TXG/MNX #1 Posted June 17, 2020 Hi I am troubleshooting an 130XE I have a question the MPD pin14 of mmu to which chip pin should it be connected?It also goes to R15 but I cannot find that resistor on the board. Solved. So far pin 15 has no connection so that needs to be fixed. Only pin 15 needs a new connection. Pin 14 need to be connected to the near via. Fingers crossed Quote Share this post Link to post Share on other sites
Rybags #2 Posted June 17, 2020 Do you have the 130XE schematics? /MPD is Math Pack Disable and is an input from the ECI, so doesn't go to any other chip on the computer. /BE is Basic Enable which comes from PB1 on the PIA. /MAP is from PB7 on the PIA - Self Test Rom select. REN is from PB0 on the PIA - OS Rom enable, note it's active high unlike the other Rom selects. Link for handy system board and chip info https://www.atarimax.com/jindroush.atari.org/atech.html Quote Share this post Link to post Share on other sites
TGB1718 #3 Posted June 17, 2020 Have a look at these circuit diagrams 1 Quote Share this post Link to post Share on other sites
TXG/MNX #4 Posted June 17, 2020 Have a look at these circuit diagramsThanx i had that only but it was a puzzel to find exactly where some traces would go. But I found two issues I will fix and test.Verstuurd vanaf mijn POCO F1 met Tapatalk 1 Quote Share this post Link to post Share on other sites
Mathy #5 Posted June 17, 2020 (edited) Hello TGB1718 9 hours ago, TGB1718 said: Have a look at these circuit diagrams Why not use the original ones here? Sincerely Mathy Edited June 17, 2020 by Mathy 1 Quote Share this post Link to post Share on other sites
TGB1718 #6 Posted June 18, 2020 Thanks for the link, but I think the "Left Side" is missing part of the circuit at the extreme left edge. But also more good infor on other Atari gems Quote Share this post Link to post Share on other sites
Mathy #7 Posted June 18, 2020 Hello TGB1718 I just checked. You are correct. But this is how they apparently came from Atari in the Netherlands. Sincerely Mathy Quote Share this post Link to post Share on other sites
Marius #8 Posted June 19, 2020 With all the respect for mr. Sobola's work, I can not remember I ever used a schematic from his hand that was not faulty. So please be careful with just using that schematic without checking everything twice or more. 1 1 Quote Share this post Link to post Share on other sites
