KevKelley #1 Posted May 18, 2020 I was using pfcolors and pfheights playfield options with the standard kernel. I understand you can only set the playfield colors once, unless you use this modification. While I was messing around with code with the statusbarcolor, where I was trying to set the statusbarcolor to a variable, I had noticed it changed the color of the top row of the playfield to be the same as the status bar. I was curious as to why this occurred. Quote Share this post Link to post Share on other sites
+Random Terrain #2 Posted May 18, 2020 Don't know why, but the fix for it here is probably the same: https://www.randomterrain.com/atari-2600-memories-batari-basic-commands.html#kernop_pfcolors Quote Share this post Link to post Share on other sites
KevKelley #3 Posted May 19, 2020 Ah. I was planning on playing around with it to see if I could get some effects out of it. Thought it was neat. Quote Share this post Link to post Share on other sites
