3do need help fixing
Ok so I just got a 3do off line and we'll it turns on but beeps. Is there anyone who knows what this means/ how you can fix it if possible?
I know on PC's they will do something like this if the memory isn't instead correctly... Could this be the case here ?
Edited by kevincondrick@gmail.com
Good new/ bad news I found  that afew vias eaten away I managed to fix them only to find that the console will turn on but shortly after fails again. I suspect that the ic400 chip was bad so I tested it wile power on and m...mm  I believe now I blown the video incoder chip.. bt9101 chip. .. so I'm in a pinch now
  • 4 weeks later...
Well I did end up finding a replacement for  bt9101chip. I replaced it with a bt858 and it worked so I'm assuming that they are inner changeable. For the beeping however I did suspect the s-ram chip I found that there some traces missing around it. I then repaired them and it seamed to fix the problem. So there for if anyone else has this problem I wold start by looking there
