CharlieChaplin
turn OS-B carts into XL/XE carts, please...
Well, I made a proof of concept on Altirra, putting TRIG3 ($D013) on GINTLK ($03FA) every frame. It worked fine.
I just put an small VBI routine on $100, forcing GINTLK with TRIG3.
If we find enough bytes on the ROM, we can add this routine and make it work. I will see it now.
21 hours ago, FULS said:
Also, besides fixing the Astro Chase Carts, is there a Monster Maze cart that works on the OsB and XL machines.
Thanks
I looked into the cartridges. There is an illegal call into a keyboard routine. Maybe if we can generalize that call, we can fix it.
Here's a beta that should do the trick. Please let me know if you find any bug.
Monster Maze (1982)(Epyx) beta.bin
Thank you guys for all the work in converting these.
I have one more request.
Is there a Pool 400 cart that works on both the OsB and XL computers?
I have these two images, one works on OsB only and the other XL only.
On a Hex editor they look very similar. I'm thinking each one makes an illegal call into the OS.
Pool 400 (OsB).bin
Pool 400 (XL_XE).bin
Thanks
17 hours ago, larryleffaovell said:
There is an already working version I linked earlier. Try this one...
Hi,
I tried using Altirra in XL mode but couldn't get your Bin to work.
Would you retry with XL and see.
I might have my settings wrong.
Also I couldn't get your Monster Maze to work in XL mode.
Wilheim's (Post #52) works fine.
Thanks
Edited by FULS
Hmm, you're right. Interesting. I'm doing all my tests with the atari800 emulator as I'm on Linux... The binary loads and shows the initial screen with both, 800 and XL/XE, but only when setting is 800 the game is working correctly and hangs on XL/XE. Tried the atari++ emulator and there XL/XE runs the binary but hangs at start and crashes with crashed at $a003 illegal opcode $02 when set as 800.
Weired. Seems that something's borked with this cartridge or dump.
