djrodderz Posted May 29, 2020 Share Posted May 29, 2020 Help required please! Just booted up the 3DO and it’s stuck in a loop like this. It worked the very first boot up after a while but now I can only get this. I’m guessing it could be a laser problem? Any help would be appreciated Thank you IMG_3958.MP4 Quote Link to comment Share on other sites More sharing options...
wierd_w Posted May 30, 2020 Share Posted May 30, 2020 I'd check for bad capacitors, poor solder joins, and things of that nature. Quote Link to comment Share on other sites More sharing options...
djrodderz Posted June 2, 2020 Author Share Posted June 2, 2020 On 5/30/2020 at 7:11 AM, wierd_w said: I'd check for bad capacitors, poor solder joins, and things of that nature. It's looking like its the lens on the CD drive. Would anyone know where to get hold of one? I have seen one on aliexpress which may be compatible... https://www.aliexpress.com/item/32776586603.html?srcSns=sns_Copy&tid=white_backgroup_101&mb=rd1JEgZZqPoGBY6&spreadType=socialShare&tt=sns_Copy&image=Uec34fea07c7f4d39a179a2d9be968523a.jpg&fbclid=IwAR3sjRBfyREfQy1nETf2NkYmrT-JLeooXVpzMQIIdNyeFQuBsGMfjW9fbP0&aff_request_id=0b5a8309cd424ba093615f6ae279122d-1591138432410-01276-_dTVvcgf&aff_platform=default&sk=_dTVvcgf&aff_trace_key=0b5a8309cd424ba093615f6ae279122d-1591138432410-01276-_dTVvcgf&businessType=ProductDetail&title=US+%2424.89++17%+Off+|+Free+Shipping+Original+SF-92.5+(+11P+%2B4P+)+Connection+Optical+Pick+UP+SF92.5+4%2F11+Pins+Car+CD+Laser+Lens+Optical+Pick-up&platform=AE&terminal_id=b5b52b362b584021a15a9469097d83b1 Quote Link to comment Share on other sites More sharing options...
oakcitycomics Posted June 2, 2020 Share Posted June 2, 2020 (edited) The boot loop it related to the CD drive. Most likely you have a broken gear on the drive shaft. Laser is detecting a CD but the broken gear is preventing it from moving to position so it boot loops. Edited June 2, 2020 by oakcitycomics Quote Link to comment Share on other sites More sharing options...
djrodderz Posted June 2, 2020 Author Share Posted June 2, 2020 17 minutes ago, oakcitycomics said: The boot loop it related to the CD drive. Most likely you have a broken gear on the drive shaft. Laser is detecting a CD but the broken gear is preventing it from moving to position so it boot loops. Ah ok I will have to open it to have a look. Where could I find a spare one of those? Many Thanks Quote Link to comment Share on other sites More sharing options...
oakcitycomics Posted June 4, 2020 Share Posted June 4, 2020 On 6/2/2020 at 7:18 PM, djrodderz said: Ah ok I will have to open it to have a look. Where could I find a spare one of those? Many Thanks A guy on ebay sells a 3d printed version. Otherwise you can change out both the drive gear and the moto gear with any off the shelf part but you will have to do both so they will lock in. A 3rd option is to take the gear off and if its just a hairline crack you can superglue it back. Just make sure you wash it well to remove any gear grease so the glue will stick. Quote Link to comment Share on other sites More sharing options...
wierd_w Posted June 4, 2020 Share Posted June 4, 2020 (edited) Could also do what I did for my large format printer (that UPS dropped). Get some cornstarch and bathroom grade silicone caulk and make a protoputty mold of the cracked gear, then cast a replacement in the resulting mold out of either UV cure resin or slow setting epoxy. If the gear has shorn off teeth, do above but only form mold around the good teeth and leave the bad teeth unmolded. Rotate the gear in the resulting mold so that the broken tooth area is then in the molded area, then cast the missing teeth back on using the resin or epoxy. Then mold the whole gear again and cast the replacement. Edited June 4, 2020 by wierd_w Quote Link to comment Share on other sites More sharing options...
djrodderz Posted June 13, 2020 Author Share Posted June 13, 2020 I have opened it up and can see movement on the Lens. It seems to be having the same problem now even without a cd in. It’s like the bios keeps resetting. After turning it off I have to leave it for a minute or two before it will even boot up properly after the error happens. IMG_4318.MOV Quote Link to comment Share on other sites More sharing options...
