Wrathchild
Magnetic Scrolls adventures - Single ATR version
Something that has been on the cards for undertaking in order to make titles more playable with the elimination of disk-swapping...
A single-disk compilation of the Rainbird/Magnetic Scrolls adventure games; The Pawn, The Guild of Thieves & Jinxter
This first post is just a work-in-progress teaser but should be playable, e.g. from an SIO2xx device or under emulation.
Still to do is the re-mapping of loading and saving, so please avoid that for now until the next update :)
rainbird-wip.atr
  • Like 20
Posted (edited)
Not sure it's working properly in Altirra, after loading and some text, a graphics screen lowers from the top and covered
the text before I had read it all, now when I move or "look" the text at the bottom of the screen scroll up under the graphics.
I've not played this before, so is there a way to remove the graphics so the text can be read or is this a bug ?
Edit: it's OK, I played around and found START and SELECT move the graphics up and down 😀
Edited by TGB1718
Update
Posted (edited)
Your'e welcome!
Here's the first version where the saving and loading should be possible.
All titles have 8 slots and so here they share them, so if you try and load a slot from a different title then you'll receive a 'fatal' error and asked to reboot the game disk.
This version brings up a question of preference as part of the copy-protection is to request a word from the game docs in order to proceed (with 3 tries).
So I would think the consensus would be to have this bypassed but seeing as the docs are available online then it might be worth leaving that in - let me know and I'll investigate if necessary.
rainbird-rel1.atr
Edited by Wrathchild
screenshot added
Easiest/least obtrusive would seem to be to have it always succeed regardless of what is typed, right?
From a quick debug, I have a feeling this is all being controlled by the game's interpreted code rather than a dedicated routine and so might not be possible.
Oof, well that makes it a bit more difficult doesn't it. Still, with modern tools, snapshot the success state, snapshot the failure state, diff and you've got what you need to replicate i would think. Bless the small memory area and therefore static memory maps between runs...
