MrTransistor
Force Command and FDOS issues.
Hello everyone. I've been trying to get Force Command running on my physical hardware, and I don't really see what's going on here.
It loads into the FinalGrom just fine, but it appears that I may have some sort of problem, either configuration or whatever, because it just hangs up and doesn't do anything else.
Is there something I am missing? Or is it a hardware issue that I should investigate?
Thanks!
(Original TI-99/4a, not the locked out version, btw.)
Thanks!
Do you have 32k memory?
Sent from my LM-G820 using Tapatalk
Yes. I recently bought a NanoPEB from you, in fact. Lmao.
Incidentally, I fixed it. It was something super simple. The nanoPEB was not being powered correctly, so it was not allowing the access to the on-board 32K.
It must have been something intermittent that was causing a short interruption of power, because the LED's were lit.
It wasn't until I noticed my power cable was a little loose that I got it working.
Thanks!
4 minutes ago, arcadeshopper said:
Hooray! Yeah Power is important.
lmao, yeah.  I'm digging this software, too. Jedimatt is a wizard.
