JOD-I #1 Posted August 21, 2020 I just got a SGM off of ebay and at first everything was great. I followed the instructions in the instruction manual when it started not to work. I did a diagnostic and it tells me that ram 0000H-1FFFH: ERRORS FOUND. Is there nothing I can do? Quote Share this post Link to post Share on other sites
artrag #2 Posted August 21, 2020 replace the memory chip ? Quote Share this post Link to post Share on other sites
Kiwi #3 Posted August 21, 2020 Does the red power LED show up when inserted into the expansion port? Makes sure it in there. Otherwise, contact Opcode for support: Quote Share this post Link to post Share on other sites
Bmack36 #4 Posted August 21, 2020 (edited) 9 hours ago, JOD-I said: I just got a SGM off of ebay and at first everything was great. I followed the instructions in the instruction manual when it started not to work. I did a diagnostic and it tells me that ram 0000H-1FFFH: ERRORS FOUND. Is there nothing I can do? Are you using the Atarimax when you get the errors? Double check that the BIOS bypass is turned off by pressing the * key in the atarimax menu. Edited August 21, 2020 by Bmack36 3 Quote Share this post Link to post Share on other sites
JOD-I #5 Posted August 21, 2020 Bmack36 - You are awesome! yes I was, yes I did and after turning it off it worked! THANK YOU! Quote Share this post Link to post Share on other sites
