Steve Guidi
NTSC/PAL Color and Clock Switcher Project?
Hello!  I'm wondering of anyone has investigated the feasibility of modding a 2600 so that you can switch between clock frequencies and/or color palettes.  The goal of such a project would be to play cartridges of differing regions on the same machine.
I've seen a similar project on a Commodore 16 where the clock crystal was replaced with an Arduino, the latter programmed to output different selectable frequencies to produce a signal for PAL and NTSC video.
As for the color palette, I believe that would require a swap of the TIA chip, which could be done manually if the board is socketed.
I haven't studied the schematic, and a cursory search doesn't show anything useful.  To anyone with the hardware experience, do these ideas seem sound?
My assumption is that the only difference between a PAL, NTSC, and SECAM 2600 are the clock crystal and TIA since the game cartridge does all the video synch.
Steve Guidi
Unfortunately, this is not as simple as I had hoped.  The TIA from NTSC and PAL systems are not pin-compatible.
(from https://amazingdiy.wordpress.com/2011/07/21/atari-2600-video-mod/)
