Indus GT O/S Chip Part Number
gilsaluki
Best Electronics : http://www.best-electronics-ca.com/8-bit_.htm
Indus Atari 8 bit GT Disk Drive Upgrade ROM.  This plug in Unreleased Indus OS Rom will give you a Faster Sector Mode 50 - 75 faster, Increased Stepper Rate of 50% faster and Shortened Motor Timeout from 9 seconds to 2.5 seconds.  Requires you dissemble your Indus Disk Drive, unplug the old OS chip and insert the upgrade OS chip.   Includes the New Indus OS chip and 1 page written instructions. CB103141 $15.95
In an earlier discussion, someone stated that the upgrade ROM from Best disables CP/M compatibility.
I have the ROM in my Indus and I thought CP/M still worked, but I plan to test this when I have finished hacking the 520STFM on my bench.
to the best of my knowledge I haven't read of their rom disabling CPM.  It isn't a custom ROM, it is a 'hacked' rom, adjusting a few 'configuration' values....  primarily the excessive idle spinning.
It is just a standard EPROM.  If you know anyone who can burn an EPROM for you, there are different versions of the ROM on the net.... including either the Best Electronics one, or a similar adjusted ROM, along with a totally custom rom by @MrMartian which gives US Doubler speeds and such to the drive.  I believe his does eliminate CP/M from working though.
