Keatah Posted July 24, 2020 Share Posted July 24, 2020 That's ok. You can ask questions to help you figure it out. If that's what you really want to do. Quote Link to comment Share on other sites More sharing options...
juansolo Posted July 24, 2020 Share Posted July 24, 2020 (edited) Set it up on a shelf, plug it into a strip that has a power connector so you can turn off whatever is connected to the strip without unplugging it. Throw a cloth over it when it's not in use. Sticking it in a box seems an overly complicated (and potentially harmful) solution to a very simple problem... Edited July 24, 2020 by juansolo 1 Quote Link to comment Share on other sites More sharing options...
jhd Posted July 24, 2020 Share Posted July 24, 2020 I do not have a 7800, but I do have a 2600. To avoid excess wear and tear on the hardware, I keep it in a storage facility located some 2,500 miles away from where I live. For greater certainty, the keys to the facility are held by a third-party. It is the classic trade-off between convenience and long-term preservation. I have opted to emphasis preservation. Quote Link to comment Share on other sites More sharing options...
fiddlepaddle Posted July 25, 2020 Share Posted July 25, 2020 Just a bit of anecdotal observation: I have, many times, seen AC plugs that are "worn out", not because the metal has worn away, but because each insertion puts stress on where the 2 or 3 metal pins get wobbly, or one even comes off. And any electrician will tell you that electric sockets wear out; they usually become loose and don't hold the plug, or get dusty/dirty enough to cause problems. No matter how many insertions/removals a particular male/female plug combination is rated for, that's only true for ideal conditions, which do not match conditions where human beings, or even gamers, are involved... a small tremor in the fingers every time while inserting or removing those barrel plugs, for example, can reduce their life to a mere dozens of times before failure. And you also might consider that 30 year old plastic and solder joints also become more fragile. Quote Link to comment Share on other sites More sharing options...
Shawn Posted July 26, 2020 Share Posted July 26, 2020 On 7/23/2020 at 8:20 PM, Keatah said: Sometimes it even forms a bandwagon. And that makes a whole thread or even the whole forum lowbrow. I've always wanted to see Mjolnir crush a 10 digit numeric sequence through the trippletopped roadrunning Keatah filled bandwagon! 1 Quote Link to comment Share on other sites More sharing options...
Keatah Posted July 26, 2020 Share Posted July 26, 2020 That would be a sight to see, no doubt. Quote Link to comment Share on other sites More sharing options...
hizzy Posted July 28, 2020 Share Posted July 28, 2020 Best Electronics sells an improved AC cable, if that interests you: http://www.best-electronics-ca.com/New Best 7800 Power supply.htm Quote Link to comment Share on other sites More sharing options...
