Mclaneinc Posted June 28, 2020 Share Posted June 28, 2020 (edited) Cut up the only SIO cable I had thinking I had a spare couple and I'd seen 2 SIO2USB lead heads only.. I can solder a couple of leads together to make one but is it pin 1 to pin 1 etc etc etc ie can I just match up the wire colours. (yellow to yellow etc) or do are the heads wired to different pins on one end Just looked at all the 'heads' and the same colours are seen in the same pins so I am pretty sure I can just match the colours....I'll await a confirmation.. Edited June 28, 2020 by Mclaneinc Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted June 28, 2020 Share Posted June 28, 2020 SIO cables are straight through. Colors may or may not be standard even among cables made by the same manufacturer. If you're just soldering back together a single cable you cut apart, then matching colors is fine. Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted June 28, 2020 Author Share Posted June 28, 2020 Thank you Doc, here all the colours on the heads match both colour and pin number used...Was getting myself mixed up with the pin numbers on the plug and the socket....So as its just making the SIO cable whole again then colour matching is fine...For a last double check with you? Quote Link to comment Share on other sites More sharing options...
ivop Posted June 28, 2020 Share Posted June 28, 2020 (edited) You could unscrew the connector, look at the colors left to right and the row below it. Write it down. Screw it back together. Do the same with the other connector. If the colors match, you are good to go! Edited June 28, 2020 by ivop Quote Link to comment Share on other sites More sharing options...
Mathy Posted June 28, 2020 Share Posted June 28, 2020 Hello Paul 7 hours ago, Mclaneinc said: ... 2 SIO2USB lead heads only.. As opposed to 2 SIO2RS232 lead heads? (Sorry) Sincerely Mathy Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted June 29, 2020 Author Share Posted June 29, 2020 Thanks people, all done, works fine, all the sockets / plugs were the same colours and pins so matched the colours and bingo... Now I can see my SIO splitter in all its shiny glory 3 Quote Link to comment Share on other sites More sharing options...
Awch Posted June 29, 2020 Share Posted June 29, 2020 Thanks for this thread. I'm just about to print some SIO connectors for AVG and new cables and was going to have to track this info down. Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted June 29, 2020 Share Posted June 29, 2020 1 hour ago, Awch said: Thanks for this thread. I'm just about to print some SIO connectors for AVG and new cables and was going to have to track this info down. The same information I mentioned above still applies - SIO cables are straight through: so pin 1 on one end corresponds with pin 1 on the other end, etc. But the same caveat applies as well: there’s no specific “color standard” for the conductors inside; as I understand it, Paul cut his cable in half and then repaired the same cable, so matching colors was logical and obvious. If he was soldering two separate cable halves together to make a whole, the fact that the colors matched is a happy accident, since there’s no guarantee that any two cables would use conductors with the same color insulation. 3 Quote Link to comment Share on other sites More sharing options...
