tschak909
#FujiNet - ATX Protection Edge Cases, Information needed
33 minutes ago, 8bitguy1 said:
How do I do that?  I read the github and the fujinet online site, but I can't seem to find where I'd output a log file?
When running the fujinet flasher, there is a button to show the debugging output. :)
This is the exact same image from post 21.  (longer filename, though the behaviour is the same with the shorter one).
Do you think a different SD card would make a difference?  I can't see why....
Thanks for the log @8bitguy1
I see in your log that there's an error reading off of SD:
[08:49:00]DiskTypeATX::_load_atx_data starting read
[08:49:00]E (103322) diskio_sdmmc: sdmmc_read_blocks failed (257)
[08:49:00]failed reading sector list chunk bytes (120, 5)
[08:49:00]WARNING: Number of tracks read = 29
[08:49:00]ATX load completed
Since it worked for me, I didn't notice that there's a similar but somehow different error in my own log when I tried it:
18:31:08.905 > DiskTypeATX::_load_atx_data starting read
18:31:09.030 > E (29223) diskio_sdmmc: sdmmc_read_blocks failed (257)
18:31:09.030 > failed reading 2304 sector data chunk bytes (368, 5)
18:31:09.031 > WARNING: Number of tracks read = 27
18:31:09.033 > ATX load completed
So that's something to dig into. Maybe we're getting a read error off of SD for some reason and ending up with potentially random data.
Thanks again for collecting the details!
I might have a related problem... I can't load anything in D2.  I posted that in the general bug thread, but I wonder if they are related.
To rule out SD card problems. I've tried both Kingston and Sandisk.
Happy to help and provide data...
So, I traced down the error we were all seeing:
Error 257 is an out of memory error.  Accessing the SD card requires creating DMA buffers that use base memory, and we were running out of this.  (This is why it didn't affect TNFS loads: those buffers aren't used in that case.)  I've made a change that should address that particular issue.  The update should be in the next firmware build.
Note that if the error is something other than 257, then it's a different issue.
  • Like 4
Happy to report with the latest firmware my issues have been resolved, including the Syncalc .atx loading issue when done from the SD Card.
Thanks again to everyone involved in this great device.
