lotharek
SIDE 3 preorder
On 10/7/2020 at 1:26 AM, Roydea6 said:
The only complaint is the BRIGHT green LED...  I might have to put a black label over the LED window.
I agree with you Roy, having just received my production cart. It is impossible to make out the red HDD activity LED when the green one is lit. The pending loader update therefore turns the green LED off by default and just flashes it when the SD card has been removed.
Edited by flashjazzcat
Yesterday I received the cart.
I agree on the fact the green led should be turned off.
On 600/800XL machines it's really annoying.
I am glad it could be done with an update.
I didn't have the time to test the cart yet but I noticed some CAR don't work.
I am sure the compatibility will improve with updates.
4 minutes ago, Philsan said:
I didn't have the time to test the cart but I noticed some CAR don't work.
Compatibility may improve if you tell us what CAR files don't work. ;)
Yes, I tested files and reported issues for AVGCart, I will do the same with Side 3 too.
Hello folks,
My Side3 was crushed by the carrier 😭
Is there a .STL file somewhere for my 3D printer ?
Thanks.
  • Sad 4
22 minutes ago, Marsupilami said:
Hello folks,
Thanks.
Have you un-cased it and checked it still works ?
It might be worth asking Lotharek if he has a spare shell when he gets back from his vacation.
Yes, It work perfectly (fortunately).
Yes i did it yesterday...but He took loooong vacations :)
  • Haha 1
29 minutes ago, candle said:
IGS to STL conversion can be done with FreeCAD, also you can make all nessesary modifications there.
Thanks, yes i could indeed..but i wanted to know if the model for Side3 was already available (without having to modify an existing shell model).
I'll wait until Lotharek is back then :)
all cases are milled and stencil-printed by maszczyk, custom colours are aslo available when making bulk orders
all you can do for 1.43 euro is to have stock replacement case that you need to CNC mill or cut with a file
but it's better than nothing
Pleased to hear news of SIDE3 orders reaching the four corners of the globe. Here's someone form Antarctica testing theirs:
  • Haha 10
Holy crap, he took a vacation?  I mean I don't think he actually sleeps, so that is amazing he took some time.
I received my Side3 and I notice the loader has some issues. I have a standard collection of games I put on my other Side carts. It's a 68 MB collection of about 3,000 games. The top directory has 61 directories. The side loader only shows about 1/2 of them. Sometimes on a restart it will show them all but as I navigate and return to the top it's back to 1/2. Each directory contains about 50 or so .xex files. Sometimes I only see about 1/2 of those as well.
Frank
That sounds like an IO error. The loader has been tested with directories containing 800+ filenames and no issues found. The most common reason for a directory to be truncated is when a bogus end of directory marker is found.
That said: if you can image the card, I will gladly test it here. If you have a different SD card, you could perhaps test it with a similar density of filenames.
To para quote the tramp at the start of the Terminator, "That's a real bright led"..
Not as beautiful as the real one but until Lotharek's return it will be enough :)
+ I added some space in the shell for the push button.
Edited by Marsupilami
  • Like 4
@flashjazzcat should I start tests or is it better to wait your upcoming new firmware?
22 minutes ago, Philsan said:
Should I start tests or is it better to wait your upcoming new firmware?
Entirely up to you Phil: I am sure any information you provide will be helpful, and I hope to release the update tonight or tomorrow morning. I will list all bug fixes when I release the update, but as far as cartridge types are concerned, only Sic! has been subject to fixes. The change Candle eventually suggested for Sic! - although it seemed to work at first sight - was actually only half the story, and I just spent the last hour finding the second bug in Sic! emulation (namely, one which prevented ROM at $A000-$BFFF being disabled at all: well spotted... not). Fortunately, since I was able to figure that one out myself, the update will be out in hours rather than days. ;)
Sincere thanks to Pawel Mandes for reporting the initial issue and testing updates at short notice.
I used a different card and re-copied the files and all is working!
Nice one: I knew it. :) Thanks for confirming. What kind of card is the problematic one? I guess we're gonna have to compile a list of to-be-avoided media.
