Logical Line Character limit broken....but how?
The attached program has several lines that break the logical line character limit, and seem to have no way of being shortened. Like this one for example:
80 S2=PEEK(T3+T):N2=(O2+P2=Q2)+(O2+R2=Q2
)+(O2+S2=Q2)+(P2+R2=Q2)+(P2+S2=Q2)+(R2+S
2=Q2)+(O2+P2+R2=Q2)+(O2+P2+S2=Q2)+(O2+R2
+S2=Q2)+(P2+R2+S2=Q2)+(O2+P2+R2+S2=Q2)
Typing this whole thing in gives this error after pressing RETURN:
80 ERROR-   S2=PEEK(T3+T):N2=(O2+P2=Q2)+
(O2+R2=Q2)+(O2+S2=Q2)+(P2+R2=Q2)+(P2+S2=
Q2)+(R2+S2=Q2)+(O2+P2+R2=Q2)+(O2+P2+S2=Q
2)+(O2+R2█
The error breaks the line off at the line limit. but if you can't type a line that long, then there is something I'm missing here.
cribbage.bas
yeah, I did, but giving it those 2 extra on each line only amounts to 6 or 8 extra spots, and that's not much when the line is over 4 full rows long without doing it.
EDIT: I was reading Mapping The Atari , and found the BUFCNT address:
Quote
107       6B        BUFCNT
Buffer count: the screen editor current logical line size counter.
Is there another address that keeps track of the max value for the buffer(120), so that maybe this can be manipulated with a POKE and the line can max out at 255 instead?
Edited by TheRaven81
2 minutes ago, evilmoo said:
Can you "ENTER" it from a file?
I don't know how I would make said file.
5 minutes ago, drac030 said:
The logical line limit is not counted in characters, but rather in lines: three lines 80 chars each is 240 characters. This line actually fits in 160:
ahh I see. Well, I don't have an 80 column editor, I'd have to look into how to get one.
10 OPEN #1,8,0,"D:LONG.TXT"
20 PRINT #1;"80 S2=PEEK(T3+T):N2=(O2+P2=Q2)+(O2+R2=Q2";
30 PRINT #1;")+(O2+S2=Q2)+(P2+R2=Q2)+(P2+S2=Q2)+(R2+S";
40 PRINT #1;"2=Q2)+(O2+P2+R2=Q2)+(O2+P2+S2=Q2)+(O2+R2";
50 PRINT #1;"+S2=Q2)+(P2+R2+S2=Q2)+(O2+P2+R2+S2=Q2)"
60 CLOSE #1
ENTER "D:LONG.TXT"
Like this, possibly? :)
60 CLOSE #1
ENTER "D:LONG.TXT"
So I entered that into Altirra to test it out, and it worked :) So I'll have to do this for each line that is too long, I guess? or is there a way to do multiple lines in a single file? TBH I'm not sure how many lines in the program are like this.
26 minutes ago, David_P said:
If you have SpartaDos X, type CON80 ON
I don't. I only have DOS 2.5, and DOS 3.
I'm glad it worked.  That's the least worst solution I can come up with on short notice.
Hi!
2)+(O2+R2█
The problem is that you are not typing the original program, you are typing some "reconstruction" of the original, with larger variable names.
This is the same, but typeable in the normal Atari:
Have Fun!
cribbage.bas cribbage.lst
6 hours ago, dmsc said:
Hi!
Have Fun!
Where/how did you get this?
Atari Program Exchange Repository, APX, easy search... on the internet... archive.org ....  etc etc etc...
for example....
https://archive.org/search.php?query=atari cribbage
yeah some different cribbage and books et al....
Edited by _The Doctor__
Bad practice to do Basic programs intended as type-ins that exceed the 120 characters.
But as discussed in threads relating to the 10-liner comp it can be good practice.
Basic imposes a 256 limit on an overall line size entered for incorporation to a program -can be met by using a different device such as "D:"
It also imposes a 255 byte limit (?) on actual line length once tokenized (rarely would you come near that)
2 relatively painless workarounds:
- split the line into 2, though for a type-in relies on the program having left unused numbers.
- type the line into a text editor then ENTER it from an emulated H: device using Atascii translation.
@TheRaven81: The APX release does have a protection against LISTing. The BASIC variable name table has been destroyed.
Version 2.0 of CRIBBAGE.BAS which can be found on ANTIC's release does not have this kind of protection. I uploaded the ATR to your other Cribbage-related thread.
The program looks a lot different, but I believe that these lines are at least similar to what you are looking at:
As you can see, there all variable names are only one character long (beside the fact that the line has been broken into several lines).
CRIBBAGE.BAS
