jonesypeter
Modern ways to load software
I recently picked up a TI99 on eBay with extended BASIC and a speech synthesizer. My main interest has always been the ZX Spectrum (The machine I grew up with), but have always been intrigued by the TI.
With the Spectrum I'm used to having a multitude of cheap devices available to load emulator tape files via an SD card into a read Spectrum.
Having looked around, I can't see anything similar for the TI99. I understand to emulate a disk drive I would need the expansion box to get started.  Is there even software which would convert 'image' files of cassettes to a wav file so I can load that way?  I have heard about Tape994a as a possible solution but the download link seems to be broken.
http://www.99er.net/emutil.html
Sadly many of the sites I have found seem to have been abandoned (apart from http://www.ti99iuc.it/). Is there a list of sites which are still regularly updated?
Finally, is there anything available for the TI which allows me to type a BASIC program in notepad then convert to a tap file. Something similar to this:
https://derekbolli.wordpress.com/2012/11/16/create-zx-spectrum-basic-program-tap-file-from-text-source-file-in-bbedit-using-zmakebas/
Many thanks in advance.
Peter
Edited by jonesypeter
Peter
http://www.cs1er.com/
Course with a TIPI you can remove the cassette player from the loop and paste from a web page to a disk file..
https://www.arcadeshopper.com/wp/the-ti-raspberry-pi-connection/
Sent from my LM-V600 using Tapatalk
Thanks @arcadeshopper
I can't see the TiPi for sale on your shop.  Do you have a link?
Cheers
EDIT: Just seen it here:
https://www.arcadeshopper.com/wp/store/#!/TIPI-SIDECAR-Raspberry-PI-interface-board-*44pin-interface-port-required*/p/103690282/category=28815024
For a novice - Could you explain what else I would need to purchase?
Thanks [mention=25598]arcadeshopper[/mention]
Cheers
For that model you also need a memory card I sell both 32k and 1 MB memory cards that both work with the tipi sidecar. You'll also need a raspberry pi I recommend a three or four but you could use a zero w if need be.
there's also a combination board in stock that is both 32k and TIPI in one board. https://www.arcadeshopper.com/wp/store/#!/Combo-32k-TIPI-pcb/p/202179717
There should be options to add a pi to the order if you want to get one from me otherwise you can get one anywhere you'll also need an SD card for the pi for the software and your file saves and disks etc
Cheers
I just went through this process.  If you aren’t good at soldering, buy the PI-zero W from arcade shopper.  That is what I did just to make sure I wouldn’t do something wrong and damage the TIPI/32k.  With it you can save and load BASIC  programs and a few other things.  I think having extended BASIS will let you do more than I can.  I now have a FinalGROM99 on order from arcadeshopper.  That gives you the ability to run about any cartridge program you can find a file for, which is a lot.  If you add the loaded SD card from his store, as I did, you should be set.  With these two devices, there isn’t much you can’t do.  I have been having fun writing BASIC programs to learn the machine, but really look forward to receiving the FG99 so I can experience amore of it’s capabilities.
Edited by Keneg
Hey, can the TIPI load from a tape wav file??
No but you can play the wav on the pi and hook it to your cassette cable
For me the best solution for the TI-99/4A is FinalGROM 99. I love it.
For my Spectrum I have the DivIDE 2k14 and both work in the same way...
Thinking... Is it possible to use a Raspberry Pi and make a "connection cable" from the GPIO pins to the same place you connect the Speech synthesizer?
Do you mean the audio pins on the side port? Or something else
On the TIPI, you use the last 4 pins on the GPIO. I was wondering if everything could be simulated in the Raspberry Pi and then use a bigger cable IF needed.
Like 32 k ram should be able to simulate in the Raspberry Pi and everything else.
Not in the tipi it's just a serial communications line and a DSR to provide communication
for what you describe you probably have to design your own board
Yes, I have a DivMMC.  The FinalGROM only supports ROM Cartridges, yes?
Thanks for all the comments.
I'm happy to start this on a new topic if preferred for these linked questions.
I downloaded CS1 and looked at the PDF instructions. The format seems to be 'FIAD'?  Is there an archive of cassette games in this format that I can browse?
Secondly, I downloaded GameBaseTI and all the files are .dsk. Looking at the GitHub page for TiPi I'm guessing they are no good for it?
Cheers
EDIT: found files on http://tigameshelf.net/xb.htm
You could connect a PI, like the Pi Zero, directly to the TI bus, skipping my little adapter.. but you'd have to ditch linux on the PI, and write a full bootable program. Linux is too asynchronous with no timing guarantees. I designed TIPI to be easy to write.
Skipping the PI altogether, there is the SDD99 project under development... but it has no ETA as of yet.
Cheers
copying a DSK file to the TIPI drive automatically unpacks the DSK image into a folder https://www.arcadeshopper.com/wp/the-ti-raspberry-pi-connection/ has lots of good info
A FIAD is a file that is used for emulation, you can put it in a folder and read it directly with say classic99 emulator.
it can also be easily loaded into a TIPI drive and then using the web interface or tidir tool you can convert it to the correct format for TIPI to use (TIFILES)
Greg
You should look the FinalGrom99 up in the FAQ ..
Yes, ROM and GROM cartridge images on the SD Card.
