+dhe Posted August 11, 2020 Share Posted August 11, 2020 I ordered one of the new AMS / TIPI cards, so I should have a standalone 32k unit. Does anyone have files for a case, for just the 32K unit? Thanks, Dan 1 Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted August 11, 2020 Share Posted August 11, 2020 You can order this case << HERE >> 2 hours ago, dhe said: I ordered one of the new AMS / TIPI cards, so I should have a standalone 32k unit. Does anyone have files for a case, for just the 32K unit? There are files at Thingiverse for a case for both the 32K & the TIPI units combined by @jedimatt42 << HERE >> but no public domain single 32K case that I know of. I included a place to purchase a really nice and affordable one above due to the lack of a downloadable STL file. Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted August 12, 2020 Share Posted August 12, 2020 I believe AMS already provides 32k, which would conflict with stand alone 32k! Are you sure you need the stand alone 32k? Quote Link to comment Share on other sites More sharing options...
GDMike Posted August 12, 2020 Share Posted August 12, 2020 (edited) Yes that's true. Mine does. Good catch. Edited August 12, 2020 by GDMike Quote Link to comment Share on other sites More sharing options...
RickyDean Posted August 12, 2020 Share Posted August 12, 2020 Yes the sam's has 32k right from the box, or soldering iron tip, if you build it yourself. Quote Link to comment Share on other sites More sharing options...
+dhe Posted August 12, 2020 Author Share Posted August 12, 2020 Since I'm updating to the AMS TIP BOARD (with built in 32K) - I will have this spare board now, that I wanted to use as a test device. I've always liked having my electronics in a box, unless they are being worked on. d. Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted August 13, 2020 Share Posted August 13, 2020 Since I'm updating to the AMS TIP BOARD (with built in 32K) - I will have this spare board now, that I wanted to use as a test device. I've always liked having my electronics in a box, unless they are being worked on. d. You are confused that is not a ams board just combo 32k and tipi. It drops in to a speech synth caseThe only jedimatt 32kb sidecar case out there is the corei64 one at least at this time. The same case works for the sidecar Sams board.GregSent from my LM-V600 using Tapatalk Quote Link to comment Share on other sites More sharing options...
+dhe Posted August 13, 2020 Author Share Posted August 13, 2020 https://www.arcadeshopper.com/wp/store/#!/Sidecar-SAMS-with-44pin-header-for-TIPI/p/176285041 So this doesn't mate with a tipi? Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted August 13, 2020 Share Posted August 13, 2020 https://www.arcadeshopper.com/wp/store/#!/Sidecar-SAMS-with-44pin-header-for-TIPI/p/176285041 So this doesn't mate with a tipi?Yes it does and it goes in the same case as the 32k it's the same size. I was confused when you said combo as that's what the other board is called that has both 32k and TIPI on one board Sent from my LM-V600 using Tapatalk Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted August 13, 2020 Share Posted August 13, 2020 I sell this case for the sidecar memory and TIPI setup https://arcadeshopper.ecwid.com/products/111996038Sent from my LM-V600 using Tapatalk Quote Link to comment Share on other sites More sharing options...
+dhe Posted August 13, 2020 Author Share Posted August 13, 2020 Right so I take my existing TIPI + 32K, pull the 32k and replace with AMS goodness. Then I have a 32K sidecar unit. Which is Ok.. I was wanting to try some things like Mack McCormicks Slow Down Circuit that used to go in a speech syntezier case, but the 32k unit might be easier, because all the bus pins are more easily exposed.... 1 Quote Link to comment Share on other sites More sharing options...
+dhe Posted August 14, 2020 Author Share Posted August 14, 2020 Let me follow up, i think a good route for my playing would be to purchase some protoboard and plug it in to the side of the 32k board. Arcadeshopper do you know what part, I'd need to get that would allow me to plug in to the 44 pin connector on the side? Thanks! Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted August 14, 2020 Share Posted August 14, 2020 A 44 pin female IDC connector I haven't found any that size so I just cut down a pi headerSent from my LM-V600 using Tapatalk Quote Link to comment Share on other sites More sharing options...
+dhe Posted August 14, 2020 Author Share Posted August 14, 2020 does the stand alone 32k need power? If it gets power then can it power circuits on the protoboard I plan on adding to it's side? Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted August 14, 2020 Share Posted August 14, 2020 It doesn't but it also doesn't pass through without external powerSent from my LM-V600 using Tapatalk Quote Link to comment Share on other sites More sharing options...
+dhe Posted August 14, 2020 Author Share Posted August 14, 2020 is there a schematic? Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted August 14, 2020 Share Posted August 14, 2020 is there a schematic? Yup it's all in GitHub it's an open source design Sent from my LM-V600 using Tapatalk Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted August 15, 2020 Share Posted August 15, 2020 If you want the 32k board to pass power from the console to the 5v pin on the header expansion, just bridge the 3 jumpers for the TI/Ext power selection.. or if there is a switch there, bridge it... The schematic data file for the 32k is in some proprietary software, but there is a PDF somewhere... The schematic PDF is here: I don't have the data file for that anymore... the pcb layout was done in Robot Room copper connection, and it didn't base itself from a schematic, so the power rails aren't detailed... The robot room files are on my project page at jedimatt42.com Quote Link to comment Share on other sites More sharing options...
