xrbrevin #1 Posted August 28, 2020 Can anyone give me any pointers as to how to diagnose a 400/800 RAM board? I have a 48k one and a 32k one and i feel ive done all that i can with them but I just keep getting the red/brown screen. ive checked traces for continuity where there should be and shorts where there shouldnt be. Ive checked the 4116 DRAMs work in a standard board and ive checked that the 4164 DRAMs work in an XL. The 48k one receives it's SEL4, SEL5, A14 and A15 connections from the Z103 socket (via a small piggyback PCB) and it also gets the RD4 and RD5 from the cartridge socket (via 2x wires). Does anyone know of a procedure for troubleshooting? Im wondering if the 74LS glue logic is at fault. cheers! Quote Share this post Link to post Share on other sites
mimo #2 Posted August 28, 2020 I'm no expert but there isn't much else on those boards to go wrong Quote Share this post Link to post Share on other sites
ClausB #3 Posted August 28, 2020 (edited) Yes, the 74LS chips, while generally durable, can go bad. If they're socketed, swap them out. Also check for shorted caps on the power busses. Use an ohmmeter between each bus and ground. Edited August 28, 2020 by ClausB Quote Share this post Link to post Share on other sites
cwilbar #4 Posted August 28, 2020 If you have a logic probe, you can probe the inputs and outputs of the 74LS chips to try to get an idea.... generally the data should be changing..... if you see something stuck high or low then you would focus in on those chips first when diagnosing. You may also run into neither high nor low.... (open). Unless the chip is a tri-state device, this would indicate something is wrong (if it is an output) (if it is an input, it simply may not be connected to anything). Quote Share this post Link to post Share on other sites
xrbrevin #5 Posted August 28, 2020 Thanks for the suggestions. I have a logic probe and the back of the RAM board is accessible so i'll have a mooch about. I thought maybe i would take a macro photo of the PCB and then zoom in on the computer to check if any traces are in amiss. On the 32k board I did some continuity testing across the DRAMS and all lines appear to be behaving as they should. All address lines are linked, -5v 12v 5v and GND are linked with no crossovers. RAS and CAS lines are linked but only on every other chip, i assume this is due to it being 2x16k on a single board. If the worst comes to the worst, i will salvage the 4116s and make my standard Atari RAM board into a 32k one. These '80s aftermarket PCBs dont have a silkscreen and the traces are less than robust!! Quote Share this post Link to post Share on other sites
+Nezgar #6 Posted August 28, 2020 A TL866 programmer can test function of LS logic chips with a few clicks if you're in the market for one. Otherwise the aforementioned methods are of course cheaper. Quote Share this post Link to post Share on other sites
xrbrevin #7 Posted August 29, 2020 I have a TL866 and ive occasionally used that feature. altho, it has never found a bad 74LS thus far so im unsure if its accurate... Quote Share this post Link to post Share on other sites
+DrVenkman #8 Posted August 29, 2020 4 hours ago, xrbrevin said: I have a TL866 and ive occasionally used that feature. altho, it has never found a bad 74LS thus far so im unsure if its accurate... It probably is - when I got my TL866, I tested it with a 4050 hex buffer that I know was bad (pulled from an 800XL video circuit that had lost color output). I also tested it with a couple 74-series logic chips I pulled from a damaged C64 a few years ago and it successfully ID’d the damaged gate. 1 Quote Share this post Link to post Share on other sites
