Hi, all!
I wanted to start using an hdd image (chd for MAME) as kind of backup / archive collection of files I create on the disk (dsk) images. But I'm stuck on the very first step: How do I create a subdir? I can't (and don't want to even if I could) store everything into the root dir. I did see a few references to something like WDS1.SUB.DIR.FILE, but how do I create SUB at WDS1 root?
Michael
I went through the whole HFDC manual now but I don´t see it.
Only the Myarc DiskManager V is mentioned there,
and I know Fred Kaals Disk Manager 2000 (v2.6) can create subdirs.
Maybe try this first
Posted (edited)
If you don't mind setting up your hard disk structure outside the emulation, I do recommend using my TIImageTool. Everything you want should be there.
Edit:
Inside the emulation, use the MDM (Myarc Disk Manager). The operation is described on page 23 of the HFDC manual. (I hope you found the HFDC manual that I rewrote, and which is searchable: https://ftp.whtech.com/datasheets and manuals/Hardware/Myarc/MYARC HFDC Manual 4th edition.pdf). I did not find a way to create directories in BASIC. (Still, it's a mouse click with TIMT.)
Edited by mizapf
You did not mention HDS1, so I presume you are setting this up for TI-99/4A use only?
If so, MDM5 allows you to make/create and remove directories.  I don't know how Fred Kaal's Disk Manager works with the HFDC, so I do not know the specifics with it.
I will add though that if you are going to use the drive on a Geneve system, use MDOS to make and remove the directories.  Use one tool, and don't mix/match anything with MDM5.  The reason I say this is that somewhere between the Eprom or MDM5, and I do not recall which, there was a bug/oversight in the directory descriptor record versus what the HFDC manual specification said it should be.  From memory, I believe the directory descriptor record should have a pointer pointing back to the previous directory.  MDOS properly implemented this while the Eprom/MDM5 did not.
You would only see this issue if you tried to remove a directory created with MDM5 while trying to do this in MDOS on a Geneve.
Beery
That's how I've always done it :)
Now, I haven't tried, but it seems to me if you wanted to create one within emulation, you could just save the file:
SAVE WDS1.SUB1.SUB2.FILENAME
Please do correct me if I'm wrong and that SUB1 and SUB2 would NOT be created by such an action.
It is fully ok to edit the structure outside the emulation. In fact I did have used your tool already, but used it for chd creation only or so. (Not sure, actual chd might be a result from the imgtool of the MAME package.) I have to admit that I was a bit stuck to TI99Dir while jogging disk images in and out. Unf. that tool exits with a runtime error on some dsk images and I didn't see a way to use chd images yet. I still like the "Norton Commander" like two filelist view, though... But I have totally overlooked the file manipulation possibilites of your tool, I'm afraid. I just had a quick peek at it and it seems to go in the right direction.
Thanks for not only the warning but the explanation, too. I just read that warning in the ReadMe of the MDM5 and now I know what it is about.
Yep, I will be using the dsk and chd (DSK1 and WDS1) on the TI99/4a side only. I have absolutely no experience with the Geneve and am right now struggling enough to resemble my 80s knowledge of that 4a machine. Later on I definitely will have a look at cards I don't know yet and the Geneve is one of them, of course, too.
Michael
TIImageTool was once created by me because I could not handle MAME's chdman without peeking in its usage notes. It also covers imgtool (hence the name). But it is much more than an image creator; take a tour if you have some time. The reference manual is at http://www.mizapf.eu/files/tiimagetool.html.
