Kchula-Rrit Posted July 20, 2020 Share Posted July 20, 2020 I've been mulling this idea for a while to power a TI. I have several 19V power bricks, including some 12V car adapters, from deceased laptops. If I could set a ground at +6V relative to the negative lead, I could use a LM7905 to generate the -5V. The +6V "ground" would give me 13V to feed a LM7812 to give me +12V, and a LM7805, maybe through a dropping resistor, to get +5V. A diode bridge would drop the voltage, hopefully without generating so much heat. Do power bricks have floating outputs? K-R. Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted July 20, 2020 Share Posted July 20, 2020 Is 13V enough headroom for the 7812? Quote Link to comment Share on other sites More sharing options...
Kchula-Rrit Posted July 20, 2020 Author Share Posted July 20, 2020 Good point. I think the 78XX/79XX requires a couple of volts difference between input and output to work. Sigh. If I could find a +12V to -5V converter, that would take care of the headroom problem. I'm poking around the Digi-Key site anyway, so I can take a look... K-R. Quote Link to comment Share on other sites More sharing options...
wierd_w Posted July 20, 2020 Share Posted July 20, 2020 https://www.mouser.com/datasheet/2/405/slts037a-206022.pdf Looks like it would have more than enough oomph, and do exactly what you need. Just a bit bulky/pricey. However, proof that such things do exist. Quote Link to comment Share on other sites More sharing options...
jens-eike Posted July 20, 2020 Share Posted July 20, 2020 The QI power supply (with 2 wires in) works from 18V DC. 1 Quote Link to comment Share on other sites More sharing options...
+FarmerPotato Posted July 20, 2020 Share Posted July 20, 2020 13 hours ago, Kchula-Rrit said: I've been mulling this idea for a while to power a TI. I have several 19V power bricks, including some 12V car adapters, from deceased laptops. If I could set a ground at +6V relative to the negative lead, I could use a LM7905 to generate the -5V. The +6V "ground" would give me 13V to feed a LM7812 to give me +12V, and a LM7805, maybe through a dropping resistor, to get +5V. A diode bridge would drop the voltage, hopefully without generating so much heat. Do power bricks have floating outputs? K-R. Take a look at TI’s line of LDO voltage regulators. They come in a wide variety of capacities and features like low ripple. Use an op amp in inverting configuration. This gives you a virtual ground and Vout = -Vin 1 Quote Link to comment Share on other sites More sharing options...
Kchula-Rrit Posted July 26, 2020 Author Share Posted July 26, 2020 On 7/20/2020 at 10:15 AM, FarmerPotato said: Take a look at TI’s line of LDO voltage regulators. They come in a wide variety of capacities and features like low ripple. Use an op amp in inverting configuration. This gives you a virtual ground and Vout = -Vin I found a LM675 power op-amp on the Digi-Key Web site. It puts out 3 amps. Have to order a few for experiments. They also stock regulators that have a 0.75V drop-out. K-R. Quote Link to comment Share on other sites More sharing options...
Kchula-Rrit Posted October 20, 2020 Author Share Posted October 20, 2020 An update on the power-supply-- Here is a picture of my battery-powered TI99, affectionately known as Tortoise. Not exactly a car battery; I used a 5A-Hr lithium-ion battery to run the CPU, and a 2.6A-Hr lithium-ion battery to run the monitor. The black box contains the battery and DC converters to run the CPU and monitor. The other picture is a close-up of the battery box. The two connectors are billed as speaker connectors for high-powered audio amps. I figured, if it's good enough for the Who, it should handle my little computer. A 19V power brick recharges the batteries, but the charger will handle 5V to 24V. K-R. 6 Quote Link to comment Share on other sites More sharing options...
