Sign in to follow this
memelord
Retroarch: failed to open libretro core
whenever I load up a Neo Geo rom, or ANY core I downloaded, I get an error. here is the log for the Neo Geo core. I use a Raspberry Pi Zero with Lakka as the OS.
[ERROR] Failed to open libretro core: "/tmp/cores/mame2003_plus_libretro.so"
[ERROR] Error(s): /tmp/cores/mame2003_plus_libretro.so: wrong ELF class: ELFCLASS64
[ERROR] Failed to open libretro core: "/tmp/cores/fbalpha2012_neogeo_libretro.so"
[ERROR] Error(s): /tmp/cores/fbalpha2012_neogeo_libretro.so: wrong ELF class: ELFCLASS64
[INFO] Using content: /storage/roms/THEC64/retropie/roms/neogeo/galaxyfg.zip.
[INFO] arg #0: retroarch
[INFO] arg #1: /storage/roms/THEC64/retropie/roms/neogeo/galaxyfg.zip
[INFO] arg #2: -s
[INFO] arg #3: /storage/savefiles
[INFO] arg #4: -S
[INFO] arg #5: /storage/roms/THEC64/retropie
[INFO] arg #6: -c
[INFO] arg #7: /storage/roms/THEC64/retropie/RetroArch-0120-124945.cfg
[INFO] arg #8: -L
[INFO] arg #9: /tmp/cores/fbalpha2012_neogeo_libretro.so
[INFO] arg #10: -v
[INFO] Content ran for a total of: 00 hours, 00 minutes, 00 seconds.
[INFO] Unloading game..
[INFO] Unloading core..
[INFO] Unloading core symbols..
[INFO] Threaded video stats: Frames pushed: 25428, Frames dropped: 0.
[INFO] Set config file to : /storage/roms/THEC64/retropie/RetroArch-0120-124945.cfg
[INFO] RetroArch 1.8.4 (Git 9e25601a56)
[INFO] Redirecting save file to "/storage/savefiles/galaxyfg.srm".
[INFO] Redirecting savestate to "/storage/roms/THEC64/retropie/galaxyfg.state".
[INFO] === Build =======================================
[INFO] Capabilities:
[INFO] Built: Jan 20 2020
[INFO] Version: 1.8.4
[INFO] Git: 9e25601a56
[INFO] =================================================
[INFO] Loading dynamic libretro core from: "/tmp/cores/fbalpha2012_neogeo_libretro.so"
[INFO] [Environ]: SET_PIXEL_FORMAT: RGB565.
[INFO] Version of libretro API: 1
[INFO] Compiled against API: 1
[INFO] [Audio]: Set audio input rate to: 30000.00 Hz.
[INFO] [Video]: Video @ fullscreen
[INFO] [Video]: Starting threaded video driver ...
[INFO] [EGL] Falling back to eglGetDisplay
[INFO] [EGL]: EGL version: 1.4
[INFO] [EGL]: Current context: 0x1.
[INFO] [GL]: Found GL context: videocore
[INFO] [GL]: Detecting screen resolution 1360x768.
[INFO] [EGL]: eglSwapInterval(1)
[INFO] [GL]: Vendor: Broadcom, Renderer: VideoCore IV HW.
[INFO] [GL]: Version: OpenGL ES 2.0.
[INFO] Querying EGL extension: KHR_image => exists
[INFO] [GL]: Using resolution 1360x768
[INFO] [GL]: Default shader backend found: glsl.
[INFO] [Shader driver]: Using GLSL shader backend.
[WARN] [GL]: Stock GLSL shaders will be used.
[INFO] [GLSL]: Found GLSL vertex shader.
[INFO] Shader log: Compiled
[INFO] [GLSL]: Found GLSL fragment shader.
[INFO] [GLSL]: Linking GLSL program.
[INFO] Setting up menu pipeline shaders for XMB ...
[INFO] [GLSL]: Compiling ribbon shader..
[INFO] [GLSL]: Compiling simple ribbon shader..
[INFO] [GLSL]: Compiling snow shader..
[INFO] [GLSL]: Compiling modern snow shader..
[INFO] [GLSL]: Compiling bokeh shader..
[INFO] [GLSL]: Compiling snowflake shader..
[INFO] [GL]: Using 4 textures.
[INFO] [GL]: Loaded 1 program(s).
[INFO] : Using font rendering backend: freetype.
[INFO] [Video]: Graphics driver did not initialize an input driver. Attempting to pick a suitable driver.
[WARN] [udev]: Couldn't open any keyboard, mouse or touchpad. Are permissions set correctly for /dev/input/event*?
[INFO] [udev]: Plugged pad: MY-POWER CO.,LTD. 2In1 USB Joystick (3727:3) on port #0.
[INFO] [Autoconf]: 306 profiles found.
[INFO] [udev]: Pad #0 (/dev/input/event0) supports force feedback.
[INFO] [udev]: Pad #0 (/dev/input/event0) supports 16 force feedback effects.
[INFO] [Joypad]: Found joypad driver: "udev".
[WARN] [udev]: Full-screen pointer won't be available.
[INFO] [Video]: Found display server: null
[INFO] Found shader "/tmp/shaders/bilinear.glslp"
[INFO] Found shader "/tmp/shaders/nearest.glslp"
[INFO] Found shader "/tmp/shaders/slang-conversion-template.glsl"
[INFO] Found shader "/tmp/shaders/stock.glsl"
[INFO] ALSA: Using signed 16-bit format.
[INFO] ALSA: Period size: 384 frames
[INFO] ALSA: Buffer size: 1536 frames
[INFO] [Menu]: Found menu display driver: "gl".
[INFO] [Autoconf]: selected configuration: /tmp/joypads/udev/MY-POWER_CO__LTD__2In1_USB_Joystick.cfg
how can I fix this? or is it something beyond my control because god hates me.
also, all the cores I downloaded/added do not work. the built in ones do. why? does this problem even exist? what am I doing wrong?
so, I figured out I was downloading the wrong cores. so I switched over to the ARMHF and ARMV7. those cores just reboot the console instead of running. how does that happen?
