rietveld
How to make an esp8266 wifi modem work with the Adam
The serial chip will not receive unless DCD is active.  If you just hook up the Orphaneware RS-232 serial card's cable to the TTL adapter, using only TX, RX, and GND, that signal will not be active and terminal programs will not read any of the incoming data.You need to trick the serial card into thinking there is a DCD.  To do this all you need to do is jumper pins 7 and 8 together then jumper pins 1,6, and 4 together.
Edited by rietveld
