tschak909
#FujiNet Testing and Bug Reporting Thread
1 minute ago, NISMOPC said:
Just an update on my issues above. Apparently, they resolved themselves. 🤪
I am not quite sure what corrected this, but here are a few things I recently did. Re-arranged my "Atari" room. Moved my shelving with my CRT TV, Atari 7800, Atari Video Music and carts to other side (right side instead of left), but left my 8-bit set-up alone. Same power supply, same S-video cable, same location, etc.
I updated the firmware yesterday to the latest version and removed the USB power to FujiNet.
All I can say is WOW! Picture quality is super clean. There are no drops in power with FujiNet being powered off 130XE. I am confused and overjoyed at the same time...
Not the best pictures and they do not do it justice.
IMG_20210208_113100772.thumb.jpg.892b7c15ee63bea34c8da0f00ff1a420.jpgIMG_20210208_112940582.thumb.jpg.da3ebbef2a08fed6ace14cafe3eeb348.jpgIMG_20210208_112925684.thumb.jpg.eba6585f66ad339f65a93d512897a3ef.jpg
just wait, until you throw a UAV in there. ;)
-Thom
-Thom
It's on my list of possible to do's along with the potential cherry MX keyboard drop in replacement...
I'm getting an Error 130 in BASIC when trying to access N:
I'm using the commands from the Fujinet "N: Has a JSON Parser!" video (bottom of email).
Atari 800 - Incognito - SpartaDOS X (w/Fujinet utilities) - (recent ROM flash on Fujinet).  I boot to SD X;  type 'BASIC',  then run both commands in the video:
DIM A$(99)
OPEN #1,12,3,"N:HTTPS://JSONPLACEHOLDER.TYPICODE.COM/todos/1"
then receive ERROR-   130
(I receive the error regardless of whether I just try to open N: with no internet addresses or with the full type out above)
Any recommendations?  My goal is to see it work and then write a stock symbol/price lookup program (using JSON) as something to do on the Atari..  Thanks :)
53 minutes ago, tschak909 said:
@Xebec if you don't load the handler (NDEV.COM), you don't get the N: device. ;)
-Thom
LOL - Duh - that worked - thank you :)
I am now getting occasional hangs on the XIO read/write commands (either they work immediately or they time out eventually with Error 138) but will mess around later today to see what's going on.   Thanks again for this wonderful device!
the only stable protocol adapters are TCP and UDP, the rest, are...very much in flux, for example, I am in the middle of doing a massive debug on the HTTP adapter (which is _EXTREMELY_ complex, has a lot of internal states that have to be properly abstracted)
-Thom
I'm currently experimenting with the FNC tools and the SIO API.
After using FEJECT to eject a drive, a following DIR to this drive resets the Fujinet cart and all drives are unmounted. Is this a bug in FEJECT (or the $E9 command)?
Can you give me a list of steps to reproduce?
-Thom
1) Boot a DOS (e.g. XDOS)
2) Mount an ATR (from tnfsd.exe) to drive 7 (or any other drive), if not already mounted
3) FEJECT 7
4) DIR D7:    -> this resets the Fujinet cart and unmounts all drives
The delightful (and gorgeous!) new game Albert does not load via FujiNet. However, it loads up perfectly via the XEL-CF loader in my 1088XLD. It will seem to load but crash with corrupted graphics all over the screen and screeching audio garbage. However, as noted, it will load perfectly via the Jon's Loader. I have not tested it via RespeQT and my SIO2PC device. If you want to try to reproduce, the game is PAL-only.
EDIT: DISREGARD! For some inexplicable reason, the game is now loading and running from my FujiNet fine tonight. I have no clue why it's behaving differently, but I didn't do a darn thing different testing tonight than the half-dozen or so attempts I made last night.
That check was never meant to lock a program out, it was meant to allow the proper version of a game or portion of code to run with a caveat that a cartridge might display that it won't run on such and such system if the wrong OS or PAL/NTSC system were detected.. but today... the carts and banking methods negate almost any need for that either
The check seems to only get used for locking out these days...the opposite of it's intended purpose..
Edited by _The Doctor__
Have you used the platoterm that's on atari-apps.irata.online? this uses the N: device, and is as fast as it possibly can be.
-Thom
hey @Kyle22, do you still have the issue where if the sd card is in the wifi tells you to jump in a lake?
take the sd card out and everything is fine...
is it possible fujinet wants the SD card in a certain FAT type to read the config files for wifi and then gets lost if it isn't there in the format it desires?
maybe @tschak909 can chime in.... I must have missed if it has a need/preference for a fat type when skimming for an answer.
I have tried everything I can think of at this point. With SD card in I can use CP/M. Without the card I can use WiFi.
Delete the fnconfig.ini file from the card, and try reconfiguring fujinet.
-Thom
-Thom
I did and it made no change.
Ok, I am going to keep reiterating, please, guys, listen and listen well:
When you have "Something doesn't work"
Can you please, ... PLEASE.... Load up the FujiNet flasher, start up the debugging monitor, and cut and paste the information emitted when the problem occurs?
-Thom
Remove card from fujinet, Delete fnconfig.ini from the card, keep card out of fujinet. Power up fujinet while holding button B. This will wipe the config from the internal storage also.
Then reinsert sd card and try again
Will this work on XP?
  • Haha 2
I'll try it tonight.
I deleted fnconfig.ini, power off booted while holding B button and it worked. Rebooted again it did NOT work. I had to delete the file again and hold B on power up for it to work.
I don't have debug output because I forgot to bring my live boot DVD so I can't fun the flasher.
