freshbrood
Using 2 or more if statements in the same line.
Example:
  if player1y<76 then e=14 : if f{1} then e=13
vs
  if player1y<76 && f{1} then e=13
Both of these examples seem to work perfectly fine in my code. The top example uses less memory.
But I have been advised to never use 2 or more if statements on the same line.
Why?
Is it because it's generally bad practice and can lead to confusing code?
Or does it actually cause a glitch and make the game crash upon reading? Because in terms of memory usage, if the top line reads correctly every time, obviously it would be preferable.
Edited by freshbrood
I actually didn't know you could do that, but the first example would be split up on several lines like this
 if player1y>=76 then skip
 e=14
 if f{1} then e=13
skip
It's easier to read, especially if you add more stuff or if statements down the line.
You might want to try this instead btw
if f{1} then e=13 else e=14
Another good thing is that it's more similar to the assembly it turns into, if you do this..
 if !f{1} then a
 e=13
 goto skip
a
 e=14
skip
you're pretty much writing assembly
Edited by Lillapojkenpåön
The bB page says these things:
"Using multiple if…thens in a single line might not work correctly if you are using boolean operators."
"If you use || in an if…then statement, the statement must be located at the beginning of a line. At this time, compilation will succeed but your program will probably not work correctly. This issue will probably be fixed in a later version."
"The else keyword might not work correctly in a statement containing &&. The else keyword may also not work as expected when there is more than one if…then on a single line."
