Faicuai
800/Incognito PBI-extender and... weird shields...
Well, been working lately on exploring Incognito's PBI via its 50-pin IDC connector. Only PBI (and VERY nice) device available is my SysCheck-II copy, but it connects with 50-pin CardEdge connector, to XL PBI bus.
So eventually built an adapter, that looks like this (for universal operation in 800XL and 800/Incognito):
But, MOST IMPORTANTLY, also fine-tuned a machine-cut adaptation to the top-cover's under-shield panel (which is fully modular and detachable). Now we can comfortably extract the ribbon (and even Bit3's video out) through the 800's back with ZERO modifications to top-cover's plastic case itself, and minimal or negligible structural stress (there are four plastic-posts where the top-shield cover attaches to the plastic-cover, and could fracture if over-stressed due to misalignment between shield-cover and shield-frame):
A testament to the 800's tolerant and flexible design.
But what REALLY caught my attention during machining (precise-cutting) my "trainer" cover's top shield (from an older 800) was what I found:
LEFT is my 800's (USA-made) '83 cover and the right is what came off during machine-cutting my '80-'81 trainer: a DOUBLE-LAMINATE (compound) top-shield (!!!) What's is left attached is the cleaned, primary layer, and what's detached was the crap that came-off after precise-cutting...
Holy-crap... that's shielding taken way too far, I guess...
BTW: to effectively clean all GUNK residue (even from the front-side shield plate), all you need is GOO-GONE and a couple of wooden tooth-picks.. Just plenty of goo-gone and a bit of patience, and you will end up with spot-less plastics, with zero damage to factory finish.
Edited by Faicuai
  • Like 6
Not to derail your thread, but where did you get the parts to build that cable?  Did you scavenge them or order them from somewhere?
I swear they built that machine to withstand a nuclear EMP and still keep working.
They built it to withstand the FCC.
  • Haha 2
All made from scratch, and on-line parts.
The hardest part is the male (50-pin) card-edge, solder-through, breakout terminal. That I had to machine-cut from a larger board that I finally found on-line as well, after looking for SoOoOo long...
It is now possible to connect legacy PBI HW directly to the 800/Incognito with this extender (and keep the top-cover safe-and-sound). Even the 1090 Frankenstein-box should be no problem, assuming no PBI issues on Incognito...
Edited by Faicuai
  • Like 4
Me thinks perhaps you should whip up a small batch for sale.
  • Like 4
Though about it, already, as it is kind of hard to make these.
Vendor ran out of 50-pin EDGE break-out boards, but a new lot has been ordered (it will take a while due to corona-crap, unfortunately). Will pay close attention to costs, as I have to sacrifice a slightly larger board, for each adapter made.
Meanwhile, I will try to come up with final / optimal length (and testing for integrity / reliability) and see if we can make a limited prod. run, for those users that have 800 / Incognito, and would like to lock-and-load their on-board PBI facilities... ;-)
Cool, I'd be interested in one.  At least it'll be an easy install, where you just lift the lid, plug it in and put the lid back down.  As for that, now I have the SCCC to put in...
