Wilheim Posted May 26, 2020 Share Posted May 26, 2020 Hi, everyone! Attached to this post there is a small utility I programmed recently. It's a cartridge dumper for different bank-switching models. The file it's an ATR containing MYDOS 4.53 and APE_WARP patch in the case you allow warp speed in your SIO2PC. It's recommended that you use this image in a SIO2PC/APE interface and configured APE or RespeQT in 3X speed (Pokey Divisor 8) so the process takes less time. There are two executables: DUMPER.XEX, which saves data for Williams, ATRAX, Turbosoft and Atarimax models. And DUMPX.XEX, which dumps XEGS/Switchable XEGS models. Instructions: 1. Boot the DiskDumper.ATR on D1: with OPTION pressed. 2. Load the binary DUMPER.XEX or DUMPX.XEX with the L option on MYDOS menu. 3. You can mount an ATR file of at least 2 MBytes on your favorite disk manager application. I recommend to mount it on D2: 4. With the START button, you can change the size from 64K to 1024K. 1024K is in default. With OPTION button, you can see the directory on D1: The button SELECT is not able yet. 5. Insert the cartridge on the Atari 8-bit machine. I recommend to insert it slightly tilted to the right. That way it minimizes the risk of hanging the computer out. 6. To start the dumping, just type the complete filename you want to save in in Dx:8.3 format. Example: D2:DUMP.BIN. It's important that you put the Dx: parameter or it won't work. 7. The application starts the dump in the ATR file. If you have any issue, feel free to give your feedback about this application. I hope it helps to make you busy during these times. Cheers! DiskDumper.atr 5 2 Quote Link to comment Share on other sites More sharing options...
spspspsp Posted May 28, 2020 Share Posted May 28, 2020 Thank you for this. This would have saved me some headache a few months back when I wanted to dump one of my XEGS carts. I ended up desoldering the chip, but next time I'll use this. 1 Quote Link to comment Share on other sites More sharing options...
SS Posted May 30, 2020 Share Posted May 30, 2020 I'm sure that this is going to be a dumb question but how do I go about creating an empty 2MByte ATR? Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted May 30, 2020 Share Posted May 30, 2020 17 minutes ago, SS said: I'm sure that this is going to be a dumb question but how do I go about creating an empty 2MByte ATR? ATRtools by @AtariGeezer can make them up to (I think?) 16MB. Do a search for it here on the forums for the latest version. 1 Quote Link to comment Share on other sites More sharing options...
darwinmac Posted May 30, 2020 Share Posted May 30, 2020 22 minutes ago, SS said: I'm sure that this is going to be a dumb question but how do I go about creating an empty 2MByte ATR? MakeATR will also create up to a 16MB ATR. Bob C 1 Quote Link to comment Share on other sites More sharing options...
Wilheim Posted May 30, 2020 Author Share Posted May 30, 2020 You can create a 16 MB ATR image (65.535 sectors, 256 bytes/sector) with makeATR, for example. The dumper atr image has D2: already configured with that parameters. Quote Link to comment Share on other sites More sharing options...
