stephena
Stella 6.2 released
There is no such option in Stella and I am not sure if the SDL framework supports it. It might be better to solve the problem using the OS, not sure. What you describe seems OS specific.
On the Mac there's a global setting for all programs, which individual programs can override such as here in FaceTime:
Looks like Stella's using this to open up the audio device:
  myDevice = SDL_OpenAudioDevice(nullptr, 0, &desired, &myHardwareSpec,
                                 SDL_AUDIO_ALLOW_FREQUENCY_CHANGE);
Per SDL Wiki that nullptr can be replaced with a device name.
SDL_AudioDeviceID SDL_OpenAudioDevice(const char*          device,
                                      int                  iscapture,
                                      const SDL_AudioSpec* desired,
                                      SDL_AudioSpec*       obtained,
                                      int                  allowed_changes)
device
a UTF-8 string reported by SDL_GetAudioDeviceName();
int i, count = SDL_GetNumAudioDevices(0);
for (i = 0; i < count; ++i) {
    SDL_Log("Audio device %d: %s", i, SDL_GetAudioDeviceName(i, 0));
Good, so I could just rebuild Stella with my desired device and it should work?
Encountered a silent crash condition while working on the next entry for the CDFJ tutorial.  By silent I mean the macOS application crash dialog did not appear, though I did find this not-so-helpful ReportCrash in Console:
1341209312_ScreenShot2020-07-04at12_17_53PM.thumb.png.2646f461c88b5290f0a61ed0c6a9fcde.png
Here's the ROM:
collect3.bin
After loading it I entered the Debugger and clicked on to the Cartridge RAM tab. I then scrolled down to 0CA8 and clicked on the cell - this is when Stella silently crashed.
I then reloaded it and again entered the Debugger.  This time Stella silently crashed as soon as I clicked on the Cartridge RAM tab. I tried this a few times and it crashed every time.
I don't recall what size the Debugger window was set to, but the sliders where almost all the way to the left.  I increased them and the crashing appears to have stopped.
I then decreased them all the way to 1160 and 770 and the crashes returned, but it doesn't always crash (so it's possible the larger window didn't really fix it, hence my use of "appears").
Here's a successful sequence with a larger debugger window. After loading Collect 3 and starting the game you'll see this:
554339147_ScreenShot2020-07-04at12_10_36PM.thumb.png.0974879922f461b4134ce9923abe3d21.png
After entering the debugger and changing Cartridge RAM 0CA8 to F0:
2120717107_ScreenShot2020-07-04at12_10_51PM.thumb.png.0126243cdc8a2bb0db4ee4008e059ed0.png
You'll now see some red playfield pixels at the top-left:
1525511144_ScreenShot2020-07-04at12_10_55PM.thumb.png.03bb95ff99ddb90564d96df432784bab.png
The HOME PG-UP PG-DN END keys seem to enable phosphor just by cycling to/through 'phosphor blend' with them. Seems to override the setting in the main Options> Video & Audio> TV Effects menu.
Thanks, I will create an issue.
I think I found the reason why that sound stops randomly. I noticed some audio buffer underrun in the log just after sound stops working, so it seems I just have to adjust the sound settings.
What is wrong when I cannot build Stella on Armbian 5.90 (Ubuntu Xenial)? Too old distro?
I can build it on latest Armbian 20.05, but I cannot run it there, cause I cannot build SDL2 there.
Stella requires g++6 and C++14 support.  Over the next year or so, the minimum requirements will move to g++7 and C++17.  For Linux, I'm using KDE Neon 18.04 (based on Ubuntu 18.04), soon to be moving to 20.04.  So it's likely that Xenial (which is 16.04 I think?) is too old.
Yes, so this is the point. Ubuntu 16.04 has g++ 5.3.1, so I should build it on newer version. However, Stella 6.0.1 in Retropie builds just fine and even the Ubuntu provided Stella 4.7 is not so bad, so it is not a problem. Seems that Finally I found a way how to run Stella fast on my Banana Pi.
Stella 6.0.1 may build fine with older versions of g++, but I'm referring to the most recent release: 6.2.1.  That's the one that requires g++6 and C++14.  See https://stella-emu.github.io/development.html for a description of what is required.  This will be updated as we move to newer version of the compiler and C++ standard.
I noticed that the right part of snapshots are chopped off when taking screenshots from fullscreen mode under Mac OS, but the snapshots look normal when taken from windowed mode.  I submitted an issue for this.
Sorry to bring this up again, but I'm going to again request being able to have a 1x gameplay window with no interpolation/effects/etc.
Time Machine is a good tool, but it has a few shortcomings from my non-developer's point-of-view. Unless I'm doing this wrong (which is entirely possible).
Here's what I'm doing:
  • I play a game with Time Machine running, set at 1 frame intervals. Buffer size 1000 states, horizon 60 minutes.
  • I enter the Time Machine UI and save the states to disk.
  • Rewind/Unwind and scrubbing controls work fine. But I can't step forwards or backwards in single-frame increments throughout the entire recording (the recordings can be quite long). I have to enter the debugger to do that.
  • In Time Machine when I hit "Continue" the emulation starts from that point without using any of the save states past that point. So if I do that, I have to reload the states again. Yes - I get that this is the way it's designed to work, because you're continuing the emulation, not save state playback. But it's incredibly frustrating having something that in appearance looks like a media player, but doesn't behave that way. A "Continue" icon would be more appropriate (see below) than a "Play" icon. Also, a true playback button where it continues the playback using all of the save states would be incredibly useful for watching playback in real time within Time Machine.
  • I can't save screenshots from the Time Machine UI directly. Or maybe I just can't figure out how to do it. A save screenshot button there would be helpful.
  • To save screenshots, I have to enter the debugger. But the debugger doesn't have the Time Machine playback controls in it. I can move backwards in time there, but I can't move forwards - it ignores save states beyond the point in time where I entered the debugger. So I have to again enter the Time Machine UI, reload the save states, move to the point I want to capture frames from, move back to the debugger, and save the screenshots from there, while only moving backwards to do so.
And this is just to capture screenshots at 1x.
The other problem, is that this still isn't going to work with capturing video. When I capture the videos for AtariAge's YouTube channel, they need to be scaled up to HD (so YouTube doesn't do it badly). The problem is, Stella is now applying its own interpolation, which is going to be interpolated a second time when scaling in video editing software. The end results are far cleaner if I only have to interpolate the video once. I can't get rid of the artifacts from Stella's interpolation. Hence, the need for 1x capture. Plus, it solves the screenshots problem, since I can easily go through and just lift the screenshots I need from the captured video. I'd prefer to use the newest version of Stella because the emulation is more accurate, but I find myself having to stick with an older version right now. I appreciate the desire and effort to accurately mimic the appearance of TV aspect ratios. But I really have a need to be able to shut it off.
Thanks for listening.
Example of a continue icon: continue-icon.gif.05c8d6cddee0a4cb3f5b1424bce84852.gif
First let me say, that I can understand your request. However a 1x window will require to disable large parts of UI (dialogs, messages), because these are tailored to a minimum size of 2x. This has been requested before, but it is not an easy task. A 2x window without scaling would be much simpler to implement. If that works for you.
How large do you choose the uncompressed buffer size?
That's correct. 60 minutes of a 60 Hz game have 216,000 frames (for BoulderDash, 1,000 states require 179 MB, with 216,000 states we would be at 39 GB!). So older states have to be compressed by removing more and more intermediate states. Only the states within the uncompressed range are saved completely.
Good point, I will look into this. However, due to the compression, the playback would run at different speeds. Alternatively a state in the compressed range could be displayed as long as the interval to the next compressed state (which can be several seconds). What would you prefer?
Hm, IIRC some hotkeys (incl. save screenshot used to work). I will double check.
I just tested what you describe. I can move forward within the debugger (either by using the buttons or the hotkeys). Can you double check this please?
The interpolation is required to have the correct aspect ratio. I figure that in your case you would prefer to do that on your own, correct? Personally I wouldn't want to expose such a functionality to the normal users, but maybe we could add a command line switch which disables the scaling. Would that work for you?
Understood.
Thanks. It looks good, but at least for me its meaning is not obvious. Maybe a simple exit button would work better? Also, where should we put that button? Besides the play button? Probably the play button should be moved into the middle of the navigation buttons. And the exit/continue button where the current play button is. Thoughts?
2x would be perfectly fine, without interpolated scaling. This is typically what I capture in with earlier Stella versions anyway. (I referred to 1x only because that's how getting clean screenshots had been referred to elsewhere in this thread - and that seemed to be the path forward.)
Not sure - probably the default. I don't have the current version of Stella on this computer.
That's what I gathered from the documentation (which I do try to read before posting these sorts of things ;) ).
If I'm understanding correctly, that would basically shift the per-frame accessibility to the present state you were in, based on where you were in the timeline? Sort of like a sliding window of finer control? That would be pretty handy I would think. But I don't know if that works best for developers.
I tried the screenshot hotkey from the Time Machine UI - nothing showed up in the Snapshots folder.
As I recall, if I rewound a bit, then exited Time Machine directly to the debugger, it wouldn't step ahead from that point. I could go backwards and then forwards - but not past the point where I exited the Time Machine. The step ahead (unwind?) button was greyed out at times, and I wasn't at the end of the recorded save states.
If I can access it on a Mac, that would be perfect! You're correct - I want to set the aspect ratio during video editing or after capturing screenshots from the video.
I'll admit, I had to Google the Continue icon, and it's not 100% universal. Exit (or Return) might be better than Continue. Continue implied to me that the playback was going to continue.
Thanks for considering this. I do appreciate it (and all of the work everyone puts into Stella!).
One of the very few. :)
Not sure what you mean. But most likely not what I meant. :)
I was wondering how long the frames resulting from a saved state should be displayed if you replay the states. Especially for the compressed states.
You were right. But I have added that function now.
Please double check. On my machine this works.
You're welcome.
Two small requests for Stella:
1) Is there any way to prevent Stella from toggling Pause when the window loses focus (on Linux with XFCE)?    When developing, I often slow down the emulation and use Pause to pinpoint the exact frame containing an issue.   The I click on the editor window, and annoyingly the emulator un-pauses and the issue is lost!
2) It would be great if the emulation speed could be controlled via keypresses, so that you can easily speed up/slow down the emulation.   I am aware of the turbo mode, which is handy in some situations, but more fine control would be very useful.
Thanks,
Chris
For feature requests, please create an issue at https://github.com/stella-emu/stella/issues.
The first has specific code that does that.  So I guess we'd need an option to not do it.  Seems easy enough.
The second requires a little more work, but also seems doable.
Will do - thanks for the fast response Stephen!
Chris
Feature Discussion:
Has there been any thought or discussion about adding the 7800 to Stella? Or, perhaps, starting a new full-feature emulator called Maria?
For me personally, I can almost definitely say never.  I don't have time to work on another large project.  In fact, my time on Stella has been limited over the past year or so.
As for starting a new emulator project for the 7800, there are already many out there.  They just need more manpower to take them to completion.
This is now fixed, and will be in the next release.
I just implemented this one. :)
