ijor
Greaseweazle new DIY open source alternative to Kryoflux and SCP
Reporting back now it is all set up:
a8 images working :)    [gw read --drive 0 --rpm 288 --revs=5 <filename>.scp]
ST images working :)   [gw read --drive 1 --rpm 300 --revs=5 <filename>.scp]
Amiga images working :)   [gw read --revs=5 --drive 1 <filename>.scp]
All in all - very happy :D
Hi Cj,
Please considering including one or two extra tracks. That means tracks 0-41 on 48tpi drives, and 0-81 on 96 tpi ones. Not sure about the default gw settings.
Also I don't recommend including the rpm parameter. I'm not that familiar with the gw software, but we don't want it to perform any kind of interpretation to the data. So it should not need the original recorded RPM value.
7 hours ago, ijor said:
Hi Cj,
Hi Ijor!
GW automatically does 0-41, 0-81 by default.
I've found without the -RPM value nothing can interpret the images it makes.
Good to know. Thanks
Quote
Are you sure? How it could work without the RPM parameter for Amiga images, but not for ST ones. Not sure that makes much sense. Would you mind posting an image produced without the RPM parameter?
Right now I can't as I was using an external PSU to power the floppies inside the case... however I've got some cables on order for SATA->Female MOLEX, when they arrive I can do so.  However, my ST disks are slighly... odd...  They're all 5.25" :)
That's odd :)
Anyway, the RPM parameter should be avoided. It modifies and distorts the data, which is very bad for preservation purposes. Of course, if you are only extracting files from personals disks, then it doesn't matter. But even then, it shouldn't be needed. May be the gw software needs it if, and only if, you are using the gw software to interpret and to convert the dumps to plain sector level images (ATR, ST). If you are using more standard tools to perform the conversion from SCP images, such as a8rawconv for 8-bit images, then it should not be needed.
I have done a hundred of Atari single sided single density dumps lately without -RPM option on a panasonic JU-475 and all the SCP (and then ATX with A8rawconv) work perfectly.
So chances are that, if it does not work on your side, something else (another option?) is wrong but this -RPM is definitely NOT mandatory
On 8/20/2020 at 3:40 AM, ebiguy said:
I have done a hundred of Atari single sided single density dumps lately without -RPM option on a panasonic JU-475 and all the SCP (and then ATX with A8rawconv) work perfectly. So chances are that, if it does not work on your side, something else (another option?) is wrong but this -RPM is definitely NOT mandatory
Well, I was thinking...
a8rawconv doesn't need any kind of RPM compensation because it already expects the raw dump to be produced on a drive that has a different RPM than the one that the disk was recorded. That's the normal and common behavior. The disk was originally recorded at 288 RPM and the dump was read at either 300 or 360 RPM.
But other tools might not. It is actually likely that some ST don't expect that because you don't normally have that RPM discrepancy with 3.5 disks. Both PC and ST drives use 300 RPM disregarding the density. But he is using 5.5 disks and more than likely a 5.25 drive rotating at 360 RPM. So that might explain, at least, why he needed the -RPM parameter for ST disks.
I’m on their facebook page and they seem like a super great bunch of folks.. Great resource for us archivers out there!
