maxx11111 Posted May 31, 2020 Share Posted May 31, 2020 i have 2 versions of doom 2, both worked with my skunk but with the GD they red screen has anyone had success getting them to run? if so what are the the crc's you get from them? Quote Link to comment Share on other sites More sharing options...
SainT Posted May 31, 2020 Share Posted May 31, 2020 If they work on the skunk then they have been modified to do so. Find an unadulterated ROM and it will work! Quote Link to comment Share on other sites More sharing options...
maxx11111 Posted May 31, 2020 Author Share Posted May 31, 2020 59 minutes ago, SainT said: If they work on the skunk then they have been modified to do so. Find an unadulterated ROM and it will work! not necessarily been modified to work on the skunk as other roms that work just fine on the skunk also work fine on the GD, hence wanting to to check the crc's Quote Link to comment Share on other sites More sharing options...
SainT Posted May 31, 2020 Share Posted May 31, 2020 1 hour ago, maxx11111 said: not necessarily been modified to work on the skunk as other roms that work just fine on the skunk also work fine on the GD, hence wanting to to check the crc's No, skunk ROMs are not compatible. Likewise ‘normal’ ROMs do not run on the skunk without modification. If it runs on the skunk it’s a 16bit ROM. If any ROMs which function in the skunk run on the GD it’s because the menu has detected they are 16bit and patched them on load. There will be a message to this effect. If for some reason it’s not recognised it you will indeed get a red screen. Likewise if it’s been ‘locked’ to the skunk, which some are, it will fail and you may get a red screen. As Doom2 is a ROM hack I’m not sure of its origins. Quote Link to comment Share on other sites More sharing options...
maxx11111 Posted May 31, 2020 Author Share Posted May 31, 2020 14 minutes ago, SainT said: No, skunk ROMs are not compatible. Likewise ‘normal’ ROMs do not run on the skunk without modification. If it runs on the skunk it’s a 16bit ROM. If any ROMs which function in the skunk run on the GD it’s because the menu has detected they are 16bit and patched them on load. There will be a message to this effect. If for some reason it’s not recognised it you will indeed get a red screen. Likewise if it’s been ‘locked’ to the skunk, which some are, it will fail and you may get a red screen. As Doom2 is a ROM hack I’m not sure of its origins. Thanks for your help 1 Quote Link to comment Share on other sites More sharing options...
