broken pipe and syntax error
Serguei2
CCI started acting funny after my computer crashed.
Here the error:
Quote
sdcpp.exe: fatal error: when writing output to : Broken pipe
C:\robin\ColecoVision\robin>sdcc -mz80 -c --std-c99 --oldralloc  sound2.c
sound2.c:23: syntax error: token -> 'snd_table' ; column 23
And the source:
Quote
#include <coleco.h>
#include <getput1.h>
const byte sound1[] = {
 0x40,0xAB,0x01,0x08,0x42,0xAB,0x71,0x08,0x18,0x11,0x50,
const byte sound2[] = {
 0x80,0x5A,0x00,0x08,0x82,0x5A,0x70,0x08,0x18,0x11,0x90,
const byte sound3[] = {
 0xC0,0x20,0xF0,0x10,0xD0,0x00,0x00,0x03,0x08,0x02,0x73,0x08,0x18,0x11,0x10,
const byte sound0[]={
 0x02,0x33,0x0c,0x1c,0x11,0x10
const byte noise1[]={
 0x00,0x33,0x0c,0x1c,0x11,0x10
const byte sound4[]={
 0x00,0x39,0xF0,0x10,0xD0,0x00,0x00,0x07,0x08,0x02,0x77,0x08,0x18,0x11,0x10,
 0xC0,0x20,0xF0,0x10,0xD0,0x00,0x00,0x07,0x08,0x02,0x77,0x08,0x18,0x11,0x10,
const sound_t snd_table[] = {
  {sound1,SOUNDAREA1},
  {sound2,SOUNDAREA2},
  {sound3,SOUNDAREA6},
  {sound0,SOUNDAREA4},
  {sound4,SOUNDAREA6},
  {noise1,SOUNDAREA4},
const byte gtsNAME[] = {
  0xFE, 0x20, 0xFE, 0x20, 0xFE, 0x20, 0xFE, 0x20, 0xFE, 0x20, 0xFE, 0x20, 0x85, 0x20, 0xFF};
const byte gtsPATTERN[] = {
  0xFE, 0x00, 0xFE, 0x00, 0x89, 0x00, 0x01, 0x1C, 0x38, 0x82, 0x18, 0x02, 0x00, 0x18, 0x18,
  0x82, 0x66, 0x85, 0x00, 0x21, 0x44, 0xFE, 0x44, 0x44, 0xFE, 0x44, 0x00, 0x18, 0x3E, 0x60, 0x3C,
  0x06, 0x7C, 0x18, 0x00, 0xFF, 0x81, 0xB9, 0xA5, 0xB9, 0xA5, 0x81, 0xFF, 0x3C, 0x66, 0x3C, 0x38,
  0x67, 0x66, 0x3F, 0x00, 0x06, 0x0C, 0x18, 0x84, 0x00, 0x01, 0x0C, 0x18, 0x82, 0x30, 0x04, 0x18,
  0x0C, 0x00, 0x30, 0x18, 0x82, 0x0C, 0x08, 0x18, 0x30, 0x00, 0x00, 0x66, 0x3C, 0xFF, 0x3C, 0x66,
  0x82, 0x00, 0x81, 0x18, 0x02, 0x7E, 0x18, 0x18, 0x86, 0x00, 0x81, 0x18, 0x00, 0x30, 0x82, 0x00,
  0x00, 0x7E, 0x88, 0x00, 0x81, 0x18, 0x81, 0x00, 0x10, 0x03, 0x06, 0x0C, 0x18, 0x30, 0x60, 0x00,
  0x3C, 0x66, 0xCE, 0xD6, 0xE6, 0xCC, 0x78, 0x00, 0x18, 0x38, 0x83, 0x18, 0x2C, 0x1C, 0x30, 0x0E,
  0x1E, 0x36, 0x06, 0xFC, 0xC0, 0xFE, 0x00, 0x0E, 0x1E, 0x36, 0x06, 0x3C, 0x86, 0xFE, 0x00, 0x0E,
  0x1E, 0x36, 0x66, 0xFE, 0x06, 0x06, 0x00, 0x1E, 0x3E, 0x70, 0xE0, 0xFC, 0x0E, 0xFE, 0x00, 0x0E,
  0x1E, 0x30, 0x60, 0xDE, 0xF2, 0xFE, 0x00, 0x7E, 0xC6, 0x0C, 0x82, 0x18, 0x18, 0x1C, 0x30, 0x1E,
  0x3E, 0x66, 0x66, 0xFC, 0xC6, 0xFE, 0x00, 0x3C, 0x66, 0xCE, 0xFE, 0x06, 0x0C, 0x38, 0x00, 0x00,
  0x18, 0x18, 0x00, 0x00, 0x18, 0x18, 0x82, 0x00, 0x0C, 0x18, 0x00, 0x00, 0x18, 0x18, 0x30, 0x0E,
  0x18, 0x30, 0x60, 0x30, 0x18, 0x0E, 0x82, 0x00, 0x02, 0x7E, 0x00, 0x7E, 0x82, 0x00, 0x0F, 0x70,
  0x18, 0x0C, 0x06, 0x0C, 0x18, 0x70, 0x00, 0x1E, 0x3E, 0x66, 0x06, 0x18, 0x18, 0x00, 0x18, 0x87,
  0x00, 0x38, 0x0E, 0x1E, 0x36, 0x66, 0xFE, 0xC6, 0xC6, 0x00, 0x0E, 0x1E, 0x26, 0x66, 0xFC, 0xC6,
  0xFE, 0x00, 0x0E, 0x1E, 0x32, 0x60, 0xC0, 0xC2, 0xFE, 0x00, 0xE0, 0xF0, 0xD8, 0xCC, 0xC6, 0xCE,
  0xFC, 0x00, 0x0E, 0x1E, 0x30, 0x60, 0xFC, 0xC0, 0xFE, 0x00, 0x0E, 0x1E, 0x30, 0x60, 0xFC, 0xC0,
  0xC0, 0x00, 0x0E, 0x1E, 0x32, 0x60, 0xCE, 0xC2, 0xFE, 0x00, 0x26, 0x82, 0x66, 0x05, 0xFE, 0xC6,
  0xC6, 0x00, 0x1C, 0x78, 0x83, 0x18, 0x1D, 0x1C, 0x30, 0x0E, 0x1C, 0x0C, 0x0C, 0x4C, 0xCC, 0xFE,
  0x00, 0x26, 0x66, 0x6C, 0x78, 0xFC, 0xCE, 0xC6, 0x00, 0x70, 0xE0, 0x60, 0x60, 0x62, 0x66, 0xFE,
  0x00, 0x46, 0xEE, 0xFE, 0xD6, 0x82, 0xC6, 0x32, 0x00, 0x42, 0xC6, 0xE6, 0xF6, 0xDE, 0xCE, 0xC6,
  0x00, 0x1C, 0x3E, 0x66, 0xC6, 0xC6, 0xCC, 0x78, 0x00, 0x0E, 0x1E, 0x36, 0x66, 0xFC, 0xC0, 0xC0,
  0x00, 0x1C, 0x3E, 0x66, 0xC6, 0xD6, 0xDC, 0x77, 0x00, 0x0E, 0x1E, 0x36, 0x66, 0xF8, 0xCC, 0xC6,
  0x00, 0x0E, 0x1E, 0x32, 0x60, 0xFE, 0x06, 0xFE, 0x00, 0x7E, 0xFC, 0x83, 0x30, 0x02, 0x38, 0x60,
  0x26, 0x82, 0x66, 0x04, 0xE6, 0xC6, 0xFE, 0x00, 0x26, 0x82, 0x66, 0x22, 0xE6, 0x6C, 0x38, 0x00,
  0x62, 0xC6, 0xC6, 0xD6, 0xFE, 0xEE, 0xC4, 0x00, 0x26, 0x66, 0xEC, 0x38, 0x7C, 0xEE, 0xC6, 0x00,
  0x26, 0x66, 0xEC, 0x38, 0x18, 0x18, 0x1C, 0x30, 0x3E, 0x66, 0xCC, 0x18, 0x32, 0x66, 0xFE, 0xFE,
  0x00, 0xFE, 0x00, 0xFE, 0x00, 0xFE, 0x00, 0xFE, 0x00, 0xFE, 0x00, 0xFE, 0x00, 0xFE, 0x00, 0xFE,
  0x00, 0xFE, 0x00, 0xB2, 0x00, 0xFF};
const byte gtsCOLOR[] = {
  0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE,
  0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE,
  0x41, 0x8F, 0x41, 0xFF};
void main(void)
 set_snd_table(snd_table);
 screen_mode_2_text();
 paper(0xc);
 rle2vram (gtsPATTERN,0x0000);
 rle2vram (gtsCOLOR,0x2000);
 rle2vram (gtsNAME,0x1800);
 duplicate_pattern();
 cls();
 screen_on();
 print_at(1,1,"PRESS 1, 2, 3 OR 4");
 enable_nmi();
 loop:
  if(keypad_1==1){
   disable_nmi();
   print_at(1,2,"BOUTON 1");
   play_sound(1);
   enable_nmi();
  if(keypad_1==2){
   disable_nmi();
   print_at(1,2,"BOUTON 2");
   play_sound(2);
   enable_nmi();
  if(keypad_1==3){
   disable_nmi();
   print_at(1,2,"BOUTON 3");
   play_sound(3);
   play_sound(4);
   enable_nmi();
  if(keypad_1==4){
   disable_nmi();
   print_at(1,2,"BOUTON 4");
   //play_sound(5);
   play_sound(6);
   enable_nmi();
 delay(1);
 goto loop;
void nmi(void) {}
These codes work before the crash.
  • 3 months later...
