a8isa1
What DOSes and final versions shipped with SWP's ATR8000 during its run?
This is the final MyDOS disk I have for my ATR8000.  I don't even recall how I obtained the disk seeing I acquired the unit second-hand in 1983/1984 which is earlier than the 1985 date indicated on the disk. I'm curious if there were versions later than the 3.014/3.19 builder disk.
I seem to recall before MyDOS began shipping with ATR8000's that OS/A+ was the DOS of choice but I'm not sure.
Were there ever other DOSes included with or made available specifically for the ATR8000?  If so, what were the final version numbers?
Thanks.
-SteveS
4 hours ago, Frankie said:
Could you upload an ATR of that?
Mathy has it and perhaps 4 or so earlier versions on his mydos page. I  sent them to him 10+ years ago.
Www.mathyvannisselroy.nl
1 hour ago, _The Doctor__ said:
Front and possibly back...
Back as in flip side?   Not possible. The ATR8000 is the only A8 drive system I've ever owned and the disk doesn't have 2 index holes. I doubt it's a "flippy".
I don't remember if they supplied Double-Sided Double or single density disks from SWP anymore... so both sides isn't a reach, not only but also because while some disks were booted in the Atari Drives, some were booted in the SWP attached drives, and some SWP attached drives had index hole sensor added or even included by either a hacker or manufacturer. If you look at some of the drives of the day, you may see some with the holes already there but UN-occupied like you see on the standard missing index hole on there Atari SIO based drives.
You can do a search (at least 10 years back you could) and find how to add index hole circuitry sensors and even index fakers. YMMV
Edited by _The Doctor__
Is there a way on windows to un-ARC these files? I have tried some programs that say they can but report the file is bad.
Altirra....You can mount arc files as a disk
As it turned out Mathy stored the images as DCM files.
Here is a newly created ATR of my disk.
mydos_builder_3014_319.atr
was there a program called whatis or something to that effect that told you the deflation/compression that was used on something if the file extender was wrong or missing?
