jacobus
Need help with an assembly copy routine
On 8/11/2020 at 9:15 PM, jacobus said:
in answer tour questions:
   -I do not cross page bountries
Why you don't just use the Quick-Command
FMOVE (Q,Z,L)
for that...?
FMOVE (Q,Z,L)
for that...?
Tried that 🙂 It fails in the VBI.
In the documentation the function is tagged with an 'x', which means you have to save the status with
IPUSH
ZPUSH
FMOVE(Q,Z,L)
ZPULL
IPULL
in the IRQ first.
Still doesn't work?
Otherwise you could even use the 'PLAYER()' command for copying, which isn't tagged with 'x' and doesn't need the PUSHs/PULLs from above...
Did nothing with Quick for ages, but I remember VBI (and DLI) should be short code only. Maybe your code runs to slow and thus the function doesn't work.
Try if it runs in main programme endless loop to be sure if this is the problem.
