimization inlinerand
   const targetlo = <(.dloop-1)
   const targethi = >(.dloop-1)
   def gt_bank = callmacro bsm
  macro bsm
  asm
  lda #{2}
  pha
  lda #{1}
  pha
  ldx {3}
  jmp BS_jsr+6
end
end
  q = $55
  gt_bank targetlo targethi 2
 bank 2
 a = a
dloop
  c = c + 1
  if !c & $7F then q = q ^ $FF : COLUBK = q
  if e && joy0fire then q = q + 4 : COLUBK = q
  if joy0fire then e = 0 else e = 1
  drawscreen
  goto dloop
 bank 3
 bank 4
The intent of temp7 is indeed to save save A. As to the question of why other temp variables weren't used, I believe the intent was to eventually bankswitch-enable certain bB functions that are already using the temps. e.g. the div_mul libraries.
if I do this
  macro bsm
  asm
  lda #>(.{1}-1)
  pha
  lda #<(.{1}-1)
  pha
  ldx {2}
  jmp BS_jsr+6
end
end
  gt_bank dloop 2
it complains about uresolved symbol
1.dloop
I don't know where that comes from
it seems to produce correct code but won't assemble
     90  1004                   .L08         ;  gt_bank dloop 2
     91  1004
      0  1004                          bsm    dloop, #2,
      1  1004
      2  1004                   .L06
      3  1004
      4  1004               a9 ff              lda    #>(.dloop-1)
      5  1006
      6  1006               48              pha
      7  1007
      8  1007               a9 ff              lda    #<(.dloop-1)
      9  1009
     10  1009               48              pha
     11  100a
     12  100a               a2 02              ldx    #2
     13  100c
     14  100c               bd f5 1f           lda    bankswitch_hotspot-1,x
     15  100f
     16  100f               4c f1 ff           jmp    BS_jsr+6
copy and paste errror in the previous code (although it seems to work)
should have been
  macro bsm
  asm
  lda {2}
  pha
  lda {1}
  pha
  ldx {3}
  jmp BS_jsr+6
end
end
17 minutes ago, bogax said:
It complains about uresolved symbol
1.dloop
Dasm considers dot symbols to be limited in scope. I'm pretty sure that limits the dasm in-macro access to bB labels.
well in that case
   set romsize 16k
   set optimization noinlinedata
  macro bsm
  asm
  lda #>({1}-1)
  pha
  lda #<({1}-1)
  pha
  ldx {2}
  jmp BS_jsr+6
end
end
  q = $55
  gt_bank dloop 2
 bank 2
 a = a
  data dloop
end
dloop
  c = c + 1
  drawscreen
  goto dloop
 bank 3
 bank 4
(yes , it works)
  • Haha 1
IObBCC..
I've read several times that macros are slow, so I guess when using it you don't input a copy of that code with the parameters you give?
Or if you do does that happen when it turns into machine language?
I couldn't use the bankswitch_hotspot constant before without getting an error, now I can for some reason.
maybe the problem is that I'm trying to jump to another bank and return to the old bank again, on gosub with bankswitch, which bB doesn't support, this is the first part
 asm
   lda #>(._ongosub_return_-1)
   PHA
   lda #<(._ongosub_return_-1)
   PHA
   LDX bankNumber   ; 4 in this case
   LDA _jumptablehi_,x
   PHA
   LDA _jumptablelo_,x
   PHA
   rts
_jumptablehi_
   .byte #0
   .byte #0
   .byte #0
   .byte >(._bank3data-1)
   .byte >(._bank4data-1)
   .byte >(._bank5data-1)
   .byte >(._bank6data-1)
_jumptablelo_
   .byte #0
   .byte #0
   .byte #0
   .byte <(._bank3data-1)
   .byte <(._bank4data-1)
   .byte <(._bank5data-1)
   .byte <(._bank6data-1)
end
_ongosub_return_
I probably need to make a custom return otherbank code also,
what do I change? getting rid of the a and x stuff didn't work
 asm
 pha ;push a to stack
 txa
 pha ; push x to stack
 tsx ; Transfer Stack ptr to X
 if bankswitch != 64
   lda 4,x ; get high byte of return address
   rol
   rol
   rol
   rol
   and #bs_mask ;1 3 or 7 for F8/F6/F4
   tax
   inx
 else
   tay
   ora #$10 ; change our bank nibble into a valid rom mirror
   sta 4,x
   tya
   lsr
   lsr
   lsr
   lsr
   tax
   inx
 endif
 pla
 tax ; *** restore X
 pla ; *** restore A
 rts ; *** RTS will "return" to the address we pushed onto the stack earlier
end
If someone can get this to work, I would be happy
you gosub to bank 4 by pressing joy0fire,
it should change bgcolor to blue
bankswitch2.bas
and is the  jmp BS_jsr+6 in bogax code because you have to do the rts at that address?
it doesn't work as advertised
the BS_jsr+6 comes after the bank switch and so never executes
it just so happens that the bank switch ends up in the dloop
I haven't figured out how to fix it
if you're just trying to compute your target you can set something up with on gosub and on goto
put gotos for each bank (or each possible target bank) in each bank tha you might be coming from
and a dispatch on goto for each possible target in the bank
in other words on gosub to a goto bank (in the current bank) that goes to an on goto in the target bank that selects the routine you want in that bank
I did that, but think I did on gosub to gosub to another bank, so I could return, then I just merged the codes in assembly
 sta temp7
   PHA
   PHA
   LDX bankNumber
   LDA _jumptablehi_,x
   PHA
   LDA _jumptablelo_,x
   PHA
 lda temp7
 pha
 txa
 pha
 ldx bankNumber
 jmp BS_jsr
this works perfectly with a regular return otherbank
So I'm not trying to get it to work, I'm trying to optimize it by removing as much excess as possible and hopefully get a little bit closer to understanding bankswitching in the process.
I don't need to save a and x, but BS_jsr and BS_return (that falls into BS_JSR) tries to pull them from the stack, I think that's what the problem is.
this works, but it's getting messy
the to_bank macro just loads the target address to the stack
you then have to goto the bank switch code at the beginning of the bank
the location of the bank switch code has to be the same in all banks
and the beginning of the bank seemed simplest
since you have to jump around it in the first bank there's padding in the rest
(in place of the jump/goto)
   set romsize 16k
   def to_bank = callmacro bsm
   def go_to = callmacro gtom
  macro bsm
  asm
  lda #>({2}-1)
  pha
  lda #<({2}-1)
  pha
  ldx {1}
end
end
  macro gtom
  asm
  jmp {1}
end
end
  def bswitch = callmacro bswm
  macro bswm
  asm
  nop
  nop
  nop
  rts
end
end
  goto skip_BS_code
bs1
  asm
  rts
end
skip_BS_code
  gosub init
  to_bank 2 dloop
  goto bs1
init
  q = $55
  COLUBK = q
  COLUPF = $33
  return thisbank
 bank 2
bs2
  bswitch
  data dloop
end
  c = c + 1
  drawscreen
  go_to dloop
 bank 3
 bank 4
Aah, now I get it, ofcourse that code has to be in the same place in all banks 💡
Thanks, it doesn't support returning but I can add that.
I'm also trying to save space and I got my previous code down to this
   lda #>(._ongosub_return2_-1)
   PHA
   lda #<(._ongosub_return2_-1)
   PHA
   LDX bankNumber
   LDA _jumptablehi_,x
   PHA
   LDA _jumptablelo_,x
   PHA
 pha
 pha
 jmp BS_jsr
just two extra pushes to get the existing bs code to work and return, not shure it would be worth adding another slightly modified version to every bank just to get rid of the extra pushing and pulling, but I sure will try it.
What the hell is a macro anyway?
you're indexing your table with the bank number(?)
in this case a macro is sort of like an inlined function
