+MarcoJ Posted May 13, 2021 Author Share Posted May 13, 2021 5 minutes ago, devwebcl said: Congrats on the game. Are the levels the same as Pitman? Hi devwebcl, thanks a lot. Yes, the levels are the same at Pitman. And the passwords for that matter too. Have fun! 2 Quote Link to comment Share on other sites More sharing options...
xkenx Posted June 13, 2021 Share Posted June 13, 2021 Hi Marco, Thank's for a fantastic game Can get it to run on PlusCart + Atari 2600(4 switcher, Sunnyvale). Fails with the Harmony Encore. It fails on Atari 7800 with both PlusCart and Harmony Encore. Changed to e7, no diffrence. 1 Quote Link to comment Share on other sites More sharing options...
Prizrak Posted June 13, 2021 Share Posted June 13, 2021 Not sure what's going on, mine works on all my PlusCarts and my Harmony cart (non encore)Sent from my SM-G996U using Tapatalk Quote Link to comment Share on other sites More sharing options...
Bomberman94 Posted June 13, 2021 Share Posted June 13, 2021 5 hours ago, xkenx said: Hi Marco, Thank's for a fantastic game Can get it to run on PlusCart + Atari 2600(4 switcher, Sunnyvale). Fails with the Harmony Encore. It fails on Atari 7800 with both PlusCart and Harmony Encore. Changed to e7, no diffrence. Same - with my Atari 2600 light 6er PAL and Harmony most the time crashes and with PlusCard runs alway perfect. Quote Link to comment Share on other sites More sharing options...
+MarcoJ Posted June 13, 2021 Author Share Posted June 13, 2021 5 hours ago, xkenx said: Hi Marco, Thank's for a fantastic game Can get it to run on PlusCart + Atari 2600(4 switcher, Sunnyvale). Fails with the Harmony Encore. It fails on Atari 7800 with both PlusCart and Harmony Encore. Changed to e7, no diffrence. Hello, thanks for trying the game and the report. I think you are #4 that’s reported this issue. Does it make a constant droning tone when it fails? My theory at the moment is that the game draws more current than a normal game and subsequently causes an undervoltage glitch on some systems. On some users consoles, it will fail after the game plays for several minutes. cheers Marco Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted June 14, 2021 Share Posted June 14, 2021 10 hours ago, MarcoJ said: Hello, thanks for trying the game and the report. I think you are #4 that’s reported this issue. Does it make a constant droning tone when it fails? My theory at the moment is that the game draws more current than a normal game and subsequently causes an undervoltage glitch on some systems. On some users consoles, it will fail after the game plays for several minutes. cheers Marco So now we need a table of current draw for each 6507 opcode, and make sure we write our games within a power vs time budget 1 Quote Link to comment Share on other sites More sharing options...
+MarcoJ Posted June 14, 2021 Author Share Posted June 14, 2021 2 minutes ago, Andrew Davie said: So now we need a table of current draw for each 6507 opcode, and make sure we write our games within a power vs time budget Haha yeah. It is a wierd one. I wonder if it has something to do with writing a lot to the cart ram, especially in the first few frames of it turning on. Would also be interesting to see if adding some extra capacitance on the 5v rail helped, or cleaning cart connectors. It used to happen on ZPH’s console last year and then stopped after the console was replaced with another. Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted June 14, 2021 Share Posted June 14, 2021 12 minutes ago, MarcoJ said: Haha yeah. It is a wierd one. I wonder if it has something to do with writing a lot to the cart ram, especially in the first few frames of it turning on. Would also be interesting to see if adding some extra capacitance on the 5v rail helped, or cleaning cart connectors. It used to happen on ZPH’s console last year and then stopped after the console was replaced with another. Many many years ago I wrote a NES game that failed on just one of the 23 different variants of NES that Nintendo tested on. But only after the game had been running for a few hours. Imagine trying to find that one. They flew me to Washington and took me to a room where my game was running (and glitching). I said "that's a hardware problem" and they said "that's a software problem", and so I asked for some Freon and we sprayed it on the NES and my game started working properly again. It turned out to be the dynamic RAM in the NES was losing content right on the edge of the frequency I was refreshing it. Cool the machine down with freon, and that changed the data loss of the RAM and my program worked again. The solution was simple - refresh the RAM contents more frequently. Nintendo retired that particular model from "your game must run on this variant of our machine" after that issue; there were apparently only "3 or 4" of them in the entire USA anyway My point being, especially with the '2600, we're right on the edge of interacting with hardware which may very well be affected by heat, current variations and who knows what else. Look at the recent PlusCart 32-char glitching for example; I had a machine which I could cause to glitch at will just by applying IPA (cooling) or hairdryer (heating). 1 1 Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted June 14, 2021 Share Posted June 14, 2021 Have you thought about a programming error which does not fail on all consoles (like a missing '#') and is not emulated correctly by Stella? Quote Link to comment Share on other sites More sharing options...
+MarcoJ Posted June 14, 2021 Author Share Posted June 14, 2021 3 hours ago, Andrew Davie said: Many many years ago I wrote a NES game that failed on just one of the 23 different variants of NES that Nintendo tested on. But only after the game had been running for a few hours. Imagine trying to find that one. They flew me to Washington and took me to a room where my game was running (and glitching). I said "that's a hardware problem" and they said "that's a software problem", and so I asked for some Freon and we sprayed it on the NES and my game started working properly again. It turned out to be the dynamic RAM in the NES was losing content right on the edge of the frequency I was refreshing it. Cool the machine down with freon, and that changed the data loss of the RAM and my program worked again. The solution was simple - refresh the RAM contents more frequently. Nintendo retired that particular model from "your game must run on this variant of our machine" after that issue; there were apparently only "3 or 4" of them in the entire USA anyway My point being, especially with the '2600, we're right on the edge of interacting with hardware which may very well be affected by heat, current variations and who knows what else. Look at the recent PlusCart 32-char glitching for example; I had a machine which I could cause to glitch at will just by applying IPA (cooling) or hairdryer (heating). Wow, that's fascinating that temperature might affect it and be "on edge" ready to spuriously glitch. I tend to think that's what happens, temperature or current fluctuations. Quote Link to comment Share on other sites More sharing options...
+MarcoJ Posted June 14, 2021 Author Share Posted June 14, 2021 2 hours ago, Thomas Jentzsch said: Have you thought about a programming error which does not fail on all consoles (like a missing '#') and is not emulated correctly by Stella? Hi Thomas, This has crossed my mind a few times. I do wish it is something that simple. In the early days quite a few of those programming errors of reading zero page addresses instead of immediate values were found, one spectacular rolling one by omegamatrix. There's a few anecdotes that has lead me to think it's something temperamental like undervoltage or thermal glitches. There's been about 4 reports of the failure. 1. ZPH's old system from last year would be able to load the game and play for several minutes. After a few levels it would stop working. The place it would fail was variable. What's more, the system wouldn't be able to play other games/load harmony for a few minutes. It could then play Pitkat again but would fail after a few levels. If the console was left for a long period it would play the game for the longest before glitching. It was like something thermal was at play. 2. There's been reports of the game working fine with Pluscart, but failing with Harmony with the console being common between them. The only difference I can think of is Pluscart might be pulling less current than a Harmony. This tells me the system processor is excluded from being a factor at play that will predictably react to unusual code, since both carts are executing or trying to execute the same code. I think perhaps the way to catch this might be for an enthusiastic owner of a console which exhibited the behaviour could try things like: Freeze/Heat components, add 5V capacitance, clean cart connectors. It would be fascinating to finally discover the heart of the issue. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted June 14, 2021 Share Posted June 14, 2021 1 hour ago, MarcoJ said: What's more, the system wouldn't be able to play other games/load harmony for a few minutes. Hm, that is indeed a good evidence. Now we should try to find out what code causes the problem, because there are a lot of other homebrews which do really a lot or RAM writing. 1 hour ago, MarcoJ said: There's been reports of the game working fine with Pluscart, but failing with Harmony with the console being common between them. There could be a difference (RIOT, TIA states) between the carts when entering your game. Or maybe there is a driver or CPU bug in the Harmony. I am just asking because I learned from my own experience that the root cause of 99.9% bugs sits between the ears. Quote Link to comment Share on other sites More sharing options...
+MarcoJ Posted June 15, 2021 Author Share Posted June 15, 2021 17 hours ago, Thomas Jentzsch said: There could be a difference (RIOT, TIA states) between the carts when entering your game. Or maybe there is a driver or CPU bug in the Harmony. I have wondered about this RIOT chip. It has some of the 32 registers that aren't listed and used in the generic VCS guides. I imagine some other computers might used them (edge detection?) Pitkat zeros all the zero page before starting so that takes care of TIA, but it doesn't try to zero the RIOT. I have wondered if maybe one of these gets into a bad state. What's your advice on dealing with the power on states of the RIOT chip? Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted June 15, 2021 Share Posted June 15, 2021 41 minutes ago, MarcoJ said: What's your advice on dealing with the power on states of the RIOT chip? I usually don't care, so I cannot give any help here. You only shouldn't assume any state at power on. 1 Quote Link to comment Share on other sites More sharing options...
xkenx Posted June 15, 2021 Share Posted June 15, 2021 On 6/13/2021 at 11:13 PM, MarcoJ said: Does it make a constant droning tone when it fails? Yes and the screen goes black. I have now also tested it on my Atari 2600 Vader(PAL). On this it works with both Harmony Encore & PlusCart. Regards Ken Quote Link to comment Share on other sites More sharing options...
+MarcoJ Posted June 15, 2021 Author Share Posted June 15, 2021 16 minutes ago, xkenx said: Yes and the screen goes black. I have now also tested it on my Atari 2600 Vader(PAL). On this it works with both Harmony Encore & PlusCart. Regards Ken Thanks for the feedback Ken. What is interesting about this failure, is that it generally fails at the same place - just after TIATracker has fetched the first note and the screen has begun writing for the first time. I have attached a test for your Sunnyvale NTSC console, can you please try it? This is a stress tester routine that continually plays video and should likely fail too. SIMPSONS E716k V2.bin Quote Link to comment Share on other sites More sharing options...
xkenx Posted June 15, 2021 Share Posted June 15, 2021 When selecting the game you see the Harmony logo and then the screen turns black with the "droning tone". The same thing happens when I run SIMPSONS E716k V2.bin /Ken Quote Link to comment Share on other sites More sharing options...
+MarcoJ Posted June 19, 2021 Author Share Posted June 19, 2021 On 6/15/2021 at 6:23 PM, xkenx said: When selecting the game you see the Harmony logo and then the screen turns black with the "droning tone". The same thing happens when I run SIMPSONS E716k V2.bin /Ken Thanks for the report Ken. I just got a Pluscart and found that Pitkat will only partially work on my Atari 7800. It makes it to the "Have you played Atari Today?" Screen and crashes. Also, The Simpsons rom also crashes immediately upon loading. However, on my NTSC 4 switcher all work fine. I will experiment with the 7800 and see what prevents it breaking. Cheers Marco Quote Link to comment Share on other sites More sharing options...
+MarcoJ Posted June 19, 2021 Author Share Posted June 19, 2021 OK, have the first results of tinkering with the 7800. 1. Tried increasing capacitance on the 5V rail, extra 220uF added. To rule out transient under-voltage. Did not change the result. 2. Tried powering the pluscart with USB 5V power, as well as the Atari 7800 with it's standard power, to try rule out undercurrent. Did not change result. Based on this result, it's seems unlikely the crash is caused by transient phenomena. Tried Pitkat R3 this time (tried R2 before). It is able to make it into a level, but moving a few spaces crashes the game. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted June 19, 2021 Share Posted June 19, 2021 Have you tried my Elite demo? It uses E7 bankswitching too. Quote Link to comment Share on other sites More sharing options...
+MarcoJ Posted June 19, 2021 Author Share Posted June 19, 2021 3 minutes ago, Thomas Jentzsch said: Have you tried my Elite demo? It uses E7 bankswitching too. Do you mean the Thargon demo? I tried that, and interestingly it does an "emulation exit" immediately upon loading. For Pitkat, it seems to always do this when pressing the left direction while in the game. However, when in the menus, using left and right is OK. I wonder if this is just a quirk of the 7800. I will test it on my 2600 next, expecting it will work OK. Quote Link to comment Share on other sites More sharing options...
+MarcoJ Posted June 19, 2021 Author Share Posted June 19, 2021 And yes, Thargon works just fine on the Atari 2600. Not sure if it's just *my* 7800, or if it's common to all. Most likely the former. Quote Link to comment Share on other sites More sharing options...
+MarcoJ Posted June 19, 2021 Author Share Posted June 19, 2021 Wow. Just tried the Elite Demo you pointed me to. It also emulation exits, but the Pluscart screen kernel gets messed up. Still functional though. Also shown in the video is how Pitkat also emulation exits when pressing Left in game. This is on a NTSC 7800. IMG_1280_x264.mp4 Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted June 19, 2021 Share Posted June 19, 2021 1 hour ago, MarcoJ said: Do you mean the Thargon demo? There is more than just a Thargon. 1 hour ago, MarcoJ said: I tried that, and interestingly it does an "emulation exit" immediately upon loading. Yes, with default developer settings it exits (IIRC a read from write port). 27 minutes ago, MarcoJ said: Wow. Just tried the Elite Demo you pointed me to. It also emulation exits, but the Pluscart screen kernel gets messed up. Still functional though. Looks like some initialization code is missing in the PlusCart for this case. Quote Link to comment Share on other sites More sharing options...
+MarcoJ Posted June 19, 2021 Author Share Posted June 19, 2021 9 minutes ago, Thomas Jentzsch said: Yes, with default developer settings it exits (IIRC a read from write port). Interesting. Is this function selective if it's run on a 2600 or a 7800? On my 2600, elite works on pluscart without going back to the menu. It's only on the 7800 that it does the emulation exit. Quote Link to comment Share on other sites More sharing options...
