Sign in to follow this
TapperP
Best power supply to use with Atari 800?
So I recently got an Atari 800 and it came with the original power supply. It looks like the one in the photo below. I was just reading that old power supplies can kill the motherboard if they go bad, so what is a recommended new power supply I can buy for the Atari 800? If you have a store link that would be much appreciated. I really don't want anything bad to happen to this computer!
Edited by TapperP
8 minutes ago, TapperP said:
So I recently got a Atari 800 and it came with the original power supply. It looks like the one in the photo below. I was just reading that old power supplies can kill the motherboard if they go bad, so what is a recommended new power supply I can buy for the Atari 800? If you have a store link that would be much appreciated. I really don't want anything bad to happen to this computer!
The original 9VAC power bricks for the 400/800/1050/1200XL are dead simple transformers - there's not much inside to go wrong, and when they fail, it's either because the fuse inside blew (probably because it was subject to a power surge from house wiring), or because the thing was physically abused and something broke the transformer coil windings. If you have a multimeter, test the PSU and see what the output is. Since it's unregulated, you should get something like 10.5 - 11VAC out of it without a load. That's perfectly fine and expected.
I have about a dozen of these and all of them are still fine after 35 - 40 years.
The 800 has a power supply board to convert the 9VAC from the power supply to the 3 DC voltages required by the system, these power supplies are just a transformer and fuse.
It's some versions the 5VDC power supplies used with the 600XL/800XL and XE computers that tend to fail and damage chips.
Ah, great to know. Maybe what I was reading was referencing other Atari AC adapters then.
Thank you.
Well, then never mind I guess. 😛
Edited by TapperP
3 hours ago, Paul Westphal said:
I don't recommend these, they have a limited output current, only ~1.5A. This is about the same a the CO14319 which came with my first 400, the fuse in that power supply blew after I upgraded the 400 with a Mosaic 64K board.
It may work OK with a 400 or 800, but definitely won't supply sufficient current for a 810/1050/XF551 drive, I will only use a CO14319 with an 850 or a stock 400 due to this low current rating.
There were several 9VAC power supplies from Atari, the CO17945(31VA) is the most common.
I am still using mine from my first Atari 800 that my dad bought me when I was 10, and I am 51 now! These are rock solid.
I have only had one go "bad" on me in all these years.   It was used for my disk drive.   I opened it, caution is advised, and replaced the blown fuse.  Used it for another 10 or so years till it finally developed an open Primary winding.
2 hours ago, gilsaluki said:
 I opened it
I found that is the most difficult part, getting that darn case split open! LOL
Mine was held by rivets, so drilled them out, replaced the fuse and fitted screws/nuts, still working fine
