JGroth
Can't upgrade SIDE2 cartridge
Hi, I'm trying to update my SIDE2 cartridge to the latest version of firmware and SDX but I have no success.
I've mounted side2_full_oss_carts.atr on D1: (RespeQT 5.2) and started uflash.xex. I press enter on the chip entry (top entry) and I get the dialogue where you are supposed to select the ROM file but the entire machine hangs and a power cycle is required.
I'm following FJC's video tutorial how to do this (I also have a U1MB installed and configured according to FJC's instructions).
The SIDE2 boot screen looks a bit odd though:
Ultimate clock installed
SIDE Driver v1.0 (c) 2011, FJC
SanDisk SDCFB-256
Drives(s): C,D,E,F,G,H,I,J
      SpartaDOS X 4.46a 4-02-2013
   Copyright (C) 2013 by FTE & DLT
The CF card was partitioned and formatted with another SIDE2 which I could upgrade to the latest firmware.
I've tested the SIDE2 cartridge on both a 800XL and 600XL with exactly the same behaviour.
My setup is:
600XL
64KiB RAM (Lotharek Lair's version)
U1MB (upgraded to F/W 3.1 and SDX 4.49)
VBXL
SIDE2 (Can't upgrade and boot message displays what looks like a very old version of firmware and SDX)
SanDisk 256MB CF card
800XL
VBXL
SIDE2 (Upgrade worked just fine)
So basically the machines are identical part from the SIDE2 cartridge. Just to check that my upgrades to 600XL isn't at fault I tried to upgrade the SIDE2 in the 800XL but with the same result, UFLASH.XEX hangs when you are supposed to get to choose ROM file.
I've also put in the 800XL SIDE2 cartridge in the 600XL and UFLASH.XEX lists the ROM files just fine.
So my question is, I guess, how do I upgrade a SIDE2 cartridge that has firmware from 2011?
Regards,
JGroth
UFLASH needs extended memory. Use the DLT flasher that's on the ATR (named SIDE2.COM or similar).
I guess UFLASH's extended memory test has developed a bug. It should just complain there isn't enough RAM.
It also happened to me, but i followed the alternative upgrade procedure from flashjazzcat video and i worked perfectly.
SIDE2.COM seems to have worked. What I don't understand is that I could upgrade another SIDE2 with UFLASH on a 800XL without any problems. UFLASH freezes both the 600XL and the 800XL with the new cartridge. The U1MB is configured to use RAMBO (1088KB) memory.
In cases like these I have to wonder if the SDX bank somehow got corrupted (this would handily explain a hang when opening the file selector). Have not been able to reproduce, however (I run UFLASH dozens of times a day, it seems).
upgrade respeqt to the latest version... there are some issues with the odd flash here and there as well... just a good idea since you mentioned what you are using.
I had the same problem this week using UFLASH to update SIDE2 on my 1200Xl with U1MB. Hangs on the Rom selection screen. SIDE2.com seems to have worked OK as I have SIDE driver v4.0 now.
I actually encountered the same issue when updating a stand-alone SIDE2 the other day. The SDX SIDE.SYS driver supplied on the non-FJC firmware device driver in use was NINE YEARS OLD, however (version 1.0), so I was hardly surprised:
The SDX build is seven years old, meanwhile. I don't observe any issues once SDX and the driver are up to date, and my workaround was also simply to use the SIDE2.COM flasher which I also provide on the firmware ATR.
