Charlie_
Wanted: 7800 console. Working or not.
Posted (edited)
I really need a7800 for the bottom half of the case. I cracked mine doing an av mod. That's what I get for taking shortcuts.
I'm looking to buy a dead system for the case, or a working system with power supply. I'll mod it and keep my current as a backup. It actually glued together well...
Thanks for reading, let me know if anyone has the above for sale.
Edited by Charlie_
6 hours ago, amiman99 said:
I cracked mine too, I think the plastic is super brittle.
I have a dead system on the way to use the case. This time I have a plastic drill bit with no rake so it doesn't pull up on the plastic. We'll see......
The secret to drilling into the plastic on these old consoles (Especially the 7800 and 5200) is to use either a step drill bit, or in my case I use a 1/16 standard bit to make a pilot hole and then I have exact size forstner bits to make the actual holes with. The forstner bits will cut into the plastic in a smooth wide pattern. As such they take longer to get through the plastic and will create a lot of debris but if you take it somewhat slot and steady, it will make a nice clean hole without damage to the plastic. I've only had one 7800 case sorta crack on me and that was before I had the right size forstner bit. I used to use the 1/16 bit, then use a 1/2" forstner, and then used a larger actual size larger drill bit to widen the 1/2" hole. But it would sometimes grab on one side too much and make the hole off center in the process or take off too much and crack a bit. But with forstners it hasn't been an issue.
